2018 Pioneer VSX-933 new generation AV Receiver - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #1 of 95 Old 04-22-2018, 11:54 PM - Thread Starter
dfa973's Avatar
Quoted: 1184 Post(s)
Liked: 1207
2018 Pioneer VSX-933 7.2ch new generation AV Receiver
Pioneer VSX-933 replaces the 2017 model VSX-932.
VSX-933 has resolved the 2 major letdowns of the VSX-932 2017 model:
- low count of HDMI inputs (4)
- no Zone 2
Differences from VSX-932:
- a little more power +5W (130 W/ch (6 ohms, 1 kHz, THD 1.0 %, 1ch Driven vs 135 W/ch (6 ohms, 1 kHz, THD 1.0 %, 1ch Driven;
- 2 extra HDMI Inputs (HDMI 4 In (4 Assignable) vs (HDMI 6 In (4 Assignable))
- 1 extra AV (Composite) 2 In (Assignable)
- ZONE 2 Pre/Line Out
- Speaker 9 ch Out (FRONT, CENTER, SURROUND, SURROUND BACK/HEIGHT/Bi-AMP, ZONE 2) but there are still only 7 amps - AVR switches between SURROUND BACK/HEIGHT/Bi-AMP and ZONE 2 posts;
- 30Watt less power consumption (Power Consumption/Standby: 480 W/0.15 W vs Power Consumption/Standby: 450 W/0.15 W)
- larger chassis (Dimensions (W x H x D): 435 x 173 x 320.5 mm vs Dimensions (W x H x D): 435 x 173 x 370.5 mm)
Notes:
- no eARC or other HDMI 2.1 features implemented or anounced!!!
Website: http://www.pioneer-audiovisual.eu/eu...oducts/vsx-933
Datasheet: http://www.pioneer-audiovisual.eu/si...sh/VSX-933.pdf
https://hometheaterreview.com/new-vs...-from-pioneer/
dfa973 is online now
post #2 of 95 Old 09-23-2018, 03:33 PM
Quoted: 13 Post(s)
Liked: 1
Thank you for you for this thread OP. ATM I can get the 932 for much cheaper than the 933 and so I did. I hope that was the right move.
PS: sorry for digging up an old thread.
m1ghtyun1t is offline
post #3 of 95 Old 12-16-2018, 07:26 PM
HammerJoe's Avatar
Quoted: 194 Post(s)
Liked: 24
How do you like the receiver so far?
I am looking at the 932 as a replacement for my old receiver.
HammerJoe is offline
post #4 of 95 Old 12-17-2018, 08:27 AM
HammerJoe's Avatar
Quoted: 194 Post(s)
Liked: 24
Does this receiver handle 8ohm speakers?
post #5 of 95 Old 12-17-2018, 02:53 PM
afrogt's Avatar
Quoted: 2426 Post(s)
Liked: 1589
of course, 8 ohm speakers are the easiest to power.
Afro GT
afrogt is offline
post #6 of 95 Old 12-24-2018, 07:43 AM
HammerJoe's Avatar
Quoted: 194 Post(s)
Liked: 24
Onkyo tx-r686 or this Pioneer?
I cant decide between these two.
So my question is there a significant difference between 80W and 100W power?
post #7 of 95 Old 12-27-2018, 07:41 AM
HammerJoe's Avatar
Quoted: 194 Post(s)
Liked: 24
This thread doesnt get alot of traffic.
Are people avoiding this receiver altogether?
Btw what is Pioneer commitment to firmware updates? 1 year? 2 years?
Also is Mcacc better than Onkyos AccuEq? I see that Mcacc does not allow individual speakers crossover settings while the Onkyo does. Not sure how important this is.
post #8 of 95 Old 12-27-2018, 01:33 PM
eriksells916's Avatar
Quoted: 802 Post(s)
Liked: 292
Joe I think I responded to you in another thread? However I am glad I found this one because after looking at it closely, the 686 actually now has the advanced version of accueq. Also, if you look in the 676 forum there are lots of issues with the 676 and arc and input switching randomly.
Keep us posted since I too am looking at the x1400, vsx-933, lx103 or 686 for the kids gaming area.
eriksells916 is offline
post #9 of 95 Old 12-27-2018, 05:49 PM
HammerJoe's Avatar
Quoted: 194 Post(s)
Liked: 24
I end up getting the 933.
It was the cheapest of the bunch and has all the features that I need.
Hopefully it outputs great sound.
eriksells916 likes this.
post #10 of 95 Old 12-29-2018, 11:46 AM
Quoted: 69 Post(s)
Liked: 6
Just got this 933.
But when playing spotify connect it disconnects after 2-3 songs.
Anybody else experience this?
mbm1000 is offline
post #11 of 95 Old 01-03-2019, 07:41 AM
HammerJoe's Avatar
Quoted: 194 Post(s)
Liked: 24
I got the 933 and have it set up and have been playing with it for the last couple hours.
ARC unfortunately doesnt seem to work with my Hisense tv. For some reason either the TV locks up or the sound is directed to the tv speakers even if the source is from something else like the cable DVR.
