"OFFICIAL" 2018 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8) - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 2646Likes
post #1291 of 5326 Old 12-05-2018, 03:54 PM - Thread Starter
jdsmoothie's Avatar
Quoted: 22565 Post(s)
Liked: 12280
Originally Posted by Stereodude View Post
Not that I'm doubting what's in the 8th post,
And yet your post would say otherwise. Believe what is listed in post 8.
jdsmoothie is offline
post #1292 of 5326 Old 12-05-2018, 05:07 PM
Stereodude's Avatar
Quoted: 4335 Post(s)
Liked: 3069
Too bad the post is ambiguous and isn't clear... Apparently asking for clarifications on your posts is not allowed. Maybe someone else will help.
Stereodude is offline
post #1293 of 5326 Old 12-05-2018, 05:23 PM
Keenan's Avatar
Quoted: 3943 Post(s)
Liked: 3645
I'm not sure if this will help but the below are my settings with my X4500H. It's a standard 7.2 setup with 4 height speakers, two front in the ceiling and two rear in the ceiling. I'm using an outboard 5 channel amp for the basic 5 speakers and the Denon for the other 6(2 rear and 4 ceiling). Something that confused me when I first set this up was all the variations for the 4 additional speakers, toggling through the scenarios I think I counted about 5 or 6 different setups.
Name:	X4500H speaker settings-2.JPG
ID:	2492232   Click image for larger version
Name:	X4500H speaker settings-1.JPG
Stereodude likes this.
Keenan is online now
post #1294 of 5326 Old 12-05-2018, 06:36 PM
Stereodude's Avatar
Liked: 3069
Okay, that makes sense. That's the bit of information I was missing. There's a section in the setup menu to pick the front L&R speakers as getting the pre-amp / not amplified...
Your configuration mimics That's how I was planning to place my height speakers (though I could place them differently). So you can't use Auro 3D with that speaker configuration? I only have one Blu-ray with Auro 3D though I've heard their upmixer is pretty good for 2 channel music.
What 5 channel amp are you using?
post #1295 of 5326 Old 12-05-2018, 10:14 PM
Madmax67's Avatar
Quoted: 2218 Post(s)
Liked: 2515
Its not ambiguous when it's in your own receivers amp assign settings. Denon manuals are pretty useless when it comes to explaining things in general and this specifically. Plenty of owners who have used this amp assign in this manner over the last 2 years to remove any doubt of it's function.
mrtickleuk likes this.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #1296 of 5326 Old 12-05-2018, 10:30 PM
Madmax67's Avatar
Liked: 2515
Correct. Only either FHR/FHL SHR/SHL or use of the rear heights along with the front like is used for a dual purpose Atmos/DTS-X configuration except with Auro there's an option to add a top surround VOG 10th speaker using the subwoofer 2 pre out and an external power amp.
Madmax67 is offline
post #1297 of 5326 Old 12-06-2018, 05:53 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12280
This same post has been used for the last 3 years and you're the first to indicate it was ambiguous.
post #1298 of 5326 Old 12-06-2018, 12:15 PM
Keenan's Avatar
Liked: 3645
I'm not sure about the Auro 3D usage, I haven't got that far into it yet. I've just been enjoying the new display(Sony A9F) and AVR combo for the last 3-4 weeks, I'm still focused on getting the display dialed in and then I plan to play with the audio.
post #1299 of 5326 Old 12-06-2018, 12:20 PM
Keenan's Avatar
Liked: 3645
For anyone who is interested, there is now a Dimmer command listed in the Harmony database for the X4500H which works for soft buttons as well as hard buttons depending on how you apply it. Prior to this the only way to dim the front panel was drilling down into the setup menu. The command should work for all recent(10 years?) Denon AVRs.
post #1300 of 5326 Old 12-07-2018, 12:26 AM
EvolutionStu's Avatar
Liked: 6
Wow, really!
That’s one of the things that has always annoyed me. Can’t wait to get that working tonight.
Great news, thanks for sharing it!
Best Regards,
Stu
Samsung Q9FN // Panasonic BD820 // Denon X4500H // 5.1.4 //
EvolutionStu is offline
post #1301 of 5326 Old 12-07-2018, 04:45 AM
Alby00003's Avatar
Quoted: 34 Post(s)
Liked: 37
I have a basement PS4 gaming set up with a Denon 2500 and presently no subwoofer.
I'm running 7.0 and my main's are full size/range towers rated at 4 ohm's, center is 8 ohm's, surrounds are 6 ohm and lastly my surround back's are also 8 ohm's.
I have the AVR 2500 set at 4 ohm's which deactivates Eco mode.
