"OFFICIAL" 2018 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8) - Page 144 - AVS Forum | Home Theater Discussions And Reviews
 2505Likes
post #4291 of 5003 Old 07-23-2019, 03:53 PM
Alan P's Avatar
Quoted: 6297 Post(s)
Liked: 5627
Alan P is offline
post #4292 of 5003 Old 07-23-2019, 04:48 PM
Mactavish's Avatar
Quoted: 133 Post(s)
Liked: 129
Originally Posted by Alan P View Post
Three words: Uninterruptible Power Supply. You're welcome.
Owned a bunch of UPS units, in front of lots of computers, ended up never needed them here, got tired of replacing overpriced batteries. Tossed all of them.
BUT, for MOST, good idea. If my Denon ever shuts itself during a lightning storm, I’ll reconsider going down that road again. Unless, there is a potential of “in air electrical”, charges it’s hard to imagine in my situation the lighting could get into the power company grid, I have no antenna connections. But one never knows. A UPS is “potential” insurance in many cases. Do ones homework and then decide. A good one with ample power specs can be around $100 or more depending on how many watts you want to protect. If my setup was up in the “country”, crappy power grid, external power lines, etc., I wouldn’t run any electronics without a UPS. I have a decent surge protector, hopefully good enough for my big city apartment, time will tell.
HDTV: Panasonic P55VT50 Plasma
AVR: Denon X3500H
SPEAKERS: Ohm (mains), Chane 2.4 (center), Rythmik F12G (sub), DefTech ProMonitor 80 (sats)
MEDIA PLAYER: Oppo BD83
Mactavish is offline
post #4293 of 5003 Old 07-23-2019, 06:07 PM
sd13's Avatar
Quoted: 1126 Post(s)
Liked: 1074
Any way to disable this stupid mute logo on the Denon receivers? This has burn in written all over it for oled owners.
sd13 is online now
post #4294 of 5003 Old 07-23-2019, 06:10 PM
Pete7874's Avatar
Quoted: 266 Post(s)
Liked: 156
Just ordered a refurb S740H to replace my dead Yamaha RX-V471. Looking forward to setting it up this weekend. It'll be driving two Dayton MK402X fronts and Chane A2.4 center, alongside a PA120 sub.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Samsung UN55B7100  Denon AVR-S740H  Chane A2.4  Dayton MK402X  Premier Acoustic PA120  Roku Premiere Plus  Squeezebox Classic  CCA
Pete7874 is offline
post #4295 of 5003 Old 07-23-2019, 06:47 PM
chi_guy50's Avatar
Quoted: 2231 Post(s)
Liked: 2269
I'm in the "big city" (such as it is) and I have all of my essential electronics (computers and A/V gear) protected by six UPS's. I like the Cyberpower brand, but I also make sure to buy units for which there are non-OEM replacement batteries available at a reasonable price (less than $30, i.e. about $10 per year apiece). It's an affordable safeguard for expensive equipment against most non-catastrophic occurrences and, beyond that consideration, it allows for continuous operation during short outages (particularly nice for DVR recordings).
Living Room: Sony XBR-65Z9D; Oppo UDP-203; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H (9.1.4/13.1); Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929, DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is offline
post #4296 of 5003 Old 07-23-2019, 06:55 PM
Madmax67's Avatar
Quoted: 2164 Post(s)
Liked: 2474
Not that I'm aware of and that bothers me as well so I just lower my volume to - - rather than use mute.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #4297 of 5003 Old 07-23-2019, 06:59 PM
Madmax67's Avatar
Liked: 2474
Congrats. I'd start by reading up on the Audyssey faqs 101 thread. Lots of helpful setup tips for both before room EQ and afterwards.
Madmax67 is offline
post #4298 of 5003 Old 07-23-2019, 07:47 PM
sd13's Avatar
Liked: 1074
I’m also having trouble with dynamic volume? When it’s set to off, I’m getting very very low volume. Light is by far the loudest. Is this normal?
sd13 is online now
post #4299 of 5003 Old 07-23-2019, 08:10 PM
Madmax67's Avatar
Liked: 2474
Low volume at what level setting? Denon uses a logarithmic gain structure so initial volume increases are more incremental then as you increase the volume you'll notice quicker increases in perceived listening levels. No, that's not right with Dynamic Volume. Light should have the least effect and High should have the most. I use Medium personally.
