"OFFICIAL" 2018 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8) - Page 268 - AVS Forum | Home Theater Discussions And Reviews
 3672Likes
post #8011 of 8453 Old 05-31-2020, 12:55 PM
fatherom's Avatar
Quoted: 640 Post(s)
Liked: 290
Yes. Simply set Audyssey to OFF.
Sorry, where is that setting? When I bring up Audio->Audyssey, I don't see an Off.
Theater 1: LG OLED55E6P, Oppo UDP-203, Apple TV 4K, Dune HD Solo 4K
Theater 2: Sony VPL-VW885ES, Seymour Premier 16:9 128", Lumagen 4242, Oppo 103D (CFW) & 203, Apple TV 4K, Sony MDR-DS7500 Wireless Surround Headphones & Denon AVR-X6500H (7.2.4)
fatherom is online now
post #8012 of 8453 Old 05-31-2020, 12:59 PM - Thread Starter
jdsmoothie's Avatar
Quoted: 24588 Post(s)
Liked: 13822
p. 185 Owner's manual
jdsmoothie is offline
post #8013 of 8453 Old 05-31-2020, 01:24 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13822
Originally Posted by Waylo View Post
Hi everyone,
I'm preplanning a home theater setup. At a prelim glance, it looks like the S750H may satisfy my needs.
I will need 2 zones for audio output. 1 zone will have 4 speaker outputs for a limited surround sound experience, the second zone is for music in another room. Obviously I can also send out stereo music to all 6 speakers simultaneously.
My main question is regarding the direction of HDMI hookups for proper AV passthrough.
My primary AV source will be an Nvidia Shield to output digital AV to my TV.
Can I connect the Nvidia Shield output HDMI directly to the Denon first to deliver the audio, with the receiver then passing through the video through an HDMI out?
Or, do I need to connect the Nvidia Shield AV output HDMI first to the TV, with the TV then sending the audio passthrough back to the receiver through another HDMI or optical out?
Or would both scenarios work equivalently?
Oops! Wrong thread. This is for discussion of the 2018 models. Please repost in the 2019 AVR Owner's thread.
https://www.avsforum.com/forum/90-re...sts-1-8-a.html
post #8014 of 8453 Old 05-31-2020, 01:32 PM
Waylo's Avatar
Quoted: 29 Post(s)
Thanks, deleted and moved to proper thread.
Server: SageTV 9.2.2 on Windows 7 x64 Pro, Core 2 Quad Q6600, 4gb RAM, OpenDCT
Display: Fanless GT 1030 to Sony LED TV via DVI-HDMI
Audio: Logitech Z-5500 via Audigy 2
Capture Devices: HDHR Prime, HDHR for OTA, Comcast
Waylo is offline
post #8015 of 8453 Old 05-31-2020, 07:18 PM
PTAaron's Avatar
Quoted: 379 Post(s)
Liked: 464
Power off the AVR, TV, and PJ and unplug their respective power cables and HDMI cables for 10 minutes.
Swap the connections on the AVR ... HDMI Monitor 1 --> TV and HDMI Monitor 2 --> PJ and connect the power cables. Power on the TV, pause 5 seconds, PJ, pause 5 seconds, AVR, pause 5 seconds, source. If still no joy, time to introduce the splitter again.
Turns out I’m just dumb. I had the second tv plugged into “zone 2” not “monitor 2”... which explains why I had to turn on zone 2 for it to work. Wow.
Now I’ve got proper sound in the theater, and the other TV is showing a mirrored screen.
In my defense, I wasn’t looking at the back of the AVR when I hooked up the second TV... yeah that’s it.
mrtickleuk likes this.
-Aaron
English Way Cinema and Bar - moving on to v3.0... projector time in 2017!
PTAaron is offline
post #8016 of 8453 Old 05-31-2020, 07:23 PM
Madmax67's Avatar
Quoted: 2526 Post(s)
Liked: 2825
Is there a way to temporarily turn off all audyssey correction? I want to do a subwoofer crawl and want the denon as flat as possible (I plan on running a new calibration after I've moved the sub, but that may be weeks away)
MULTEQ Reference/Flat/Off
fatherom and dfa973 like this.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #8017 of 8453 Old 06-01-2020, 06:20 AM
mborner's Avatar
Quoted: 118 Post(s)
Liked: 34
Dynamic Volume both attenuates loud explosions/bangs as well as boosts lower level dialog so is similar to "night mode".
