"OFFICIAL" 2018 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8) - Page 135 - AVS Forum | Home Theater Discussions And Reviews
 2775Likes
post #4021 of 5678 Old 07-04-2019, 05:09 PM
M Code's Avatar
Quoted: 1130 Post(s)
Liked: 733
Originally Posted by prsman View Post
thanks the loudspeakers are Polk RTi-A7, 8ohms, sensitivity 89db
2 subwoofers
Room is 4500ft3
Volume probably just below theater level.....wife complains.
100% movies, streaming,
what do you think?
U should be fine...
If U do need more power, EZ to connect another component power amplifier to the 4500's pre-outs..
Just my $0.02...
M Code is online now
post #4022 of 5678 Old 07-04-2019, 05:40 PM
prsman's Avatar
Quoted: 221 Post(s)
Originally Posted by M Code View Post
U should be fine...
Just my $0.02...
ok. thanks. Yes easy to connect but from I can find so far very expensive for a power amplifier.
I if used an seperate amp for the front right, left, would that power would be available for the Denons other channels?
I just had thought, I have a Yamaha AVR that was replaced by the Denon. I could experiment with it to see if it makes a difference in what I hear.
Are you in Cotati? Its spelled Cocati in your location. My son lives near the police station in Cotati.
thanks!
prsman is offline
post #4023 of 5678 Old 07-04-2019, 05:44 PM
Quoted: 28 Post(s)
Liked: 31
I have an Onkyo Nr737 ~110 watt 2 ch with RtiA9's crossed at 80Hz with subs. For 7 speaker surround on movies it can get ridiculous loud with room to spare - I have not come close to maxing it out because its way too loud. On music I prefer 2ch with the subs and it gets between very loud and ridiculous loud depending on music type. For some reggae/dancehall I can turn it all the way up and still want a bit more.
The power consumption on the A7 and A9 is to get the subs working, but at 80Hz crossover they would probably only handle 160 Watts or a bit more. 125 vs 160 Watts at full blast would be a small difference.
The Denon will work nicely.
tooslow2 is offline
post #4024 of 5678 Old 07-04-2019, 06:53 PM
Madmax67's Avatar
Quoted: 2267 Post(s)
Liked: 2570
Originally Posted by b0rnarian View Post
Thnx for the reply... its definitely the denon as i noticed the auddessy was also turned off. It was like this when I got home from work and nobody else used it. So I saved the settings on a usb, reset the reciever and uploaded again. Seems like all movies have atmos back but still no dice on GOTG V2 and Ghost Protocol. Im stumped!
That's weird. So first it was all movies and now it's just certain discs? Double check those aren't the blu ray versions instead and some 4K discs make you first play the film then select the Atmos track while playing. Other than that I'm running out of recommends.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #4025 of 5678 Old 07-04-2019, 07:01 PM
b0rnarian's Avatar
Quoted: 2084 Post(s)
Liked: 1262
I too am lost here. I make sure the 4K discs go into HDR, ive sold the blurays anyways and then I make sure the oppo is playing Atmos track via the disc menu and the oppo also reports its Atmos 7.1 track but denon shows DD+DS. I select info on denon and it shows the input is for 5.1 speakers only. But now it's only these two movies... GOTG V2 and Ghost Protocol.
PS, I got a new fw update on the denon this morning.
Samsung 65 KS9800 + Denon X4500H (11.2) + OPPO 203 + PS4 + Roku
Disc Lot For SALE : HERE!
b0rnarian is offline
post #4026 of 5678 Old 07-04-2019, 08:25 PM
M Code's Avatar
Liked: 733
The fewer channels used in the Denon, the more power/current reserve is available for the other channels.
Yup, correct spelling is Cotati. I am located just 2 miles east of Sonomo State University.
Just my $0.02...
post #4027 of 5678 Old 07-04-2019, 09:49 PM
Quoted: 14 Post(s)
Liked: 2
Did you try resetting the microprocessor a few times in a row? If yes, and still no joy, then warranty repair.
Tried one time today, still no luck. Looks like warranty repair is the destiny for my beloved X3500 H.