So I disabled it.
I ran MCACC and I checked the info and it seems pretty accurate for the distances.
But I find that while sound is loud/decent using the NET functions, the sound is quite low coming from my DVR receiver connected via HDMI.
Is there a way to boos the sound level just for that input without messing up MCACC?
post #12 of 95 Old 01-04-2019, 10:03 AM
Liked: 4
So I disabled it.
Hello, Check for a new update for VSX-933 01/04/2019 1030-6000-1040-0010!
I have just applied the following equalizer settings manually on VSX-933, search on youtube the following Pioneer AV-R EQ Equalizer Einstellungen Heimkino / AV Receiver Series SC / LX / VSX
First run calibration MCACC Speaker and only then adjust the equalizer settings manually.
oliver44 is offline
post #13 of 95 Old 01-04-2019, 07:27 PM
HammerJoe's Avatar
Quoted: 194 Post(s)
Liked: 24
Wow quite a difference in the sound. definitely louder which is good, and i think crisper too but when I compare the two settings before the correction it sounded fuller (albeit duller) so I am undecided which version (on or before eq) is the "real" sound.
What do you think?
Btw I cant change the band 63. Also I take that these settings are to be applied to all speakers right?
post #14 of 95 Old 01-04-2019, 10:31 PM
Liked: 4
Hello
For me it was easy with the settings, i use a 2.1 system, i have configured these settings on both speakers!
First run calibration MCACC Speaker and only then adjust the equalizer settings manually, you can adjust some settings from AV Adjust.
Name:	WhatsApp Image 2019-01-04 at 20.06.44(1).jpg
ID:	2505954   Click image for larger version
Name:	WhatsApp Image 2019-01-04 at 20.06.44.jpg
ID:	2505956   Click image for larger version
Name:	WhatsApp Image 2019-01-04 at 20.06.44(2).jpg
oliver44 is offline
post #15 of 95 Old 01-04-2019, 10:55 PM
Liked: 4
Originally Posted by mbm1000 View Post
Just got this 933.
Installs the latest firmware version and try using the remote app pioneer application, i use this application on my phone and i have no problems.
oliver44 is offline
post #16 of 95 Old 01-12-2019, 05:21 PM
Liked: 1
Hello all, I have a VSX-933 and I have a problem to connect my cable box to it. I connect it via HDMI and I can’t have sound pass with the HDMI, I try every 6 hdmi in without success, if the cable box is plugged directly in my tv (Q7F) i have no problem with audio. All other deceive plugged in receiver have sound via HDMI. Other thing when I plug my receiver and do info I see the input audio at Analog but don’t have/found any way to change the input audio at HDMI only Coax or Optical... witch when hooked up with an optical work...
Thanks if you have a clue or point me where to post my question if i’m not at the right place!
alexbolduc is offline
post #17 of 95 Old 01-12-2019, 06:12 PM
RKSKYDANCER's Avatar
Quoted: 400 Post(s)
Liked: 161
So I disabled it.
Make sure your HDMI cables are premium certified cables. Try enabling ARC on TV and receiver, enabling HDMI standby through and disable CEC. Also audio TV out to off.
Always Level match all your different sources with the Input volume absorber before doing any EQ adjustments.
You can also check your DVR receiver and be sure it is set to stereo, Not dolby digital 2.0 or 5.1. This makes the source louder. Your receiver will upgrade the stereo input to 5.1 by setting it to Dolby digital. It will sound the same but be louder. At least this is how my Xfinity DVR operates.
(Living Room) Sony XBR65X950G 4K TV, Harman Kardon Enchant 1300 & HK Enchant subwoofer, Sony UHP-H1 SACD & Panasonic DP-UB420 4K BD players.
(Garage) Sherwood RX-4105 Receiver, Samsung DVD/CD player, Klipsch 2.5 med oak speakers
RKSKYDANCER is offline
post #18 of 95 Old 01-13-2019, 03:57 PM
HammerJoe's Avatar
Quoted: 194 Post(s)
Liked: 24
Did you check in the settings input/ouput assign/hdmi?
post #19 of 95 Old 01-13-2019, 03:58 PM
HammerJoe's Avatar
Quoted: 194 Post(s)
Liked: 24
I used the volume absorber to add +5db and also used the equaliser settings shown in a previous message. The receiver is now loud just how I like it.
RKSKYDANCER likes this.
post #20 of 95 Old 01-13-2019, 07:46 PM
Liked: 1
Here what I got in the setting.
HDMI Input:
CBL/SAT:HDMI2 (HDCP 2.2) (Since all HDMI are assigned from 1 to 4 I only get "---" and HDMI2 as a choice)
Digital Audio Input:
CBL/SAT: "---" (Only choice is "---", Optical or Coaxial)
Analog Audio Input:
CBL/SAT: "---" (Choice is "---", Audio 1 to 4)
If I plug my Xbox One X in the CBL/SAT HDMI in (HDMI 2) I got image and sound by HDMI with this setting on the Receiver.
I did a Factory reset without success...
