"OFFICIAL" 2018 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8) - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 3754Likes
post #31 of 8553 Old 04-27-2018, 12:22 AM
Liked: 0
Originally Posted by KD5MDK View Post
The easy answer is to wait until the X6500 is announced or at least clearer
Fair enough - but any idea when this is the case, based on previous years?
sw_wieschnee is offline
post #32 of 8553 Old 04-27-2018, 12:23 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 24660 Post(s)
Liked: 13873
July/August
jdsmoothie is offline
post #33 of 8553 Old 04-27-2018, 06:48 AM
dfa973's Avatar
Quoted: 1381 Post(s)
Liked: 1434
How the 2018 X series front panel looks:
In attached image the AVR-X1500H receiver.
Zoland2020 likes this.
dfa973 is online now
post #34 of 8553 Old 04-27-2018, 07:27 AM
Cleveland Plasma's Avatar
Quoted: 7652 Post(s)
Liked: 7714
Cleveland Plasma is offline
post #35 of 8553 Old 04-27-2018, 10:05 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13873
Although there were some changes in the layout of the front panel on the "S" series models especially, there was no addition or subtraction of inputs/buttons.
post #36 of 8553 Old 04-27-2018, 02:29 PM
jsmiddleton4's Avatar
Quoted: 1038 Post(s)
Liked: 374
Gotta have the door.....
Matt2026 likes this.
jsmiddleton4 is offline
post #37 of 8553 Old 04-28-2018, 06:50 AM
Liked: 374
I am most likely going to replace my X4200 this go round. Not 100% sure. IF I do it will be very hard to pick between the 2018 Denon's and Yamaha's. Seeing some stuff here and there about the xx80's that you know are coming....
Pioneer used to be in the mix but for me no longer.
Need to see how the DV pass through firmware works out on the X4200 first.
post #38 of 8553 Old 04-29-2018, 12:52 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13873
Still a few months away from the DV firmware release, although by then, the specs on the new X4500H should be released.
post #39 of 8553 Old 04-29-2018, 10:41 AM
Liked: 374
"specs on the new X4500H should be released."
If DV pass through works and already having an external amp they'd have to be really impressive to justify the upgrade.
post #40 of 8553 Old 04-29-2018, 10:46 AM
Selden Ball's Avatar
Quoted: 4823 Post(s)
Liked: 2874
For some people, having access to the receiver's Web page again might be worth the upgrade. It went away when HEOS was first added, but apparently is being restored in the 2018 models.
Selden
Selden Ball is offline
post #41 of 8553 Old 04-29-2018, 10:48 AM
Liked: 374
"access to the receiver's Web page again"
For the X4200? I have access via the web.
post #42 of 8553 Old 04-29-2018, 01:41 PM
Liked: 2874
For the Heos models. None of the xxxH devices allow access to the Web page (assuming it's actually there).
Selden
post #43 of 8553 Old 05-01-2018, 08:29 AM
vegout's Avatar
Quoted: 71 Post(s)
Liked: 41
I have a 3311ci now and trying to decide whether to upgrade to a refurb 4400H or wait for the new 3500H which are about the same price. I don't have the space for built-in Atmos speakers now but may in the future. From what I have read, up-firing speakers don't cut it.
vegout is offline
post #44 of 8553 Old 05-01-2018, 09:17 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13873
Depends on the height of and type of ceiling. CEDIA demos have proven that in some cases Dolby enabled speakers provide a very convincing height effect.
Also, review post 1 of this thread to determine if you want any of the newer features to be released on the X3500H.
vegout and bslep like this.
post #45 of 8553 Old 05-02-2018, 06:22 AM
vegout's Avatar
Quoted: 71 Post(s)
Liked: 41
Thank you for all of that great info. The only one feature that I care about is the ability to do menus over 4K.
Have there been any improvements with Denon or other brands to allow the option of hearing a different source than the video? I often watch sports and like to listed to music at the same time. I am aware of the workarounds to do this with my current Denon but would prefer a seamless method using the HDMI for video and another HDMI or the phono input for the audio.
vegout is offline
post #46 of 8553 Old 05-02-2018, 07:02 AM
Dan in St. Louis's Avatar
Quoted: 397 Post(s)
Liked: 326
I implemented this by programming the following code into my remote:
M = Mega, m = milli. K = Kelvin, k = kilo. B = Bytes, b = bits. G = Giga, g = gravity. Dan in Saint Louis
Dan in St. Louis is offline
post #47 of 8553 Old 05-02-2018, 07:10 AM
vegout's Avatar
Quoted: 71 Post(s)
Liked: 41
I have a Harmony Smart Hub and remote. I don't think I have that much flexibility or my 3311ci does not support it.
