New Behringer NX Series: 1000/3000/6000 in Black - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 253Likes
post #541 of 584 Old 11-02-2019, 10:50 AM
Augerhandle's Avatar
Quoted: 1393 Post(s)
Liked: 1354
Originally Posted by ghart999 View Post
Weird. It saved the 3rd time. Do I need to touch any of the switches on the back?
What switches? You said you have the NX6000D
Need help setting up a NX6000D...
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ________________________
Augerhandle is offline
post #542 of 584 Old 11-02-2019, 01:36 PM
ghart999's Avatar
Quoted: 220 Post(s)
Liked: 72
Oops. I wasn't looking on the amp itself. Just in the manual.
Audio: Denon AVR-X3400H - Behringer NX6000D - miniDSP
Speakers: LCR: DIYSoundGroup Cobalt 8s | Surrounds: NHT SuperOnes | Atmos: Boston Acoustic SoundWare | Subs: Marty cube w/ Ultimax UM18 and (4) JBL CS1214s
Automation: Fire Cube - Harmony Hub- Insteon Plugs - Sensi Thermostat
Video Image: TCL 55r625 - Roku - nVidia Shield Pro 2019 - Xbox One X
ghart999 is offline
post #543 of 584 Old 11-04-2019, 03:42 PM
rr14's Avatar
Quoted: 143 Post(s)
Liked: 32
Man nobody? I’m waiting on this to order.
Edit, this is about post 527. Do these still have turn off thump when used with one of those power strips that controls off additional outlets after the master shuts down?
rr14 is offline
post #544 of 584 Old 11-05-2019, 10:57 PM
kagtha's Avatar
Quoted: 150 Post(s)
Liked: 155
@rr14 I purchased the NX6000D the month it was released and have NEVER experienced the "Thump" issues.
It has been a part of my setup from before using the 12v trigger on my AVR. I have also used it with an older Sony 5.1 AVR, older Onkyo 7.1, a newer Denon and now a Marantz prepro.
All the speakers it powers are nearfield so I would know if it had a Thump issue.. lol
I cannot speak to any other models.
FYI, I use a solid state Relay rated up to 40 amps ( like $16) to interrupt one of the power wires using the 12v Trigger from my AVR. ( Before I upgraded my AVR, I used my TVs USB port as the trigger)
Sent from my Pixel 3 using Tapatalk
DIY HTR: One 800 lb. VBSS credenza, 3 horizontal Elusive 1099s, 2 HT-8 height duty wedges, & 2 DIY Volt 6 Tabletop Surrounds.
Bedroom:5 MLT-2 LCR & Surrounds, 2 hidden DIY shallow 12's, & 2 BST Bass Shakers on 2 PB875 Ensos.
kagtha is offline
post #545 of 584 Old 11-05-2019, 11:09 PM
kagtha's Avatar
Quoted: 150 Post(s)
Liked: 155
Originally Posted by crunchman12001 View Post
My NX6000D has the same issue on
my windows 10 laptop. No solutions out there so far.
@DavidinGA
I have used NXedit on my big powerful desktop with Windows 10 as well as two separate laptops running Windows 10 with absolutely zero issues.
Try unplugging all USB peripherals including a USB mouse just to be sure there are no conflicts.
Try turning off any Security software as some restricts USB usage.
Last but not least, if it is a work computer you may not have permission. But to check, try right clicking the NXEDIT icon and "Run as Administrator"
kagtha is offline
post #546 of 584 Old 11-06-2019, 08:40 AM
DavidinGA's Avatar
Quoted: 472 Post(s)
Liked: 164
Originally Posted by kagtha View Post
@DavidinGA
I'll have to go back and revisit it all; I gave up on the program ever working a while back...
I couldn't get it to work on two different win10 pc's, so I figured it was a poorly written program.
I never tried unplugging my usb devices, but I did try a number of other things such as: run in compatibility mode, run as admin, uninstall/reinstall multiple times. The app would simply never connect to the nx3000d. I think I tried multiple usb cables too, thinking that was the issue; never worked.
*edit*
I also tried it on my laptop and the nx3000d was the only usb device attached, so I guess I actually did try the no other usb devices attached suggestion - it didnt' work from my laptop either...
Other suggestions?
Source: HTPC w/madVR, Video: Epson 5040, 150" 16:9, Audio: Onkyo RZ 830 avr, 5.1.4 Atmos setup. 5 speaker Energy C Series: L/R C300's, C C-C100, SR/SL C50's, 4 in-ceiling Micca R-8c. Subwoofers: 1 MiniMarty um18 w/NX3000D. 2 VBSS 18" Subs w/NX3000D.