My question is would setting the 2500 to 6 ohm's get my 4 ohm main towers pumping out more low end energy and would it impact the 2500 negatively?
Thought's?
The worlds greatest evil....Ignorance
In SCIENCE I trust!
Oppo UDP-203, Sony XBR75 X940E, Paradigm (all Version 2's) Studio 100, CC, 60, Servo 15 Subwoofer, Denon 4802 AVR
Alby00003 is offline
post #1302 of 5326 Old 12-07-2018, 05:07 AM
Selden Ball's Avatar
Quoted: 4808 Post(s)
Liked: 2848
Thought's?
Selecting a 4 or 6 Ohms setting does nothing but reduce the voltage going to the receiver's amplifiers. That's also what ECO mode does: the 4 Ohms setting is the equivalent of max ECO. The only effect on the sound is to limit the maximum available volume level at all frequencies.
The best way to get quality lower frequencies is to add a subwoofer. Even upgrading your front speakers will have only a limited benefit since the best locations in a room to produce bass frequencies are not the best locations for imaging at higher frequencies.
The low frequencies are limited by the woofer designs of your speakers. Running an Audyssey calibration will provide the best bass. Overdriving the woofers by increasing the bass signal going to them will result in distortions in the sound as well as potentially damaging the woofers, especially if they "bottom out".
ETA:
To some extent you can improve the bass-to-treble balance if you use the ($20) Audyssey MultEQ smartphone app and select a frequency response curve with higher bass levels. For details, consult the app's thread at https://www.avsforum.com/forum/90-re...-pre-pros.html
Madmax67 likes this.
Selden
Selden Ball is offline
post #1303 of 5326 Old 12-07-2018, 07:10 PM
Alby00003's Avatar
Quoted: 34 Post(s)
Liked: 37
ETA:
Got it, thanks.
I was just wondering if some more current would translate into some more umph in the low end.
Still I must say that Call of Duty Black Ops 4 is sounding pretty sweet!
In SCIENCE I trust!
post #1304 of 5326 Old 12-07-2018, 08:18 PM
maphiker's Avatar
Quoted: 14 Post(s)
Hi. I just purchased the AVR-X6500H. So far I am very happy with it. But I can't find the remote codes for this receiver. The link at the beginning of this thread seems to be broken and I get the same problem when going through the Denon website.
I'd greatly appreciate if someone can post a copy. Thank you.
maphiker is offline
post #1305 of 5326 Old 12-08-2018, 01:35 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12280
The link in post 1 is the same link listed in the X6500H Owner's manual (p. 264) so if it isn't working then the web page must be down.
So the next option would be to look at the X4500H link which does work.
post #1306 of 5326 Old 12-08-2018, 01:35 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12280
Got it, thanks.
More "umph in the low end" should be handled by the sub which has its own amp.
Alby00003 likes this.
post #1307 of 5326 Old 12-08-2018, 03:38 AM
Quoted: 52 Post(s)
Liked: 4
new Denon AVR-X4500H
Hi,
I have recently purchased brand new AVR , Denon X4500H, instead of Yamaha RXV 683.
However, after doing calibration on my new Q Acustics 3050i set up, and 2 ceiling Monitor speakers, I really dont see any special sound improvement vs Yamaha RXV 683 (which was about 800 EUR), and new Denon I bought is 1.400 EUR.
I did calibration via Denon mic, and set up , but the sound is somehow plastic.... On top of it, the bass from front speakers (3050i) , is not that strong, and subwoofer (3060i) is only fair, nothing special....Somehow, I miss agility and strength of sound from my new AVR and spakers. Can it be that I should do something with frequencies to improve the sound ? Also, what about crossover on the subwoofer ?
Any suggestion will be very much appreciated.
Thank you and best regards,
Milos
milosbgd is offline
post #1308 of 5326 Old 12-08-2018, 04:17 AM
Yankees24's Avatar
Quoted: 217 Post(s)
Liked: 77
Did the speakers sound good with the old receiver?
Think before you speak....
Yankees24 is offline
post #1309 of 5326 Old 12-08-2018, 05:12 AM
Quoted: 52 Post(s)
Liked: 4
I had Yamaha NSF-555 /444/333 set up on Yamaha AVR. Then I changed everything, AVR (Denon X4500 instead of Yamaha RXV 683), and speakers (Q aqustics 3050i set instead of Yamaha 555/444/333). The new AVR + speakers are ok, but still, somehow "plastic" , I dont feel the bass that strong when watching the movies...maybe the issue is crossover/frequencies... I have set up all speakers "small" and frequency 80hz , except SUB is LFE+MAIN on 120hz, and ceiling speakers are also 120hz, the rest are 80hz. The living room is about 15m2 of size , and its kind of open space....
milosbgd is offline
post #1310 of 5326 Old 12-08-2018, 05:14 AM
Quoted: 1031 Post(s)
Liked: 819
Hope u resolve this and check all channel levels & other items folks mentioned.
