Dead Inuke 6000dsp - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By markmon1
  • 1 Post By corradizo
post #1 of 18 Old 05-13-2018, 06:27 AM - Thread Starter
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
Dead Inuke 6000dsp
So I had sent in my inuke 6000dsp for some led repair, got it back with the led not being fixed. Contacted them about the issue so they will pay for return shipping to fix the issue that didn't get fixed, just came from having dinner and wanted to watch a movie but the amp won't power on now! My luck is awesome! So my question is should I stay with the inuke or buy a different amp? I'm powering 2 Ultimax 15s
Joe879 is offline
post #2 of 18 Old 05-13-2018, 09:31 AM
josh6113's Avatar
Quoted: 273 Post(s)
Liked: 118
If I were you I would seriously give the crown XLS line a go.I run an XLS 1002 and it's been rock steady.
Sent from my MHA-L29 using Tapatalk
Doing what I do best...LIVIN!
josh6113 is offline
post #3 of 18 Old 05-13-2018, 02:07 PM
M Code's Avatar
Quoted: 1132 Post(s)
Liked: 735
That brand has a terrible reputation for quality...
Good specs on paper & cheap but poor reliability...
Save the $ and buy a quality amplifier..
Just my $0.02...
M Code is offline
post #4 of 18 Old 05-13-2018, 02:59 PM
markmon1's Avatar
Quoted: 5679 Post(s)
Liked: 3732
I have used crown amps for subs. They are ******* compared to behringers. They have the power but they just dont push subs right. I don't have equipment to measure to know exactly why there was such a big difference. I've also tested inukes vs EP4000 amps and the EP4000 just destroyed the inukes in bass performance. The behringer EP4000 has improperly documented dip switches so most people dont realize the real benefit from them. But the EP4000 is by far the best sub amp I've found (again, once the dip switches are set right).
The proper dipswitch setting is every dip switch to the right except 8 and 10 to the left. I've read the specs. I've seen the measurements of how the 6000 puts out more power than the 4000. It's doubtful you're getting near the power rating on your amp anyway. The EP4000 is my first choice for sub amps.
I have tested and sold off several crown amps. I currently own 2 EP4000's for 2 sub arrays, 2 buttkicker amps, 2 inuke dps's a 6000 and a 1000.
Joe879 and bebb like this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #5 of 18 Old 05-13-2018, 09:24 PM - Thread Starter
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
Hmmm I never heard of this model, does it have built in dsl? And would this be enough for 2 Ultimax 15s?
Sent from my SM-G935T using Tapatalk
Joe879 is offline
post #6 of 18 Old 05-13-2018, 09:28 PM
markmon1's Avatar
Liked: 3732
My EP4000 is running 4 15’s bridged in mono right now. It has no dsp. It’s a heavy class H (more of a class A/B design not class D like the inuke).
markmon1 is offline
post #7 of 18 Old 05-13-2018, 09:39 PM
corradizo's Avatar
Quoted: 1552 Post(s)
Liked: 1628
DSL? This is a family show.
corradizo is offline
post #8 of 18 Old 05-13-2018, 09:53 PM
Nexgen76's Avatar
Quoted: 775 Post(s)
Liked: 224
Don't you run your EP4000 bridged ? Curious real world ratings how much they put out bridged at 4ohms. I know the Inuke6k both channels driven 4ohms put out 2000 each channel.
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is offline
post #9 of 18 Old 05-13-2018, 09:54 PM
Fabricator's Avatar
Quoted: 238 Post(s)
Liked: 138
I've also tested inukes vs EP4000 amps and the EP4000 just destroyed the inukes in bass performance. But the EP4000 is by far the best sub amp I've found (again, once the dip switches are set right).
very interesting. i have a EP2500 that is not in use. hmmmm
BenQ HT1070 . Da-Lite HP 2.8 119"
ULTIMAX 18-22, 14cf ported, x2. 6000DSP.