DavidinGA is offline
post #547 of 584 Old 11-06-2019, 09:24 AM
kagtha's Avatar
Quoted: 150 Post(s)
Liked: 155
*edit*
Other suggestions?
That thread is too long to go through everything you did. I did see someone mentioned to download the software from musictribe, but I downloaded mine from the support section of the regular behringer website. (see attached, it is still V1)
The only other thing I can think of is maybe you were running nxedit without unzipping it. Once downloaded you must unzip the nxedit.exe in a new place so it is not sitting in the nxedit.zip folder. Or possibly move it from your desktop to the root C drive and see if you can run it as admin from there just in case your desktop folder has some weird policy.
Did you ever install the inuke software on any of those computers? I have not, maybe it is conflicting?
I doubt this would be an issue but did you delete the first memory slot on the NX3000d? I did not. It is still there sitting next to 17 other saved config files.
Sorry I am all out of ideas if that does not work and you have verified you have a good usb cable. If that does not work.... from my perspective the only thing left to change is the operator.
I went through the whole process again just for you, you know what I learned? I got a damn good price on my unit for purchasing it before release. $ Should have bought 100 and sold em to you guys.. lol
ID:	2637160   Click image for larger version
kagtha is offline
post #548 of 584 Old 11-06-2019, 09:38 AM
DavidinGA's Avatar
Quoted: 472 Post(s)
Liked: 164
Ok, thanks for your help.
I'll revisit the issue maybe this weekend and see if I can get anything working.
post #549 of 584 Old 11-08-2019, 06:00 PM
xpertpredator's Avatar
Quoted: 45 Post(s)
I have a dumb question. I am constructing a BOSS, from the hidden theatre thread, and have ordered the NX3000d amp. I received it today, but looking at the back on the connectors. What is everybody using for the input and output connections?
xpertpredator is offline
post #550 of 584 Old 11-08-2019, 07:33 PM
smcmillan2's Avatar
Quoted: 1026 Post(s)
Liked: 866
From AVR to NX3k: https://www.amazon.com/Monoprice-XLR.../dp/B001VLW398
From NX3k to drivers, it depends. You can do SpeakOn to bare wire connection on the drivers or SpeakOn to a SpeakOn connector on the platform.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is online now
post #551 of 584 Old 11-13-2019, 10:16 PM
jch2's Avatar
Quoted: 157 Post(s)
Liked: 135
Send a message via Skype™ to jch2
Is anyone using the NX series amps for full range HT use?
Did the reported high frequency fix on the NX work (i.e. Benefit from a linear frequency response at any speaker load, by virtue of the NX4-6000's SmartSense loudspeaker impedance compensation)?
Do they hiss or him or have any noise through the speakers when used for full range, or have and turn on or off thumps or pops?
I've read about the fan noise and poor heat dissippation from the cost-cutting to produce an inexpensive unit. That is one shortcoming that I can deal with: I have read many fan and heatsink mod threads. I'm happy to mod them to be quiet and extend the longevity with a little investment in each unit if that overcomes these shortcomings. But I can't do anything about issues related to using them as full range home theater amps, so those are the issues I am most interested in hearing about.
I have read about a relay mod for the main power switch to make them trigger on a 12v trigger signal from a processor. Has anyone done it or know where the information is located? If so, can you share a link to that please?
Are the ULF frequency power output drops that much of a concern? Is the better or worse than the same problem the Crown XLS 2502 seems to have (i.e. has anyone measured both and compare power output below 40Hz down to 5Hz)?
The reason I ask is because a stack if NX4-6000 amps seem ideal for a 16 channel home theater setup. The power is overkill but the price is exceptional. You could use 4 of them (16 amp channels) for bed layer and heights, and bridge a couple more for subwoofer duty (a bridged NX4-6000 seems identical to an NX6000). You would then have redundancy, if one failed you could send it in for warranty repair and swap things around so the least important channels were without an amp during the repair.
Thoughts?
jch2 is online now
post #552 of 584 Old 11-16-2019, 04:46 PM
Liked: 0
NX3000D Limit LED Question
Used software to set NX3000D in Bridge mode and connected single in (from preamp) and out (to subwoofer) on channel A. Set the channel A limit to 700W for 4 ohm load. Saved all settings. When using, I put the input signal levels on channel A to about the 11 o'clock position and channel B to zero. On some loud passages I see green LEDs for both channels light up and if the passage is very dynamic (e.g.: heavy bass drum, cannon fire, etc.) the red limit LED on channel B (but not necessarily on A) will light momentarily. Since I'm only connected to channel A for input and output in Bridge mode and channel B's limit setting is blanked out and gain level is set to zero, why am I getting any signal level and limit LEDs on channel B? Thanks to all.