Thx
mapleoak is offline
post #4028 of 5678 Old 07-05-2019, 07:20 AM
Dan in St. Louis's Avatar
Quoted: 369 Post(s)
Liked: 277
The volume level I use is at 50%
Assuming that by "50%" you mean "50" on Denon's default volume scale, that is the equivalent of -30dB with respect to an arbitrary reference level after Audyssey calibration has been run. Since -30dB = 1/1000 of the reference power level you should have no problems.
Madmax67 likes this.
M = Mega, m = milli. K = Kelvin, k = kilo. B = Bytes, b = bits. G = Giga, g = gravity. Dan in Saint Louis
Dan in St. Louis is offline
post #4029 of 5678 Old 07-05-2019, 07:28 AM
NismoZ's Avatar
Quoted: 117 Post(s)
Liked: 41
Just got a AVR-X4500h today from accessories4less. Hooked it all up and I get no video menu to come up. I hooked it all up the same way I had my last receiver. I'm using the Monitor 1/ARC HDMI out on the denon, to the HDMI1 IN on my TV. All it says on the front is Cable/Sat. I pressed info/setup buttons on the remote, no go. I looked in the manual for anything that I should be doing, and it's like it skips right over all this. Right after the part where you plug the power in, they just start talking about the setup, like you don't have to press anything. I even did a factory reset on the front panel, no go there. Can anyone help me out? When exactly should I be seeing an onscreen menu? Any buttons I should be pressing on the remote to get into that menu?
NismoZ is offline
post #4030 of 5678 Old 07-05-2019, 07:38 AM
prsman's Avatar
Quoted: 221 Post(s)
super. Yes 50% is the Denon value shown after Audyssey calibration.. Thank you. I understand better now.
prsman is offline
post #4031 of 5678 Old 07-05-2019, 07:58 AM
dfa973's Avatar
Quoted: 838 Post(s)
Liked: 766
Probably it's a lemon (DOA). You should return/warranty the unit.
dfa973 is online now
post #4032 of 5678 Old 07-05-2019, 08:27 AM
Quoted: 369 Post(s)
Liked: 277
Just so you don't get stung by a confusion trap later: that "50" is not a percentage, it is a scalar number on a 0 to 98 scale with each increment of 1 being 1dB different in amplitude.
Another way to look at it (and can be selected as a Denon setup choice) is that the dB scale = (numeric scale) - 80. That is, 80 numeric = 0dB. Depending on room size and program material you may find volume settings between -40dB and -20dB to be comfortable. Program sources are not consistent either. I see 10-15dB adjustment needed between different streams from Roku channels, for example.
post #4033 of 5678 Old 07-05-2019, 08:48 AM
NismoZ's Avatar
Quoted: 117 Post(s)
Liked: 41
I just updated the firmware and it seems to be ok now. That really doesn't easy my mind to much. We'll see.
NismoZ is offline
post #4034 of 5678 Old 07-05-2019, 08:57 AM
NismoZ's Avatar
Quoted: 117 Post(s)
Liked: 41
Ok, a few more questions. My last AVR was a Pioneer SC-07. The calibration included a few more things like playing a sub 3 times with each channel. The only thing Audyseey did was go around the channels with the high pitched sweep in my 3 listening positions.
How does Audyseey EQ the sub and where can I see the curves and corrects it made from 10Hz through 80Hz?, etc? I also thought Audyseey would do the same for the L, R, C and Surround settings as well.
What am I missing here?
NismoZ is offline
post #4035 of 5678 Old 07-05-2019, 09:08 AM
Quoted: 958 Post(s)
Liked: 291
Return the unit. No warranty. And then wait. These units come on sale NEW often. Heard more than one story about theses refurbished units.
SouthernCA is online now
post #4036 of 5678 Old 07-05-2019, 09:53 AM
prsman's Avatar
Quoted: 221 Post(s)
ok. I should got over to the db scale then. Thats more absolute.