Madmax67 is offline
post #4300 of 5003 Old 07-23-2019, 11:47 PM
sd13's Avatar
Liked: 1074
Light does have the least effect and high has the most effect but when dynamic volume is turned off, there hardly any sound coming out of the speakers.
sd13 is online now
post #4301 of 5003 Old 07-24-2019, 12:13 AM
Madmax67's Avatar
Liked: 2474
Got it but at what listening level? The Absolute scale is the default range and it runs from 0 to 89. 80 is Reference level so if you're listening at say 50 that's 30dB below that and might not sound very loud depending on your seating distance from your speakers. Check your on screen level and see where it is between that range and list it in your next post.
Alan P likes this.
Madmax67 is offline
post #4302 of 5003 Old 07-24-2019, 10:05 AM
Liked: 1
Originally Posted by audimus View Post
Thank you for reply and advice
I've detached any wires from AVR, except couple HDMI in-out and power cord, obviously.
Tried to play dosens of DTS demos (lossy and lossless) via kodi on Shield TV (passthrough for DTS and DD only)
AVR was set to Direct mode, output to headphones.
Result: Clicks and cracks, sound loss for 5-10 seconds, mostly for the right driver.
GREMeZ is offline
post #4303 of 5003 Old 07-24-2019, 12:19 PM
Pete7874's Avatar
Quoted: 266 Post(s)
Liked: 156
I've been trying to find an image of what the Denon volume display on a TV screen looks like. The only thing I was able to find is the photos in this older thread that pertains to AVR-3310CI/990, so obviously ancient history.
What does it look like on these newer S and X series receivers?
Pete7874 is offline
post #4304 of 5003 Old 07-24-2019, 01:09 PM
jmbgator's Avatar
Quoted: 37 Post(s)
Liked: 24
Hi Everyone-
I currently own a X4500H receiver. I would like to transmit audio to bluetooth wireless headphones from my AVR receiver whenever I want to listen through the headphones. I know that Denon AVRs only receive a bluetooth signal and don't transmit to headphones themselves. Therefore, If I were to buy a bluetooth transmitter, what would be the recommended way to connect it to the AVR in order to maximize sound quality and convenience?
TV: 65'' Samsung KS8000; AVR: Denon AVR X-4500H; Center Channel: Polk Signature S-35; L/R Channels: Polk Signature S-20; LFE: SVS-SB3000; UHD Blu-Ray Player: Sony UBP-X800; Gaming: PS4 Pro; Streaming Device: Apple TV 4K
jmbgator is offline
post #4305 of 5003 Old 07-24-2019, 01:16 PM - Thread Starter
jdsmoothie's Avatar
Quoted: 22426 Post(s)
Liked: 12200
Originally Posted by jmbgator View Post
Hi Everyone-
Zone 2 pre-outs is your only option if you want to pass HDMI audio otherwise, if not, the Zone 3 pre-outs can be used.
Madmax67 likes this.
jdsmoothie is offline
post #4306 of 5003 Old 07-24-2019, 01:25 PM
chi_guy50's Avatar
Liked: 2269
Here's a snapshot from my X8500H. Sorry for the poor quality.
Pete7874 likes this.
post #4307 of 5003 Old 07-24-2019, 05:36 PM
osu fan's Avatar
Quoted: 40 Post(s)
Liked: 90
Originally Posted by pete7874 View Post
i've been trying to find an image of what the denon volume display on a tv screen looks like. The only thing i was able to find is the photos in this older thread that pertains to avr-3310ci/990, so obviously ancient history.
What does it look like on these newer s and x series receivers?
osu fan is offline
post #4308 of 5003 Old 07-24-2019, 08:53 PM
sd13's Avatar
Liked: 1074
When I’m watching tv and dynamic volume is turned off, I need to turn it to 50-60 out of 100 to hear any kind of sound. When playing music I can hear sound even at 10-20.
sd13 is online now
post #4309 of 5003 Old 07-24-2019, 09:02 PM
Mactavish's Avatar
Quoted: 133 Post(s)
Liked: 129
Is your TV connected by an HDMI or OPTICAL cable?
I’m connected via optical, and I have to raise my volume a lot for OTA TV. All my other sources are HDMI, average about -20db, for TV, I’m at -8db.
AVR: Denon X3500H
post #4310 of 5003 Old 07-24-2019, 09:04 PM
sd13's Avatar
Liked: 1074
Hdmi but what is very strange is that’s when I’m playing music, dynamic volume off and light have similar volume but when playing from the tv, the dynamic volume when turned to off is extremely mute.
sd13 is online now
post #4311 of 5003 Old 07-24-2019, 09:11 PM
Mactavish's Avatar
Quoted: 133 Post(s)
Liked: 129
I have very uneven results when at late night I try Dynamic Volume. That’s the only time I’ve tried using it, otherwise it’s always off.
