"OFFICIAL" 2018 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8) - Page 155 - AVS Forum | Home Theater Discussions And Reviews
 2480Likes
post #4621 of 4922 Old 08-22-2019, 08:01 PM
Pete7874's Avatar
Quoted: 252 Post(s)
Liked: 141
Originally Posted by Mactavish View Post
I use the web interface often, even though many times it does not 100% accurately show the REAL settings, even after a browser refresh, not sure why
Just curious, which settings show inconsistencies through the web interface?
So far I haven't come across any, but mine has fewer bells and whistles than yours.
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Samsung UN55B7100  Denon AVR-S740H  Chane A2.4  Dayton MK402X  Premier Acoustic PA120  Roku Premiere Plus  Squeezebox Classic  CCA
Pete7874 is online now
post #4622 of 4922 Old 08-23-2019, 01:27 AM
CBdicX's Avatar
Quoted: 1631 Post(s)
Liked: 385
Hi, i have the X4500H, but are there, or will there be models that support Front Wide (again) ?
(prevered with all the X4500H "stuff")
CBdicX is offline
post #4623 of 4922 Old 08-23-2019, 09:05 AM
Quoted: 73 Post(s)
Liked: 8
HiAll...
It was just mentioned on another forum that my x3500h cannot do 4k out of Zone 2. Is that the case? If it can, what about HDR, Dolby Vision, etc?
Rich428 is offline
post #4624 of 4922 Old 08-23-2019, 11:15 AM
Mactavish's Avatar
Quoted: 132 Post(s)
Liked: 128
Sorry, I didn’t keep good notes. One issue was the LFE kept showing as 120 under web interface, even though it was set at 80, and shows 80 in the Denon menu on TV screen, (I only rely on the Denon menu for 100% accuracy. I kept trying to change the LFE to 80 in web interface, but it would not stick. Back in Denon menu, I changed LFE from 80 to 120, then back to 80, now showing properly in web page. So that’s one example, but does not inspire total confidence. There were a few other small items, but the main point for me is to only really trust the Denon menu for settings confirmations. The info in the Heos app showing your DynamicEQ status is also flaky in the same way, I have to switch to a different input and then back for it to update and show the actual setting. Little things that hopefully get ironed out eventually.
HDTV: Panasonic P55VT50 Plasma
AVR: Denon X3500H
SPEAKERS: Ohm (mains), Chane 2.4 (center), Rythmik F12G (sub), DefTech ProMonitor 80 (sats)
MEDIA PLAYER: Oppo BD83
Mactavish is offline
post #4625 of 4922 Old 08-23-2019, 11:25 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 22380 Post(s)
Liked: 12179
Originally Posted by Rich428 View Post
HiAll...
The Zone 2 HDMI monitor output is simply a pass through, so AFAIK, no reason that a 4k source cannot pass to it if there is a 4k TV/PJ as the display.
jdsmoothie is offline
post #4626 of 4922 Old 08-23-2019, 11:27 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12179
The only current Denon/Marantz AVR that supports Front Wide is the "flagship" Denon X8500H. Haven't heard about any future models supporting Front Wide, certainly not any of the 2019 models.
post #4627 of 4922 Old 08-23-2019, 11:30 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12179
Originally Posted by grajasekar View Post
Is this still a good time to get a X3500H? I'm unlikely to need more than 2 Atmos speakers, but I'm worried that the HDCP 2.2 on the 3500 will be a limiter compared to HDCP 2.3 on the 3600H, and that somehow the 3600H will get an update to HDMI 2.1 proper.
On that note, I wish I could get the best deal on this, but I can't message @jdsmoothie given I don't have enough posts and have spent years just reading up here
No more X3500H in stock, rather only the X3600H which will NOT be updated to HDMI 2.1, rather only it's successor the X3700H (summer 2020) is likely to be the first model with HDMI 2.1.
post #4628 of 4922 Old 08-23-2019, 11:35 AM
Pete7874's Avatar
Quoted: 252 Post(s)
Liked: 141
I tried to replicate this issue, but on my end everything seems to be working as expected. No inconsistencies. Either Denon fixed it in the latest firmware release, or it only affects certain models.
post #4629 of 4922 Old 08-23-2019, 12:02 PM
grajasekar's Avatar
Quoted: 14 Post(s)
Liked: 7
Thank you, I'll reach out to you. This makes it a bit more clear, since the only thing I'd gain really from going to the 3600 (that might matter to me 3-4 years down the line) is the extra channels.
grajasekar is offline
post #4630 of 4922 Old 08-24-2019, 05:05 AM
jayw's Avatar
Quoted: 24 Post(s)
Question Firmware Update - Not working
If this has been answered, sorry I couldn't find it.