Thanks, jd. So does this mean that the Dynamic Volume setting does the exact same thing as the Dynamic Compression setting? Or should my question be, what is the difference between Dynamic Volume and Dynamic Compression? It appears that the surround mode might have something to do with it.
mborner is offline
post #8018 of 8453 Old 06-01-2020, 08:20 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13822
Dynamic Compression is a legacy feature mostly applicable to DD audio (but also DTS) which can be set to OFF if using Dynamic Volume.
post #8019 of 8453 Old 06-01-2020, 09:52 AM
neurot's Avatar
Quoted: 26 Post(s)
Denon x4500h Atmos + Zone2 issue
I have just upgraded from Pioneer Elite SC-61 to the Denon x4500h. I have a zone 2 stereo pair on the deck, and just had 4 x atmos speakers installed in the ceiling. I have Definitive Technology center, fronts with built in subs, bipolar surrounds, and the new 4 ceiling speakers. No rear surrounds planned.
Where I apparently went wrong is that it seems that with this receiver I just bought, I cannot use the Zone2 function since I have atmos speakers. When I bought the receiver a couple of weeks ago, before the atmos speakers were installed, I configured the zone2 to be connected to the rear surround output. But now that the atmos speakers are installed, I apparently can't use the rear surround for that function. I'm really disappointed, and it seems that I now have to buy a two channel amp and use pre-out. Can someone confirm this?
Also, we pretty much never care to have the same thing playing in both places, and just want the outdoor speakers to be used for listening to music by the pool. That being said, maybe I'm better off buying a completely separate 2 channel device (amp, receiver??) that has airplay capability and can be selected, instead of having to choose the receiver, then choose the zone, and all that nonsense. In fact, maybe I prefer that since there were a couple of times where we were blasting music outside without realizing it, since the zone was turned on. Any recommendations on that topic?
neurot is offline
post #8020 of 8453 Old 06-01-2020, 10:37 AM
flmiami's Avatar
Liked: 24
Originally Posted by chi_guy50 View Post
It was my recollection that the 4311 was a precursor to the flagship 7200, but yes, according to JDSmoothie, that remote will work with your 4500:
For your consideration... an alternative to backlit remote control:
I have the AVR-X4500H with its standard remote control, and I have added led light strips to the back of my TV which give it a nice glow in the dark, and it allows me to see all the remote controls' keys quite well (AVR, Roku, Tivo, TV, etc).
So, if this is of interest for you, you can order them from Amazon and experiment with them.
https://www.amazon.com/s?k=led+strip...diversity_2_17
I hope this helps. Good luck.
Keep it cool. HT room: L11 x W18 x H8 feet (1584 cuft)
AV Equipment: AVR: Denon X4500H | 5.2 configuration | Speakers: Athena: 2 AS-F1 fronts, 1 AS-C1 center, 2 AS-B1 surrounds | Subwoofers: 2 SVS SB-1000 | TV: Vizio 4K M70D3 |
In another room: Denon AVR-X4000 | Def. Tech. SSA-42 and SM350 | Athena AS-P6000 subwoofer | TV Samsung 58" 1080P Plasma |
flmiami is online now
post #8021 of 8453 Old 06-01-2020, 10:46 AM
chi_guy50's Avatar
Quoted: 2400 Post(s)
Liked: 2511
Originally Posted by flmiami View Post
For your consideration:
I have the AVR-X4500H with its standard remote control. However, I do not miss a remote control with backlight since I've attached led light strips to the back of my TV which give it a nice glow in the dark.
I hope this helps.
I assume you meant to direct your comment to the OP to whom I was responding. I myself have the X8500H w/backlit remote. But then I almost never use the OEM remote since I have a Harmony Elite (also backlit) that operates all of the gear in my setup.
Living Room: Sony XBR-65Z9D; Oppo UDP-203; TiVo Roamio Pro/DarbeeVision DVP 5000S; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H; Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55X950G,
Sony UBP-X800, TiVo Mini/DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is online now
post #8022 of 8453 Old 06-01-2020, 10:47 AM
flmiami's Avatar
Liked: 24
Yes, but my comments might be of interest for others. Apologies for posting it in the wrong place.
post #8023 of 8453 Old 06-01-2020, 11:27 AM - Thread Starter
jdsmoothie's Avatar
Liked: 13822
1. Confirmed. There are only 9 amps on board so if you use all 9 in the main zone for your 5.2.4 setup, you must use an external amp for Zone 2 and/or Zone 3.