AVR: Denon X3500H
post #4312 of 5003 Old 07-24-2019, 09:17 PM
sd13's Avatar
Liked: 1074
Something is definitely not right on mine. I shouldn’t have to crank it to 70-80 for normal listening. It’s been a frustrating experience so far as I’ve had much better sound from my previous Sony receiver.
sd13 is online now
post #4313 of 5003 Old 07-24-2019, 09:22 PM
Madmax67's Avatar
Liked: 2474
Ok. Well first off the Absolute scale goes to 98 not 100 but that's still a too high listening level for anyone listening above 80dB. Those ranges you list are normal listening levels based on others feedback in the past here. They'll get louder faster as you raise the volume but best to stay at or under 80 if possible. As far as just hearing music sources at 10 or 20 doesn't tell me much. I can hear music a bit as background at 20 but almost not at all at 10. Just hearing it isn't the comparator. At what levels with similar settings do both sound exactly the same? If that's a bit lower for music over movies then it's probably source and content dependent. How large is your space in cubic feet and how far away are you sitting from the main speakers? Also what make and model of speakers do you have in your front soundstage?
Madmax67 is offline
post #4314 of 5003 Old 07-24-2019, 09:27 PM
sd13's Avatar
Liked: 1074
Ok. Well first off the Absolute scale goes to 89 not 100 but that's still a too high listening level for anyone listening above 80dB. Those ranges you list are normal listening levels based on others feedback in the past here. They'll get louder faster as you raise the volume but best to stay at or under 80 if possible. As far as just hearing music sources at 10 or 20 doesn't tell me much. I can hear music a bit as background at 20 but almost not at all at 10. Just hearing it isn't the comparator. At what levels with similar settings do both sound exactly the same? If that's a bit lower for music over movies then it's probably source and content dependent. How large is your space in cubic feet and how far away are you sitting from the main speakers? Also what make and model of speakers do you have in your front soundstage?
Music with volume at 20 is about equal to tv at volume 65. This is with dynamic volume turned off for both. I’m about 8 feet from the receiver and my space is about 12x25. I have Martin Logan motion 4i speakers.
sd13 is online now
post #4315 of 5003 Old 07-24-2019, 09:29 PM
Madmax67's Avatar
Liked: 2474
There are source specific level settings under option->channel level adjust that can be boosted up to 12dB. Adjust them per source until they all match. Varying source levels is a common issue.
Madmax67 is offline
post #4316 of 5003 Old 07-24-2019, 09:34 PM
Madmax67's Avatar
Liked: 2474
Got it. Something else is up then. That's not normal. 20 should be a whisper and 65 should sound fairly loud. You're on the default volume level setting right? 0-98. I got the max limit backwards earlier in that mode. Mines -18 to 80(mute) using the optional Relative scale.
Madmax67 is offline
post #4317 of 5003 Old 07-24-2019, 10:00 PM
Madmax67's Avatar
Liked: 2474
@sd13 Those 4i's are actually designed more for on wall side surround use. 4 Ohm and 90dB sensitive should be able to get fairly loud at 8 feet but they aren't even a full sized bookshelf speaker. That's the only other thing I can think of short of rerunning Audyssey in case something didn't get set correctly level wise or a defect with the receiver itself. Wish I had more for you.
Madmax67 is offline
post #4318 of 5003 Old 07-24-2019, 10:20 PM
sd13's Avatar
Liked: 1074
Yes it is on default 0-98
I did not have the issue with my Sony 1080. It got way louder at lower volumes. Sound was richer and less tinny as well and bass was much tighter.
sd13 is online now
post #4319 of 5003 Old 07-24-2019, 11:25 PM
355F1's Avatar
Quoted: 164 Post(s)
Liked: 35
Does the amp start distorting once you go over 0db (reference level) on volume?
😎It's just life, dude. We are all gonna die sometime--Might as well try and have a kickass time while we're still here.😜
355F1 is offline
post #4320 of 5003 Old 07-25-2019, 12:25 AM
fulano's Avatar
Quoted: 57 Post(s)
Liked: 39
Am I correct in assuming you don't want to turn off the volume on the on-screen display?
Vizio E-701i, Denon X4500H, Crown XLS-1502, Polk Monitor 70s, Polk CS2 II, Polk T15s, Klipsch RIC-65, Tivo Roamio OTA, LG BD570, Fire TV 1, Fire TV Stick 4K, XBox 360, Harmony Smart Control
fulano is offline
calibrate , dali alteco , Denon , denon 4500h , denon avr-x4500h , denon x3500 , earc , heco victa 500 , lg b8 , onkyo ts-xr507 , sound , speakers , tear ax3000 , testing