XPA-3, PIONEER VSX-01TXH, SWANS 6.1 & C3
Fabricator is offline
post #10 of 18 Old 05-14-2018, 10:49 AM - Thread Starter
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
Sorry meant dsp
Joe879 is offline
post #11 of 18 Old 05-14-2018, 10:58 AM
corradizo's Avatar
Liked: 1628
Sorry meant dsp
Was just foolin
Joe879 likes this.
post #12 of 18 Old 05-14-2018, 03:52 PM - Thread Starter
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
Was just foolin
It's ok I was half asleep when I posted it lol
Joe879 is offline
post #13 of 18 Old 05-14-2018, 03:55 PM - Thread Starter
Joe879's Avatar
Quoted: 232 Post(s)
Liked: 29
So I will have to look into this more, I'm running my subs for 4ohms. I could get this amp and get a separate dsp
Joe879 is offline
post #14 of 18 Old 07-14-2018, 04:23 PM
bebb's Avatar
Quoted: 229 Post(s)
Liked: 165
What does this do for you? You are turning the clip limiter OFF on channel 1 but ON for channel 2. You are turning the low cut filter ON for channel 1 but OFF for channel 2. Why set it up this way? Why are both channels not set the same?
If bad sound were Faital, good sound would be almost impossible
Killed two Mach5 21s and three UM-18s (and counting?)
bebb is offline
post #15 of 18 Old 07-14-2018, 04:26 PM
markmon1's Avatar
Liked: 3732
I know what it is documented to do, which is why I have repeatedly stated "the documentation is wrong". The result of this was you could hear tons more subsonics, and the woofers all moved a lot more at the same volume level. The subs literally came alive. As was indicated above, it's possible that they fixed this based on manufacture date of the amp, but I have not seen evidence of that so far. I have an amp dated 2009 and one dated 2015 both require same settings for the subs.
Note: I didnt come up with these settings. With a little research you can come across other discussions that came to this conclusion.
Note #2 : Your analysis was also incorrect. If you read the documentation, I think you meant to say it is turning the low cut filter *OFF* for channel 1 but *ON* for channel 2.
In any case, the dipswitch settings above turned the EP4000 into a magic sub amp destroying the crown's I had and the inuke's I had.
markmon1 is offline
post #16 of 18 Old 07-18-2018, 03:45 PM
bebb's Avatar
Quoted: 229 Post(s)
Liked: 165
Yes, on note 2 my bad.
Interesting. Assuming you are correct, and the documentation wrong, then thank you for sharing. Regardless, you say you are getting much better sound with your settings. Good to know. If I ever get an EP amp, I will definitely keep this in mind. Thank you for sharing.
bebb is offline
post #17 of 18 Old 10-08-2018, 06:49 AM
Quoted: 198 Post(s)
Liked: 74
@markmon1 I was hunting around for a amp to power the 2 MicroMarty's im about to build that has 390HO and in the Measuring Amplifiers thread there is a spread sheet "stating" EP4000 is only putting out 615W RMS- So how are you running so many off one?
Remy.Alexander is online now
post #18 of 18 Old 04-09-2019, 11:11 AM
johnplayerson's Avatar
Quoted: 302 Post(s)
Liked: 83
Nothing like the real sine wave power of a toroidal amplifier. Even if it is one of the smaller ones. He has the Amplifier bridged so he should be getting
1200 to 1600 in bridged mode for 8 ohms speaker load.
If he is bridged into a 4 ohm speaker load (2 ohm stereo equiv), Death within 3 to 5 years is rather certain.
Most users I see on AVS tend to put a lot of drivers on one amplifier. One or two tops is best per amp.
If you get the behringer ep 4000 , plan on purchasing your coils in a manner that you end up with a 8 ohm final load, and bridge the amp to the speakers.
This would entail using 2 amps with one 8 ohm driver per amp , or 2 amps with 2 four ohm drivers on each amp, wired in series. Setting up subs with these
amps in this manner, results in not only the best bass you will ever hear, but your amp just may outlive you.
https://******************.com/index.php?topic=459.60
A Good amplifier requires a adequate power supply, It does not matter what the amplifier is capable of if the power supply will not provide the power required. Most amplifiers have under rated power supplies. It is up to you to make sure you get the ones that are least under rated if at all.
johnplayerson is offline