2. Zone 2 can be powered on independently from the main zone using either the remote control or using the 2016 Denon AVR Remote app( ie. main zone can be off, except when using Airplay).
Review posts 1-8 on page 1 of this thread for additional helpful information.
post #8024 of 8453 Old 06-01-2020, 11:29 AM
avernar's Avatar
Quoted: 1244 Post(s)
Liked: 1512
Originally Posted by MRAYB View Post
....4311 to a 4400 here. A Harmony 650/665 is backlit Works great.
I blame you.
Name:	Photo 2020-06-01, 2 25 42 PM.jpg
Cam1977 and MRAYB like this.
avernar is online now
post #8025 of 8453 Old 06-01-2020, 12:17 PM
MRAYB's Avatar
Quoted: 547 Post(s)
Liked: 2244
Originally Posted by avernar View Post
I blame you.
Attachment 2735746
Good deal buddy. Since it's my fault, feel free to PM me if you need any help getting it going
Cam1977 likes this.
MRAYB is offline
post #8026 of 8453 Old 06-01-2020, 04:33 PM
Cam1977's Avatar
Quoted: 3364 Post(s)
Liked: 4146
^great im looking into it as well
MRAYB likes this.
Cam1977 is offline
post #8027 of 8453 Old 06-01-2020, 05:24 PM
gtsum's Avatar
Quoted: 66 Post(s)
Liked: 45
In use a harmony ultimate for years and they r so easy to program and use, I love them.
Sent from my iPhone using Tapatalk Pro
MRAYB and yllanos like this.
gtsum is online now
post #8028 of 8453 Old 06-01-2020, 09:20 PM
MRAYB's Avatar
Quoted: 547 Post(s)
Liked: 2244
Make the move, you won't be sorry. I hate having more than one remote. The 650/665 will do anything you ask of it. As long as you ask with the proper commands. Ignore the $189 price on Amazon that first pops up for a 650. They are becoming hard to come by. A 665 is the same, only black. Pick up a 665 for about $75 new (Amazon), or $40-60 used/refurbished on ebay. Check out the end of the Denon 2019 thread were I just helped a guy program (with screenshots) an unlimited number of QuickSelects from his Original remote to the Harmony. Good luck
Cam1977 likes this.
MRAYB is offline
post #8029 of 8453 Old 06-01-2020, 09:30 PM
Cam1977's Avatar
Liked: 4146
^many thanks for the advice! I might be picking up one tomorrow!
MRAYB likes this.
Cam1977 is offline
post #8030 of 8453 Old 06-01-2020, 09:39 PM
rlb4's Avatar
Quoted: 35 Post(s)
Liked: 34
The Harmony 665 is $50 at Best Buy.
rlb4 is offline
post #8031 of 8453 Old 06-02-2020, 05:46 AM
porschedrifter's Avatar
Quoted: 60 Post(s)
X4500 owners, I've been reading a few negative reviews saying they've had theirs die or suffer from green screen and other failures: Has anyone here had any issues with their 4500s? Making me feel uneasy about wanting to get one.
Denon AVR-X4700H - Aragon 2005 THX Amp - Paradigm Monitor 9 v5 Front - Paradigm CC-290 v5 Center - B&W DM 602 S3 Surrounds - Klipsch R15m Atmos Highs - Rythmik E15 15'' Servo Subwoofer
porschedrifter is offline
post #8032 of 8453 Old 06-02-2020, 05:56 AM
fireman1000's Avatar
Quoted: 157 Post(s)
Liked: 59
Originally Posted by fireman1000 View Post
Thanks for the help. I did turn on the ARC function in the denon menu but still no sound. I will try the power off 10 min. and unplug the hdmi cable and then back on and plug in trick to see if it's a hand-shake issue.
Still no sound with my Denon AVR-X4500h and my LG 65" c7 OLED. I have tried everything I know of and still can't get any sound out of the receiver from the TV. I have the arc settings on in the denon menu with auto and digital and also tried pcm to no avail. I have the tv settings to sound out hdmi and I have the cable from the denon on monitor 2 as the manual states to my HDMI2 labeled arc on my TV. I have powered down and unconnected and even tried different cables and still no sound. I'm open to suggestions and thanks for the suggestions so far!
fireman1000 is offline
post #8033 of 8453 Old 06-02-2020, 06:18 AM
avernar's Avatar
Liked: 1512
The ARC/eARC port is MONITOR 1 on the Denon.
ianfretwell and dfa973 like this.
post #8034 of 8453 Old 06-02-2020, 06:34 AM
JD23's Avatar
Quoted: 1066 Post(s)
Liked: 832
My X4500H has been perfect. Granted, it's only 3.5 months old, so this isn't much of an endorsement. Like all Denons, it runs warms, so I have an AC Infinity T8 to limit the temperature to not more than ~90F outside the unit.