I found I have to set the digital input to +12db to not have to turn up the volume so much. Also the dynamic range or compression settings makes a big difference in volume. I have to turn it up much more if no compression is selected. Ive been using "light" as that seems to give reasonable average volume levels.
prsman is offline
post #4037 of 5678 Old 07-05-2019, 09:59 AM
fulano's Avatar
Quoted: 59 Post(s)
Liked: 42
What SouthernCA said x2.
My first unit's HDMI was bad out of the box so I took it back. Didn't discover problems with replacement unit's HDMI until after return window had closed, will have to send for repair when I can stand to be without home theater for a few weeks (OSD problem, so annoying but not critical). Any doubts, don't wait, kick it to the curb...oh, and my units were brand new, not refurbs.
Vizio E-701i, Denon X4500H, Crown XLS-1502, Polk Monitor 70s, Polk CS2 II, Polk T15s, Klipsch RIC-65, Tivo Roamio OTA, LG BD570, Fire TV 1, Fire TV Stick 4K, XBox 360, Harmony Smart Control
fulano is offline
post #4038 of 5678 Old 07-05-2019, 10:18 AM
Quoted: 958 Post(s)
Liked: 291
Oh. Thanks for the remind. I will store my old AVR (very very reliable, working for 15 years, Yamaha) in the garage just in case.
post #4039 of 5678 Old 07-05-2019, 10:44 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22772 Post(s)
Liked: 12419
All of your Audyssey related questions are answered in the FAQ ---> https://www.avsforum.com/forum/90-re...d-part-ii.html
jdsmoothie is offline
post #4040 of 5678 Old 07-05-2019, 11:39 AM
Liked: 0
Unhappy AVR and HD Audio streaming
Does anybody has positive results with FLAC coded HD Audio streaming reception?
For exampleIntense Radio(Dutch):
<stream.png>
Initially my new X4500H was able to play such links.
After that I spent next few days playing with my DLNA server settings, and when I tried to play such link again, receiver refused to play streaming FLAC audio anymore.
I tried to make system reset, but this didn't help.
The is no problem with playing mp3 streams.
I also noticed some difference, using DLNA and USB. Some FLAC files, which can be played from USB, couldn't be played from DLNA. Also it seems that all multi-channel FLAC files are banned for some reason. For the testing I used files from:
<hires.png>
Only original CD 16BIT/44kHz files can be played from DLNA. Stereo 24BIT/192kHz(176k) and Stereo 24BIT/96kHz(88k) can be played from USB and no way for multi-channel (5.1). Didn't try DCD yet, as I don't have such records in my archive.
PS Sorry for the links, the system doesn't allow to put direct links to the newbies...
ID:	2587830   Click image for larger version
Cool2000 is offline
post #4041 of 5678 Old 07-05-2019, 01:22 PM
infamous_pb's Avatar
Question Denon AVR and the Smart Menu
I have a Denon x1500h AVR and a Samsung NU8000 HDTV. On the Samsung, I have the Anynet+ (HDMI-CEC) Set to ON so that when I turn on the TV, it will automatically turn on the Denon AVR. When it turns on, it shows the Denon Smart Menu. I click the "Now Playing" button and goes to it's source. However, just seconds later, the Smart Menu pops back up and I have to click the "Now Playing" button for a second time - then it stops popping back up. Any reason why it pops up two times?
I know you can turn OFF the Smart Menu in the Denon settings, however, when I do, then the AVR doesn't automatically turn off/on when I turn off/on the TV. I've tried various settings in the Denon menus, but nothing seems to work.
Any ideas why the Smart Menu keeps popping up two times on the Denon AVR?
infamous_pb is offline
post #4042 of 5678 Old 07-05-2019, 04:09 PM
Madmax67's Avatar
Liked: 2570
Whenever you buy a factory certified receiver you should do 4 or 5 full microprocessor resets in a row before setup. Glad it was an easy fix.
Madmax67 is offline
post #4043 of 5678 Old 07-05-2019, 04:17 PM
Madmax67's Avatar
Liked: 2570
Technically it's more relative. The 0-98 one is considered absolute but most experienced owners use the Relative scale(+18 to -80.)
That's actually pretty common at lower levels.