My X3500H has a firmware update available. But when I try to update it turns off and never finishes. I've tried several times.
Symptoms: See new firmware.
Go to Settings-> General -> Check for Update
Says "This update improves overall performance and stability. Estimated time to install 13 mins" I click on Update Now
Get a screen that says "Your AVR will turn off during the update then restart when the update is complete and HEOS devices on your network will stop playing audio. Do you want to continue with the update." I click on "Update" and the receiver turns off. Never to return. I left it alone all night last night. The only way to get it back is to pull the power plug. Front panel switch and remote are unresponsive.
Sorry for the long post, but I'm stumped. Anyone know what I should do at this point?
TIA,
Jay
Check here later for a thoughtful, funny, profound .sig line.
jayw is offline
post #4631 of 4922 Old 08-24-2019, 08:25 AM
Djuganight's Avatar
Quoted: 57 Post(s)
Liked: 4
Just received a firmware upgrade version
2461-9110-1131-0025 on my X4500.
Anyone knows where to get the respective changelog?
Djuganight is offline
post #4632 of 4922 Old 08-24-2019, 08:32 AM
Pete7874's Avatar
Quoted: 252 Post(s)
Liked: 141
I'm afraid the best you can hope for is here:
https://www.avsforum.com/forum/90-re...l#post56087614
post #4633 of 4922 Old 08-24-2019, 08:38 AM
Quoted: 1044 Post(s)
Liked: 273
Bug fixes and stability improvements
Sent from my GM1915 using Tapatalk
Brian_Barros is offline
post #4634 of 4922 Old 08-24-2019, 08:42 AM
Djuganight's Avatar
Quoted: 57 Post(s)
Liked: 4
post #4635 of 4922 Old 08-24-2019, 10:32 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12179
TIA,
Jay
Refer to post 4 and do a "Restart."
post #4636 of 4922 Old 08-24-2019, 10:51 AM
maphiker's Avatar
Quoted: 14 Post(s)
Originally Posted by dfa973 View Post
The last 21 August firmware update has completed the Web control interface, adding the last missing HEOS section - or I was dreaming and it was added by a prior update?
I certainly hope Denon has not completed the Web control.
Am I missing something? I was expecting a full Web control. While, yes, the Web control on my AVR-X6500H does allow to make some setup changes. It lacks some very basic controls. I see no option to change the volume or change surround modes for example.
Does anyone know if these controls will be added by a firmware option or is this as good as it gets?
Thank for your reply.
maphiker is offline
post #4637 of 4922 Old 08-24-2019, 11:21 AM
Mactavish's Avatar
Quoted: 132 Post(s)
Liked: 128
The various playback modes are accessed in the HEOS app, the web control is the almost the same information as you can access via the remote “Setup” button and viewed on you connected HDTV.
AVR: Denon X3500H
post #4638 of 4922 Old 08-24-2019, 01:24 PM
jayw's Avatar
Quoted: 24 Post(s)
Thanks. I just tried it. It wouldn't restart until I pulled the power first. Then I plugged it in, put it in standby and did a restart. I am trying the firmware upgrade again, but it shut down immediately. You saying it's going to come back this time? So far, no joy.
NOTE: When it goes to start the update it shuts all the way down, not to Standby mode. (no red light.)
jayw is offline
post #4639 of 4922 Old 08-24-2019, 01:53 PM
sd_smoker's Avatar
Quoted: 30 Post(s)
So my primary source is my HTPC and I'm having some issues with HDMI passthrough. I set the AVR's 4k format to "Enhanced", but I still can't pass through 4k @ 60Hz. It will sometimes let me do 60Hz with YCbCr 4:2:0, but I'd ideally like to run RGB Full @ 60Hz. I'm using Monoprice Certified Premium cables, so I wouldn't think that's the issue. Do I need to bite the bullet and get the Belkin cable or is there something else I'm missing?
Vizio P75-F1 | Denon AVR-S740H | Dayton B652-AIR/C452-AIR L/C/R | Boston VRS Micro Surrounds | Dayton Sub-1200 | HTPC (Win10, Red Dragon RX 5700 XT, Kodi, MPC-HC/MadVR) | PS4 | XBone
sd_smoker is offline
post #4640 of 4922 Old 08-24-2019, 04:16 PM
Scrawner's Avatar
I noticed one nice fix after updating - volume control now works MUCH better from IOS HEOS and airplay. Previously it was very slow to respond and would move erratically when changing volume from phone.
dfa973 likes this.