JD23 is online now
post #8035 of 8453 Old 06-02-2020, 06:47 AM
MRAYB's Avatar
Quoted: 547 Post(s)
Liked: 2244
Not an X4500H owner, but have owned it's predecessor, the X4400H since new (2018). Running 11.4 setup with Zone 2 and Zone 3 utilized at varying times. I just feel the need to emphasize the use of a cooling fan with theses units. Have used an Aircom fan system from day one. Never has gotten above 85F, still good as new.
Ricoflashback likes this.
MRAYB is offline
post #8036 of 8453 Old 06-02-2020, 06:52 AM
eaayoung's Avatar
Quoted: 357 Post(s)
Liked: 216
I've had my 4500 since 1/2019. No problems with mine.
eaayoung is offline
post #8037 of 8453 Old 06-02-2020, 07:00 AM
chi_guy50's Avatar
Liked: 2511
I am curious how well this works for any QS settings that are not a part of the AVR's currently downloaded config file when the command is sent from the Harmony remote.
I should think that the AVR would execute only the settings recognized internally according to saved QS1 through QS4 regardless of any alterations that were subsequently made.
Could you clarify with specific examples of how this is working for you with the supplemental QS's on the Harmony regarding the functionality of the pertinent settings as shown below?
Name:	Denon Quick Select.jpg
post #8038 of 8453 Old 06-02-2020, 07:07 AM
billymac's Avatar
Quoted: 57 Post(s)
Hey gang, have a few questions before I spend money. We're looking to add a TV to our back patio.
Currently own the AVR-X3500H, which is supporting our living room as well as our back patio for a separate Sonos zone by way of Zone 2 pre-outs to a Sonos AMP and Polk subwoofer amp. This setup has served us well, but we'd really like to add a TV to our back patio.
I've read and re-read the Denon manual, but what I'm trying to understand is if I can simply run HDMI from Zone 2 OUT on the Denon to the new TV and still be able to operate the Sonos zone via Zone 2 source selection on the remote. I realize I would likely NOT be able to listen to music on the patio AND have the TV on the patio running with audio at the same time, but can I operate one activity at a time using the remote or is it one or the other period due to wiring or AVR limitations?
In case it matters, I'm using a Comcast cable box for cable TV in the living room and am unfortunately unable to leverage Live TV cable streaming due to the fact we do not have cable for our home internet service--otherwise this question would be moot.
Our hope is that we can select Zone 2 source with the remote to either listen to music or watch live cable tv on the back patio.
Couple more quick questions:
Is there any way to utilize the existing patio speakers for the TV audio?
The manual is a little confusing. If I'm watching TV with audio in Zone 2, is TV in main zone interrupted if the source is the same (Comcast cable box)?
Thank you in advance for any help or guidance here.
"the one who has the most fun wins."
billymac is offline
post #8039 of 8453 Old 06-02-2020, 08:24 AM
Quoted: 157 Post(s)
Liked: 59
I typed it wrong earlier. I do have the cable connected Monitor 1 HDMI connection and it is labeled arc but still no sound. Thanks for the correction.
post #8040 of 8453 Old 06-02-2020, 08:37 AM
avernar's Avatar
Liked: 1512
OK, moving on to the next items on the list:
Have you pressed TV Audio on the remote?
On the Denon you just need the ARC setting turned on.
Sorry, just reread that you have the C7. I believe that it only supports ARC. So just ARC in the Sound Out menu and make sure Simplink is turned on somewhere.
Madmax67 likes this.
11.2 , 2.1 , 2.2 , 7.2.4 , alexa , amazon music , avr , avr-x2500h , bluetooth headphones , calibrate , dali alteco , Dayton Audio , Denon , denon 3500 , denon 4500h , denon avr-x4500h , denon receiver , denon x3500 , dolby atmos , earc , heco victa 500 , heos , issue , Klipsch , lg b8 , onkyo ts-xr507 , oppo 203 , sound , speakers , svs pb-1000 , tear ax3000 , testing , wiring
