"OFFICIAL" 2018 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8) - Page 263 - AVS Forum | Home Theater Discussions And Reviews
 3672Likes
post #7861 of 8453 Old 05-25-2020, 11:10 AM
bluesky636's Avatar
Quoted: 356 Post(s)
Liked: 281
I am baffled by the complaints of Denon receivers running hot.
I have a 3500. Eco mode is turned off. All video processing is turned off. I listen/watch with a MV setting of -20dB to -15dB. Sometimes up to -12dB. I am retired and with the covid-19 virus, I watch TV/movies or listen to music for several hours in the afternoon and at night. The top of the AVR is slightly warm to the touch after a 2 hour movie, and in fact, feels cooler than the DISH satellite receiver with all its digital processing. There is no heat build up in my equipment rack and certainly no heat build up in our great room. In standby mode the AVR is cold.
I play electric guitar and build my own vacuum tube guitar amps. I have two 40 watt amps and two 5 watt amps. The 40 watts amps, when cranked, can easily raise the room temperature by about 5 degrees F.
Madmax67 and dfa973 like this.
Bill
bluesky636 is offline
post #7862 of 8453 Old 05-25-2020, 11:48 AM
Quoted: 69 Post(s)
Liked: 0
Does Denon's 4500 earc function work flawlessly? I want to buy a ps5 later this year and i would like to know if i should buy now a 4500 for a discounted price, so i can connect this through earc with a future 8k tv
Blade 77 is online now
post #7863 of 8453 Old 05-25-2020, 12:27 PM - Thread Starter
jdsmoothie's Avatar
Quoted: 24589 Post(s)
Liked: 13823
Originally Posted by eaayoung View Post
Quick question on setting up an old Onkyo TX-84 2 channel receiver for powering Zone 2 on my Denon 4500. I reviewed JD'S pages on this but not sure where I would plug the RCA cables from the Denon into the Onkyo receiver. I'm thinking any one of the Onkyo's play jacks would work. My on the TX-84 are Phono, CD, Tape 1 record and play, Tape 2 record and play, VCR 1/VDP record and plan or VCR 2.
No trigger plug in for this receiver. But it should work for my patio speakers until my backordered AudioSource amp is sent.
You can connect the RCA cables to any of the analog audio inputs on the Onkyo except PHONO although CD is likely least complicated.
eaayoung likes this.
jdsmoothie is offline
post #7864 of 8453 Old 05-25-2020, 12:29 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13823
Although your AVR only runs "warm to the touch", as a general rule, it's best not to stack anything (other than a fan) on top of the AVR to ensure for proper ventilation.
post #7865 of 8453 Old 05-25-2020, 12:41 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 2329
Sweet room and guitars!
System 1: Samsung Plasma | Denon X4500H | Hypex Ncore NC252MP | Buchardt S400 | Polk LSiM 702 F/X | Heights TBD | Subs TBD Rythmik
System 2: Laptop | NAD T758 v3 | PSB Imagine B
System 3: PC | Micca OriGen G2 | Mackie MR624
Soulburner is offline
post #7866 of 8453 Old 05-25-2020, 12:43 PM
Liked: 0
Originally Posted by daverph86 View Post
I do have Media Streaming turned on and can see the 4500h listed. In the app I choose Music-Music servers-(my computer name)-browse-music-folder-music and then see all of my subfolders. example Flac music, mp3 for car , etc. When I click on one of those say Flac I see all artists I have, then click on an artist and I see the albums I have and when I click on the album I get the "No Media" message on the app. Frustrating because I can drill down that far and it fails.
So, I figure I would go to Denon Customer Support and email the question to them. Surprise their support email isn't working and will not allow me to send my question. I am probably not doing something correct but it is frustrating.
daverph86 is offline
post #7867 of 8453 Old 05-25-2020, 12:43 PM
bluesky636's Avatar
Quoted: 356 Post(s)
Liked: 281
I have been stacking a blu-ray player on top of the 3500 since I purchased it last year. Prior to that I had a blu-ray player stacked on top of my old Onkyo AVR for years and never had a problem. The player sits on 1.5" feet and there is airflow all around the AVR and player.
I am not recommending that anyone else follow my example. I am merely presenting the fact that I have zero heating problems with my setup. If someone is claiming that enough heat is being generated to actually cause a noticeable increase in the air temperature of an entire room, they have a serious problem that no fan is going to correct.