Rag_Dude is offline
post #553 of 584 Old 11-16-2019, 04:59 PM
Quoted: 28 Post(s)
Liked: 8
@DavidinGA
Thank you for the reply kagtha, I tried it again as an administrator, turned off pop up blockers and anti virus. Still cannot get the s
software to connect. I will have to see if I can get my wife who is in "IT" to try it. I will report back. It really shouldn't be this hard. ****ty software IMO.
crunchman12001 is offline
post #554 of 584 Old 11-16-2019, 05:17 PM
Liked: 1354
Considering the limiter software claims 5000 watts at full power vs the 3000 watts claimed by the manual, one would assume the 700 watt setting to really be closer to 420 watts. If you want to set the limiter to a true 700 watts, try setting the limiter to 1167.
Channel B's amp is also being used in Bridge mode, thus both sets of lights lighting. Due to tolerances, each channel will not necessarily be exactly equal in power or report that power exactly alike, so one red light may light before the other.
post #555 of 584 Old 11-16-2019, 06:16 PM
blake18's Avatar
Quoted: 656 Post(s)
Liked: 372
Just got the NX3000D, and wow, these are much nicer looking and sounding than the iNukes were. I also have the iNuke 3000DSP, and the NX series is definitely an improvement in just about every way. Absolutely love it.
Lumenlab "Community driven video lab".
blake18 is offline
post #556 of 584 Old 11-17-2019, 09:03 AM
Liked: 0
Of course, you're correct that the B channel amp is used in bridge mode! Don't know what I was thinking! Guess the software graphics blanking out the channel limit settings threw my mind off track. Anyway, thanks for setting me straight. Now the indications make sense. I'll also look into bumping up that watt limit too when I get back into it. Thanks again!
Rag_Dude is offline
post #557 of 584 Old 11-17-2019, 12:45 PM
DavidinGA's Avatar
Quoted: 472 Post(s)
Liked: 164
Yeah , I still can't make mine work either....
Sent from my Pixel 2 XL using Tapatalk
crunchman12001 likes this.
post #558 of 584 Old 11-17-2019, 05:35 PM
kagtha's Avatar
Quoted: 150 Post(s)
Liked: 155
Did you guys unzip it?
If you did not unzip it, you will be able to see "Extract All..." as on option when you right-click the file.
kagtha is offline
post #559 of 584 Old 11-19-2019, 04:28 AM
stegen's Avatar
Quoted: 184 Post(s)
Liked: 119
nuke6k run a pair of othorns
I am on the verge of building 2 more othorns and was wondering if the mentioned amp would be sufficient at running a pair of ots?
stegen is offline
post #560 of 584 Old 11-30-2019, 07:04 PM
RamKat's Avatar
Originally Posted by afaa View Post
Ah dang it. Didn't think about that.
The good news: DHL notified me they will deliver today.
The bad news: It is really a 240V version per the user manual. What to do now?
Power Supply, Voltage, Current Consumption (Breaker / Fuses)
USA / Canada 120 V~, 60 Hz, (T 25 A H 250 V) 100-120 V~, 50/60 Hz,
(T 10 A H 250 V)
UK / Australia / Europe 220-240 V~, 50/60 Hz, (T 12 A H 250 V) 220-240 V~, 50/60 Hz,
(T 6.3 A H 250 V)
Power consumption @ 2 Ω,
1⁄8 rated power
— 620 W 350 W
Power consumption @ 4 Ω,
1⁄8 rated power
620 W 620 W — —
Mains connector Standard IEC receptacle
I realize that this post is already a few months old. However, looking at pictures of the Printed Circuit Board posted elsewhere in this thread, it appears as if the voltage rating is added as a label (i.e. 120V or 220V/240V) instead of being printed as part of the silk screen process. This tells me that Behringer is most likely using the same PCB for both configurations. The difference can be as simple as populating a component such as a resistor between different pads to define the voltage configuration.
Has anyone looked into this layout design? Difficult to read the details from the pictures.