Also, just because you spend more $$ on an AVR doesn’t mean sound improvement. Usually means more features, channels & bit more wattage. Reminder wattage has to double to achieve 3 dB increase.
Mid-level Yamaha are very good values and I always felt VG musically & have punch. I have 3 mid-level Yamahas & One Denon and prefer the Yamaha
Good luck..
Primary set-up 5.1.4; Yamaha A2050, Paired w/Parasound P5 & ATI 522NC 2 channel amp
Revel F206 fronts & Revel M16 rears; Outlaw X12 Sub & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is online now
post #1311 of 5326 Old 12-08-2018, 06:00 AM
Liked: 2848
If you haven't already, please take the time to look through the Audyssey 101/FAQ. It'll help you to get a good calibration. The instructions in the equipment's owner's manual are pathetically inadequate.
Selden
post #1312 of 5326 Old 12-08-2018, 07:41 AM
maphiker's Avatar
Quoted: 14 Post(s)
Thanks for your reply. Perhaps I should be more specific in my request. I am looking for the AVR-X6500H remote code that will work with the Oppo BDP-103.
The remote codes for this receiver are unavailable on the denon website. Oddly, the codes for the 4500 do not list Oppo and the code given for the 8500 does not seem to work for me.
Thanks again.
Nailz003 likes this.
maphiker is offline
post #1313 of 5326 Old 12-08-2018, 11:09 AM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
I just had eye surgery so please don't mind a couple mistakes.
Would anybody care to tell me any advantages or disadvantages between the x3500 and the Yamaha a1080?
Most important to me is 4K passthrough, preouts, 2 sub preouts hopefully independent.
If there are any links iwith comparisons please feel free is it's been discussed already.
kingpin111 is offline
post #1314 of 5326 Old 12-08-2018, 11:27 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12280
Thanks again.
AFAIK, only the Denon flagship models have ever listed the Oppo code 32545 so if that doesn't work …. well, time for a Harmony remote.
post #1315 of 5326 Old 12-08-2018, 11:34 AM
maphiker's Avatar
Quoted: 14 Post(s)
Thanks for that. Maybe Denon can offer me a solution.
maphiker is offline
post #1316 of 5326 Old 12-08-2018, 11:40 AM
rakstr's Avatar
Quoted: 414 Post(s)
Liked: 182
I'd say the 3500 stacks up better against the A880 but it's a tough call. If you can get them both at the same price point I personally would go with the A1080. I love my 1020's.
If it's between the A880 and the X3500H I'd say Chevy/Ford
Scroll down after clicking this link for a 4 way comparison.
https://www.crutchfield.com/Product/...Item=022RXA880
rakstr is offline
post #1317 of 5326 Old 12-08-2018, 11:46 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12280
These are comparable units with similar features for the most part, although each has a few advantages the other does not:
X3500H - arguably the better EQ (XT32); dual sub EQ (independent level/delay)
A1080 - able to store 2 EQ patterns; 27 DSP modes (esp Sci Fi, Adventure, Enhanced); stream audio to Bluetooth headphones
Note however, you would have to step up to the A2080 for dual sub EQ (independent level/delay), so for your use case, the X3500H gets the nod.
Madmax67 and dfa973 like this.
post #1318 of 5326 Old 12-08-2018, 11:48 AM
Quoted: 52 Post(s)
Liked: 4
thanks a lot, I took a look at it shortly, I can see a lot of good points and advices.
Still, can you tell me why Dolby Vision movies , when I go to "video info" options , says RGB 8-bit, and when it is HDR , it is 12-bit 4:4:4. I thought that Dolby Vision is more vivid color, but in my case its worster. Any suggestions?
milosbgd is offline
post #1319 of 5326 Old 12-08-2018, 12:17 PM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
Thanks guys. The Denon is also $600 cheaper here right now at $999.
post #1320 of 5326 Old 12-08-2018, 01:22 PM
kingpin111's Avatar
Quoted: 298 Post(s)
Liked: 289
Just ordered the DENON AVR-X4500H.
Found one for a couple hundred more than the 3500.
calibrate , dali alteco , Denon , denon 4500h , denon avr-x4500h , denon x3500 , earc , heco victa 500 , lg b8 , onkyo ts-xr507 , sound , speakers , tear ax3000 , testing