vegout is offline
post #48 of 8553 Old 05-02-2018, 10:00 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13873
The <Video Select> feature has been available for years that allows watching an HDMI video source and listening to a non-HDMI audio source (to include PHONO on those models with PHONO inputs or CD analog input for turntables with their own pre-amp or when using a 3rd party phono pre-amp). As all of the 2018 models (except the S540BT) now feature a PHONO input, the <Video Select> feature can be used with all models to listen to a turntable. To listen to an HDMI audio source, you would have to purchase an HDMI --> analog converter and purchase a S940H/X2500H or higher model.
vegout and Madmax67 like this.
post #49 of 8553 Old 05-02-2018, 12:42 PM
Liked: 0
The x2500H manual shows the additional video select source as being available for the PHONO input but does not show this as pre-defined input source on the input assign table, will this work once a chosen input has been renamed as 'PHONO'?
ds4130 is offline
post #50 of 8553 Old 05-02-2018, 12:58 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13873
An input cannot be reassigned as PHONO.
post #51 of 8553 Old 05-02-2018, 01:09 PM
Liked: 0
The PHONO input cannot be reassigned.
Thanks JD, knew I was missing something, my 2400 doesn't have PHONO...
ds4130 is offline
post #52 of 8553 Old 05-02-2018, 01:23 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13873
Correct. Until the release of these 2018 models, the PHONO input has only been featured on the X4000 series and higher models for the past 5 years.
post #53 of 8553 Old 05-02-2018, 01:31 PM
Liked: 0
Appreciate the fast reply!
Any idea on time frame for the x3500H release? About to pull the trigger on 3400 for my lounge but stumbled on the 2500 manual last night while hunting for the 3500 one, would quite like a read of it ASAP haha...
ds4130 is offline
post #54 of 8553 Old 05-02-2018, 01:51 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13873
July
post #55 of 8553 Old 05-03-2018, 07:22 AM
Liked: 374
Its great to see the PHONO inputs moving down the model chain. Now if those companies who indicated they were going to produce decent TT’s at a reasonable price point would actually do so......
post #56 of 8553 Old 05-04-2018, 01:32 PM
giomania's Avatar
Quoted: 921 Post(s)
Liked: 731
Whoops
giomania is offline
post #57 of 8553 Old 05-04-2018, 01:49 PM
giomania's Avatar
Quoted: 921 Post(s)
Liked: 731
If I need a cheap Dolby Atmos / DTS:X receiver to go with a new 4K TV, it looks like the options are below. This is for a family room, and I am currently running a Denon AVR3312CI, so I don’t need to spend a lot of money.
I see the 2018 options are:
- S740H - MSRP $479, 7.2 CH, 75W, HDMI In/Out (6.1) - avail April
Upgrading from the S640H adds a front HDMI input and two more audio channels for a 7CH model, Atmos/DTS:X 5.2.2, DTS:X. It features 5.1 + Zone 2 capability using the Surround Back speaker posts for Zone 2. There are no Zone 2 pre-outs. No noticeable difference in power. DTS Virtual:X (simulates height audio when using a 5.1 configuration but Audyssey is disabled).
- S940H - MSRP $579, 7.2CH, 90W, HDMI In/Out (8/2, main/main outputs) - avail April
Upgrading from the S740H adds 2 more HDMI inputs, 1 more main zone monitor output (eg. when using a TV and PJ), 2 component video inputs / 1 output, 4k/30Hz upscaling, on board. No noticeable difference in either power or audio quality.
Versus this 2017 option:
AVRS730H Sorry, the other thread didn’t have the specs where I could locate them easily, but I know it doesn’t display menus over 4K.
Sent from my iPhone using Tapatalk Pro
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is offline
post #58 of 8553 Old 05-04-2018, 02:06 PM
giomania's Avatar
Quoted: 921 Post(s)
Liked: 731
Cant edit the post for some reason, but...
Wanted to add I was thinking to stick with 7-channel. The 4 surround speakers are ceiling-mounted, and the L/C/R are on top of the wall unit, so practically on the ceiling.
giomania is offline
post #59 of 8553 Old 05-04-2018, 02:27 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13873
Huh? Post 1 of the 2017 Owner's thread provides the same info on those models as this thread provides on the 2018 models.
post #60 of 8553 Old 05-04-2018, 02:29 PM
giomania's Avatar
Quoted: 921 Post(s)
Liked: 731
Guess I did that too quickly...sorry
giomania is offline
11.2 , 2.1 , 2.2 , 7.2.4 , alexa , amazon music , avr , avr-x2500h , bluetooth headphones , calibrate , dali alteco , Dayton Audio , Denon , denon 3500 , denon 4500h , denon avr-x4500h , denon receiver , denon x3500 , dolby atmos , earc , heco victa 500 , heos , issue , Klipsch , lg b8 , onkyo ts-xr507 , oppo 203 , sound , speakers , svs pb-1000 , tear ax3000 , testing , wiring