Edit: Note that I said "slightly warm to the touch" as in negligible.
post #7868 of 8453 Old 05-25-2020, 12:46 PM
bluesky636's Avatar
Quoted: 356 Post(s)
Liked: 281
Thanks. I have a BSEE earned when vacuum tubes were still part of the curriculum. I know a little bit about heat transfer and cooling. 😉
post #7869 of 8453 Old 05-25-2020, 03:36 PM
b0rnarian's Avatar
Quoted: 2305 Post(s)
Liked: 1439
Originally Posted by chi_guy50 View Post
Originally Posted by b0rnarian View Post
Guess I shouldn't say Hot, more like warm to the touch. Though the green power light and red B side button is always On so I was wondering if its actually running all the time. I will see if the unit has trigger option, I dont think it does though as the power button is a push button so the unit won't shut off properly unit the button is manually pushed I suppose.
The AudioSource AMP-100, unlike its successor AMP-100VS model, does not have a trigger option. But it does offer a switchable auto-on function. There is a AUTO ON toggle switch on the back of the unit: In the AUTO position, this switch will use signal sensing to power on the amp assuming that the power button on the front panel is kept in the ON (pushed in) position; the other switch position is labeled NORMAL and reflects manual on/off operation by means of the front panel power button.
However, in my experience signal sensing with this amp does not always work well for height speakers given the tenuous nature of the overhead signals in many audio codecs. When I was using this amp, I found it preferable to keep it powered on constantly except during periods of prolonged non-usage. The amp's extremely low power consumption when idle means that there is not much of a conservation factor to worry about, and the heat generation should be very minimal.
Otherwise, there are other solutions you could employ, such as a smart power strip with the AVR as the master.
You are right on point! Though I tried setting it to auto and no signal or even playing atmos content didnt wake up the amp so I go bk to leaving it at normal and always powered on. Silver lining is i do notice the unit being less warm when not in use. Guess thats how it'll have to be. TY!
LG 77C9PUB + Denon X4500H (11.2) + OPPO 203 + PS4 + Roku
Disc Lot For SALE : HERE!
b0rnarian is offline
post #7870 of 8453 Old 05-25-2020, 04:40 PM
Quoted: 56 Post(s)
Hi everyone,
I have a really simple question I know that been asked and explained alot here but I really searched for it using google but still not sure what I found is right ... when watching movies should I use direct ot auto mode ? I have been using auto until a friend told me that the auto alter and change the real experience intended by the movie mixer but what I did understand from the manual and the searching that is not totally true since using direct mode will totally disable audyssey and that not right and auto should be used so could you please confirm it to me ... thanx
dabdoub81 is offline
post #7871 of 8453 Old 05-25-2020, 04:44 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13823
Originally Posted by dabdoub81 View Post
Hi everyone,
Using either DIRECT/PURE DIRECT will disable Audyssey and bass management.
Using AUTO will not.
Continue using AUTO or select sound mode directly using MOVIE - (Surround mode) as either one keeps Audyssey and bass management enabled.
post #7872 of 8453 Old 05-25-2020, 05:53 PM
Pete7874's Avatar
Quoted: 472 Post(s)
Liked: 504
Where exactly are you touching it?
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Samsung UN55B7100  Denon AVR-S740H  Chane A2.4  Dayton MK402X  Premier Acoustic PA120  Roku Premiere Plus  Squeezebox Classic  CCA
Pete7874 is offline
post #7873 of 8453 Old 05-25-2020, 06:15 PM
Madmax67's Avatar
Quoted: 2526 Post(s)
Liked: 2825
I have a similar 1.5 inch air gap above my X4300H and it's also only cool to slightly warm to the touch. My last receiver lasted 12 plus years in the same location. I was slightly worried with the newer receivers having HDMI boards and more bells and whistles inside but no. Still very little heat production coming from the top. Mines open totally on both sides though.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is online now
post #7874 of 8453 Old 05-25-2020, 06:19 PM
Madmax67's Avatar
Liked: 2825
He's an EE so my guess is he's checked everywhere.
post #7875 of 8453 Old 05-25-2020, 06:23 PM
Pete7874's Avatar
Quoted: 472 Post(s)
Liked: 504
At -20 dB MV, my S740H generates decent amount of heat, alas, it is driving two very inefficient (84 dB) 4 Ohm L/R speakers, so I am not surprised.