Madmax67 is offline
post #4044 of 5678 Old 07-05-2019, 04:24 PM
Madmax67's Avatar
Liked: 2570
You're not going to see something regarding actual post correction results because the test tones are only used pre EQ not post. The ones provided in the receiver offer just a guess of what those post correction filters affected. To get any real post correction measurements you'll need to invest in a calibrated USB mic like the UMIK1 and Room EQ Wizard freeware to take in room measurements after the fact.
Madmax67 is offline
post #4045 of 5678 Old 07-05-2019, 06:53 PM
Quoted: 77 Post(s)
Liked: 8
I’m sort of bumping my post up there somewhere, because I’m so baffled and stressed out. So, I called Denon support about my issue and the message said there was a wait, so the automated system had an option to call me back. 45 minutes later, they called me back, said press option 1 to be connected and they hung up on me (it was 10 minutes before closing). I sure wasn’t too lazy to spend my hard earned money on the last 3 AVR’s I’ve owned. Okay, that aside:
I have an ARC problem I’m trying to isolate. Denon X3500H, Extenders (AVPro Edge AC-EX100-444-KIT - ARC compatible) out ARC Monitor 1 to the ARC port on the Samsung Q9FN. No ARC.
Samsung Apps will only play TV Sound. CEC turned on in TV, HDMI Control and ARC set to on in the X3500H. Firmware current on all.
I have not done a hard reset on either (haven’t unplugged Samsung, but did unplug the Denon and Extender).
I’m pulling my hair out. Anyone? This is insane.
Rich428 is online now
post #4046 of 5678 Old 07-05-2019, 07:08 PM
Quoted: 958 Post(s)
Liked: 291
[quote=Rich428;58262884]I’m sort of bumping my post up there somewhere, because I’m so baffled and stressed out. So, I called Denon support about my issue and the message said there was a wait, so the automated system had an option to call me back. 45 minutes later, they called me back, said press option 1 to be connected and they hung up on me (it was 10 minutes before closing). I sure wasn’t too lazy to spend my hard earned money on the last 3 AVR’s I’ve owned. Okay, that aside:
Sent from my iPhone using Tapatalk[/quote @jdsmoothie will recommend 4 to 5 hard resets. Often, resets fix the anomolous behavior.
Rich428 likes this.
post #4047 of 5678 Old 07-05-2019, 07:21 PM
HiRes_PR's Avatar
Quoted: 67 Post(s)
Liked: 63
[quote=SouthernCA;58262938]
Can you remove all that and just connect the receiver to the TV with just one cable?
HiRes_PR is online now
post #4048 of 5678 Old 07-05-2019, 07:29 PM
Quoted: 77 Post(s)
Liked: 8
[quote=HiRes_PR;58262982]
Problem is, they’re 80’ apart. No issues running Video & Audio out to the Q9FN, just no ARC.
That same X3500H uses the zone 2 output to feed another room that shares some of the sources.
A lot of my research shows people unplugging ALL hdmi to both the AVR and TV and rebooting both. I haven’t tried that yet. (Hard to get that room away from my wife). I also just started wondering why the integrator didn’t use Monitor 2 HDMI output, but used Zone 2.
post #4049 of 5678 Old 07-05-2019, 07:31 PM
Quoted: 77 Post(s)
Liked: 8
I’m not certain how to do a proper reset. I really wanted to try that. I did an unplug 1 minute replug, but I know there’s a way to do a processor reset.
post #4050 of 5678 Old 07-05-2019, 07:57 PM
Liked: 0
AVRS540BT Firmware upgrade ?
Hello,
First post here, glad to have found this informed group.
Question please on firmware upgrade for a AVRS540BT
I received this unit in Canada via Amazon in 2018. I see on the web page a firmware upgrade is available as of Jan 2019
However when I load in my model number and s/n to the web page , it tells me nothing is available ?
Any suggestions ?
Thank you kindly
Teddis is offline
calibrate , dali alteco , Denon , denon 3500 , denon 4500h , denon avr-x4500h , denon x3500 , earc , heco victa 500 , lg b8 , onkyo ts-xr507 , sound , speakers , svs pb-1000 , tear ax3000 , testing