I don't know If I miss something somewhere. I can remember if in the first day I plug everything the sound work but the ARC from my TV (launching Netflix on the TV) have like over pass the sound of the CBL Box and now don't work anymore.
On my Cable box I don't have many choice. Dolby, PCM or HDMI Autoselect. And like I said if my cable box is plugged directly in my TV I have the sound via HDMI and return it back to the Receiver with the TV input(output) with an optical cable for the sound... On the TV the sound is set at Bitstream / Dolby and it is recognized by the amp.
post #21 of 95 Old 01-13-2019, 08:20 PM
Quoted: 802 Post(s)
Liked: 292
Alex I a have a hisense 65r6d with 2 hdmi inputs (Wave cable box and sony bluray) Those are then fed to my Integra avr via optical out from the tv. I get dts 5.1 sound from both hdmi sources.
my settings on the hisense are....settings/audio/spdif =D + DTS (due to old pre-hdmi Integra)
hope that helps?
post #22 of 95 Old 01-14-2019, 02:55 AM
Liked: 1
hope that helps?
Thanks Erik, I know passing by the TV it work but what I wish not to pass by my TV and use only the HDMI in on my receiver (The receiver is made for that in a sense! )
post #23 of 95 Old 01-14-2019, 10:07 AM
Quoted: 802 Post(s)
Liked: 292
Yea. I think the 933 has video upscaling maybe you need to turn it off and to straight pass-through, fwiw?
post #24 of 95 Old 01-15-2019, 06:15 AM
HammerJoe's Avatar
Quoted: 194 Post(s)
Liked: 24
If i rerun mcacc calibration does it reset the settings?
I'm asking because after reading about optimal subwoofer calibration settings and stuff.
Before i had the gain set at about half way in the sub and mcacc set up the sub level at +2.5.
Last night i increased the gain to 75% (3o clock on the knob) and ran mcacc and the sub level remained at +2.5.
That can't be right because i could hear the difference in the sub.
post #25 of 95 Old 01-15-2019, 06:42 AM - Thread Starter
dfa973's Avatar
Liked: 1207
Yes, it should overwrite the old settings with the new values.
If not, try to reset the AVR.
post #26 of 95 Old 01-16-2019, 06:38 AM
Liked: 1
Nope not working! I give up and plug my CBL Box via Optical Cable. That way I can have my TV return via Optical and need to use the volume of the TV when I use on tv app. Maybe I will find the way to pass audio from my CBL Box via HDMI un a near future... Maybe the problem is the Cable Box itself (Cisco Explorer 9883HD)
Thanks to all who have try to help. If I found something in the future I will post it here to help if someone else have the same issue...
post #27 of 95 Old 01-16-2019, 06:39 AM
Liked: 1
can't have my tv audio return
post #28 of 95 Old 01-29-2019, 04:18 AM
Liked: 0
Question Pioneer VSX-933 HDMI input problems
Hi,
I'm having problems with my newly purchased VSX-933. Everything works otherwise and sounds awesome but some of my devices pictures just don't show up when routing through the new receiver. My 4K AppleTV works great, and my PS3 works most of the time. My Wii and Xbox (original), both connected through HDMI (!) work great when connecting directly to the TV (LG 65" 4K OLED) but when routing through the receiver I can only hear their sound – but get no picture. I've tried different cables – but the same cables that work for the AppleTV don't work with the AV receiver. Same goes with the input ports on the receiver – same result: sound but no video.
Any thoughts or should I just take this back to the store?
Fredrik Rönnlund is offline
post #29 of 95 Old 02-07-2019, 06:18 AM
Liked: 1
Hello All I have some news (founds) for you from my previous post.
Recap of the Setup.
Samsung Q7F (HDMI2-ARC) plugged in TV OUT HDMI of VSX-933
Cable Box plugged in CBL/SAT HDMI input of VSX-933
Problem can't manage to have the sound from Cable Box to VSX-933 via HDMI
Here what I have found last night by mistake. When Im unplugging the TV OUT HDMI from VSX-933 or TV, the Receiver switch to HDMI and I have sound via HDMI from my Cable box. If I plug back the TV OUT HDMI (VSX-933) the Audio switch back to Analog and no more sound from Cable box via HDMI. I will try to disable the ARC from my TV tonight to see if its that who overpass the sound of my Cable box.
But if that point you to something it will be great to hear from you!
Thanks a lot!
post #30 of 95 Old 02-18-2019, 09:46 AM
a100's Avatar
Does the Pioneer VSX-933 have autoplay with Tunein and Deezer?
I am interested in a Pioneer VSX-933 if autoplay works with Tunein and Deezer. I mean the native net-access with login with the Pioneer app, and not using chromecast.
To check this, you have to look, if you can enter your login data with the Pioneer app. If so, play Tunein (and later Deezer), use the remote control, switch off the VSX-933 and switch it on again without doing anything else. Do you hear music?
It could be, that you have to check an option called "auto play", which I saw, when I used the webinterface of another Pioneer. See attachment.
a100 is offline
not available , novideo , speaker problem , surround