Pete7874 is offline
post #7876 of 8453 Old 05-25-2020, 06:26 PM
bluesky636's Avatar
Quoted: 356 Post(s)
Liked: 281
Without removing the blu-ray player my fingers can reach to the middle of the top, about above where the video card is.
The side vents are cool to the touch.
post #7877 of 8453 Old 05-25-2020, 06:37 PM
Madmax67's Avatar
Liked: 2825
The OP is talking about the heat at idle meaning no load on the amps.
post #7878 of 8453 Old 05-25-2020, 06:38 PM
bluesky636's Avatar
Quoted: 356 Post(s)
Liked: 281
I believe it has been stated that the main heat source is the video and hdmi cards.
post #7879 of 8453 Old 05-25-2020, 06:42 PM
bluesky636's Avatar
Quoted: 356 Post(s)
Liked: 281
Sorry. I find that hard to fathom unless there is a serious defect. AVR is heating up the room? If that were true I would shut it down and send it in for service.
Some photos of the room and equipment setup would be useful.
post #7880 of 8453 Old 05-25-2020, 06:44 PM
Madmax67's Avatar
Liked: 2825
That was my take as well. Soulburner has a pic of his setup in the Rythmik thread I believe. Last few posts as I hang out there as well.
post #7881 of 8453 Old 05-25-2020, 07:15 PM
Pete7874's Avatar
Quoted: 472 Post(s)
Liked: 504
He stated it was after a 2 hour movie watched at -20 to -15 dB.
Pete7874 is offline
post #7882 of 8453 Old 05-25-2020, 07:19 PM
Pete7874's Avatar
Quoted: 472 Post(s)
Liked: 504
My S740H isn't doing any video processing, AFAIK.
At -35 dB, there isn't any heat, but at -20 to -15 dB, it starts to get fairly warm.
Pete7874 is offline
post #7883 of 8453 Old 05-25-2020, 07:20 PM
bluesky636's Avatar
Quoted: 356 Post(s)
Liked: 281
I can watch a 2 hr movie at MV of -20 to -15 db and my 3500 is barely warm. System is 7.1 with 8 ohm Polk speakers and HSU sub.
post #7884 of 8453 Old 05-25-2020, 07:21 PM
bluesky636's Avatar
Quoted: 356 Post(s)
Liked: 281
Photo of your equipment setup please.
post #7885 of 8453 Old 05-25-2020, 07:28 PM
bluesky636's Avatar
Quoted: 356 Post(s)
Liked: 281
I looked at the last 5 pages and found nothing. If you have a link ....
post #7886 of 8453 Old 05-25-2020, 07:32 PM
Madmax67's Avatar
Liked: 2825
Post #43487 on my Tapatalk app. Literally 9 posts up from the last on. The receiver is sitting on a carpeted floor as he's looking for stand recommends there.
post #7887 of 8453 Old 05-25-2020, 07:39 PM
Madmax67's Avatar
Liked: 2825
You're cherry picking one thing he said then. He said to me repeatedly in thread it was hot to the touch at idle and the room was noticeably hotter the minute he entered the room. That's the main reason he's so concerned about it. We went back and forth discussing said idle current as well.
Cam1977 likes this.
post #7888 of 8453 Old 05-25-2020, 07:41 PM
Cam1977's Avatar
Quoted: 3364 Post(s)
Liked: 4146
I just ordered the aircom s8 to pair with my 4500h for piece of mind. The reciever has 4 inches of clearance on top and is open on the sides but still gets pretty warm to the touch.
musicman0725 likes this.
Cam1977 is online now
post #7889 of 8453 Old 05-25-2020, 07:45 PM
Madmax67's Avatar
Liked: 2825
For edification is this at idle with no load on the amps? If so you should first try engaging Eco Auto mode.
post #7890 of 8453 Old 05-25-2020, 07:47 PM
Cam1977's Avatar
Liked: 4146
^I've never left it at idle. It gets warm when watching movies or streaming...I dont think it's anything out of the ordinary.
I don't use eco mode.
11.2 , 2.1 , 2.2 , 7.2.4 , alexa , amazon music , avr , avr-x2500h , bluetooth headphones , calibrate , dali alteco , Dayton Audio , Denon , denon 3500 , denon 4500h , denon avr-x4500h , denon receiver , denon x3500 , dolby atmos , earc , heco victa 500 , heos , issue , Klipsch , lg b8 , onkyo ts-xr507 , oppo 203 , sound , speakers , svs pb-1000 , tear ax3000 , testing , wiring
