Choosing between 2 receivers, help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-16-2018, 11:37 AM - Thread Starter
latentpsycho's Avatar
Liked: 0
Hi all,
My needs are fairly modest: 4k pass through, 7 channels, atmos, 4-6 hdmi inputs.
My setup for the near future will remain 5.1, but in a couple years I may look at changing things to take advantage of atmos.
I'm using a Definitive Technology 600 speaker set.
Bestbuy (Canada) has these two models on sale:
Denon AVR-S730H - $399 CDN
Onkyo TX-NR575 - $449 CDN
Which would you folks recommend? And is there any other similarly priced receiver that I should be considering?
Thanks in advance!!
latentpsycho is offline
post #2 of 4 Old 05-16-2018, 05:07 PM
Quoted: 106 Post(s)
Liked: 62
Originally Posted by latentpsycho View Post
Hi all,
Thanks in advance!!
I'd recommend you get both and try them in your setup to see which one serves you best. They will have different sound signatures and features.
Go Eagles! Go Sixers! Go Phillies! Go Flyers!
tingham is offline
post #3 of 4 Old 05-17-2018, 03:17 AM
Quoted: 95 Post(s)
Liked: 122
Between those two, I would choose Denon as I prefer Audyssey to AccuEQ, but would take a Sony 1080 over both. Only way to know for sure is to try them.
Projector: LG PF1500W; Receiver: Sony STR-DN1080; Speakers: Monitor Audio Controlled Performance Inwalls and Inceilings; Subwoofer(s): SVS PC-2000; Bluray Player: Sony BDP-S6500; Remote: Roomie Remote; Cables: Monoprice
rnatalli is offline
post #4 of 4 Old 05-17-2018, 03:28 AM
satboy's Avatar
Quoted: 799 Post(s)
Liked: 535
Denon would be my choice too, Sony has been good in the past too (In that price range)
Den - LG 65 OLEDE7P - Denon AVR-X4200W - Definitive Mythos STS - ProCenter 2000 - SR-8040BP - SVS Ultra-13 - DTV 4K - XBOX One S
Media - LG 65 OLEDC8 - AVR-X4400 - KFL28F - Vienna Acoustics Center - Def GEMS Rear - Def A60 Atmos - Monitor Silver SUB - DTV 4K - XBOX One X
My YouTube Tech Channel - https://www.youtube.com/c/TechFan
satboy is offline