Epson 8500UB (R); Elite Electric100 16:9; Yamaha RX-V671; Polk Monitor 60 x 2, Polk CS2, Polk Monitor 30 x 4
RamKat is offline
post #561 of 584 Old 11-30-2019, 08:14 PM
Liked: 1354
Yeah, I think I read somewhere that there is a jumper you can cut, or vice versa.
post #562 of 584 Old 12-02-2019, 03:39 AM
RamKat's Avatar
That looks like it. If the INuke is the same as the NX, then this video shows removing of two jumpers and adding one jumper to go from 110 to 220. Interesting that Behringer use through hole jumpers instead of zero ohm surface mount parts.
RamKat is offline
post #563 of 584 Old 12-02-2019, 03:46 AM
RamKat's Avatar
Also found this thread in the DIY subwoofer section
https://www.avsforum.com/forum/155-d...110v-220v.html
From the discussion it appears as if there are more jumpers involved on the 6000 (as per the video above) than just the single one shown in the pictures for the 3000.
RamKat is offline
post #564 of 584 Old 12-02-2019, 08:40 AM
jcr159's Avatar
Quoted: 213 Post(s)
Liked: 114
The real question is...
Do they output any more power running off 220 vs 110?
Have a question and want it answered in podcast format?
[email protected]
http://www.avrant.com/
https://www.youtube.com/c/avrant
jcr159 is online now
post #565 of 584 Old 12-02-2019, 12:52 PM
Liked: 1354
The real question was whether the OP, who accidentally bought the 220 version, could convert it to 110.
post #566 of 584 Old 12-02-2019, 12:56 PM
jcr159's Avatar
Quoted: 213 Post(s)
Liked: 114
ah... missed that..
[email protected]
post #567 of 584 Old 12-02-2019, 03:28 PM
RamKat's Avatar
Correct, In my case I am considering buying a NX3000D from the same source as the OP at a significant reduced price when compared to the current NA prices. Since I will forfeit the warranty by replacing the fan (from whom ever supplier I buy) I may as well add this 240V to 120V mod to the mix if it would save me some dough. I have a 220/240V outlet in my workshop so I could test the unit and even run it for a while before doing the mods. This should take care of DOA or any infancy failures. The only thing to get certainty about is if adding a single jumper to the PCB on the NX-3000D is the only mod required.
I have a hunch that the current high prices in NA have to do with maybe a short supply? This is based on the observation that PE has been out of stock on the NX3000D pretty much when the price increase happened from the other suppliers.
RamKat is offline
post #568 of 584 Old 12-06-2019, 10:06 PM
Liked: 0
Ok so I have found a big difference in distortion on the limiters when comparing the inukes to the nx series. With a long hold/release limiter there was no audible distortion in the inukes, it just capped the volume but with the nx6000dsp it distorts like crazy. Tested on two amps with the same result and the distortion gets worse as you turn down the threshold or smash it harder. Am I missing something here?
unboundsound is offline
post #569 of 584 Old 12-11-2019, 09:27 AM
rr14's Avatar
Quoted: 143 Post(s)
Liked: 32
anyone know if there is a difference between the Europe versions and the us versions? In other words do they still do two versions, a 120 and a 230? Or is it just a plug difference?
rr14 is offline
post #570 of 584 Old 12-11-2019, 09:44 AM
jch2's Avatar
Quoted: 157 Post(s)
Liked: 135
If you read earlier posts in this thread, someone from the US purchased an NX4-6000 from a UK dealer for a great price and got a 240V version. So, apparently there are two versions. It's not an auto-sensing power supply, and there's no switch to change between 120V and 240V. But, apparently it can be modified by cutting/attaching one wire and moving a soldered jumper, to convert them between 120V and 240V. There are YouTube videos showing the process in the NX3000.
If you buy from the UK dealer to get the good price you will get a UK version setup for 240V and with a UK plug. You'll either have to change the plug and use a 240V circuit, or do the conversion to 120V by modifying the internals.
Main: Marantz AV8805, 5x Behringer NX4-6000, Epson 6050UB, Stewart Greyhawk 120", LG C8 65", DISH H3, Panasonic UB820, ATV4k, FTV4k, 7.2.6+2: DefTech BP2000, CLR2000, Di 5.5BPS, UIW BPZ/A, Di 8R, M&K MX-125. Bedroom: Yamaha RX-A3070, LG C8 55", DISH 4k Joey, FTV4k, 5.1.4: DT RCS II, RSS II, IW Sub Ref. Basement: Yamaha RX-A3040, 3x Marantz MA700U, Panasonic PT-AE8000U, Panasonic P65VT50, 6.1: DT BP2000, CLR2000, Di 6.5R
jch2 is online now