Scrawner is offline
post #4641 of 4922 Old 08-24-2019, 06:14 PM
musicman0725's Avatar
Quoted: 74 Post(s)
Liked: 108
Some TV's have a similar setting that also needs to be enabled. For instance, Samsung has a setting called HDMI UHD Color that needs to be enabled to get full 4:4:4 60hz chroma.
Samsung UN55KS8000 | Denon AVR-X4500H | AppleTV 4K | DirecTV HR54 + 4K RVU | Samsung UBD-M8500
Samsung UN55HU8550 + SEK-4500/ZA | Samsung Soundbar HW-H550 | AppleTV 4K | DirecTV C41W | Samsung UBD-K8500
Samsung UN32EH4003 | AppleTV 4th Gen | DirecTV C41W
musicman0725 is online now
post #4642 of 4922 Old 08-24-2019, 06:19 PM
maphiker's Avatar
Quoted: 14 Post(s)
Thanks for your reply. I do realize volume and playback modes can be accessed in HEOS app, also the Denon app as well as the remote control. But I would like to be able to access these controls from a web browser. Seems it should be easy enough to achieve if one is familiar with the code. I know it can be done by sending RS-232C/IP commands but that is exceedingly tedious.
Does anyone know of a program that can be automated to send ip commands to to the AVR?
maphiker is offline
post #4643 of 4922 Old 08-24-2019, 06:28 PM
sd_smoker's Avatar
Quoted: 30 Post(s)
Should have mentioned that I have Full UHD Color enabled on my TV.
post #4644 of 4922 Old 08-24-2019, 06:32 PM
hungryJonJon's Avatar
I helped a neighbor purchase a Denon S540BT and install/hookup went fine as expected. However, I seem to be unable to program their Verizon STB remote to control power/volume on the S540BT.
Per the below Verizon support link these are the codes that should work and none of them do. Does anyone happen to know of other codes or what code will work for the S540BT? Oddly, I can't seem to find any other posts or sites even suggesting issues with finding the correct code.
Code:
1387, 3602, 3633, 3662, 3663, 3676, 3681, 3682, 3691, 3694, 3700, 3702, 3703, 3704, 3709, 3721
https://www.verizon.com/support/resi...r-remote-codes
hungryJonJon is offline
post #4645 of 4922 Old 08-24-2019, 06:36 PM
Pete7874's Avatar
Quoted: 252 Post(s)
Liked: 141
Code:
Maybe try one of the codes listed here:
https://codesforuniversalremotes.com...dio-receivers/
post #4646 of 4922 Old 08-24-2019, 07:28 PM
Quoted: 74 Post(s)
Liked: 108
Does it work when you bypass the AVR and connect directly to the TV? Also, is the cable from the AVR to the TV also premium certified and do other sources work with 4:4:4 chroma?
post #4647 of 4922 Old 08-24-2019, 11:35 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12179
Not necessarily, rather simply a "Restart" is the first step towards trying to resolve the issue. Next step is doing a "Network reset".
post #4648 of 4922 Old 08-24-2019, 11:46 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12179
Code:
Here are some additional 4 digit codes to try --> 0145 1342 1544 1486 1135 5012 5019 5028 5060 1053
Otherwise, another option is to purchase a universal remote (eg. Harmony) which could likely control all of the devices in the setup to include the STB and AVR.
Madmax67 likes this.
post #4649 of 4922 Old 08-25-2019, 01:41 AM
Djuganight's Avatar
Quoted: 57 Post(s)
Liked: 4
Found changelog on another forum:
https://denon-uk.custhelp.com/app/an...tail/a_id/3832
The update for spotify free account is really great
SoCalGuy-99 and musicman0725 like this.
post #4650 of 4922 Old 08-25-2019, 05:00 AM
chi_guy50's Avatar
Quoted: 2219 Post(s)
Liked: 2263
I am with you. The Web Control as presently constituted is all but worthless to me as it lacks most of the functionality that was available in previous model years.
I understand the diversion of emphasis to mobile apps, but Denon might as well not have reintroduced Web Control if they do not intend to bringing back those missing features.
Living Room: Sony XBR-65Z9D; Oppo UDP-203; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H (9.1.4/13.1); Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929, DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is offline
calibrate , dali alteco , Denon , denon 4500h , denon avr-x4500h , denon x3500 , earc , heco victa 500 , lg b8 , onkyo ts-xr507 , sound , speakers , tear ax3000 , testing
