Official Pioneer Elite VSX-LX503 Thread - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 81Likes
post #391 of 688 Old 04-11-2019, 04:03 PM
bungi43's Avatar
Quoted: 46 Post(s)
Liked: 24
Originally Posted by bungi43 View Post
Well, my SCLX502 came yesterday. Didn't get to play with it much, but so far so good. I like the new MCACC. It set up quickly. Still need to tinker.
I won't post a ton more here since this is the 503 thread...but I like what i have so far
After 3 months, pleased so far. I need to upgrade my center channel as it sounds a bit off, but I don't think it's a 502 issue. Hoping to install ceiling speakers in the next few weeks for atmos.
eriksells916 likes this.
bungi43 is offline
post #392 of 688 Old 04-14-2019, 11:12 PM
Quoted: 17 Post(s)
Liked: 3
Anyone getting a random clicking sound when in Dolby audio surround mode? Also cuts off the rears hooked up to the external amp randomly ?
Hokies83 is offline
post #393 of 688 Old 04-17-2019, 04:36 PM
john stephens's Avatar
Quoted: 63 Post(s)
Liked: 44
Using Flare Connect
I'm surprised that there is little or no discussion of the excellent Flare Connect Feature of this receiver. To wit, are there other Flare Connect users here?
My setup
Two Pioneer AVR's
Three, Pioneer MXR-3
Two Onkyo NS 302
Getting excellent performance, properly synchronized with this set!
john stephens is offline
post #394 of 688 Old 04-19-2019, 08:15 AM
Liked: 5
A new firmware update has been released today that is really great. It adds Airplay2 supports, 4K enhanced mode/standard mode switching, Sonos and Amazon music improvements and other bug fixes.
(Change history link)
https://intl.pioneer-audiovisual.com.../downloads.php
(Firmware specific changes and functions\new functions PDF)
http://jp.pioneer-audiovisual.com/ma...supple_933.pdf
godfatherip likes this.
redtommy76 is offline
post #395 of 688 Old 04-19-2019, 08:26 AM
jsb75's Avatar
Quoted: 350 Post(s)
Liked: 88
Anyone know what the pre out voltage is on the pioneer? Can't seem to find it listed anywhere. The Onkyo rz 830 is listed as only doing 1v from the multi channel pre outs. Hoping the pioneer is better.
jsb75 is online now
post #396 of 688 Old 04-19-2019, 08:30 AM
Liked: 5
I have been wondering about bi-amping with greater than 5.2.2 setups since the manual specifies limitations bi-amping and then attempting to use height/dolby speakers and zone connections. Its not clean if its a power issue or a signaling issue. The manual also seems to oddly leave out examples of 6.+ configurations instead detailing many 5.+ and 7.+ configurations options. Using an external amplifier I'd assume would correct any power issues but as you questioned, there is little to nothing in the docs explaining function behavior when using an external amp.
post #397 of 688 Old 04-19-2019, 08:32 AM
Liked: 5
voltages are listed on page 171 of the manual in the 'Amplifier Section' of General Specifications'
"Rated RCA Output Level and Impedance
1 V/470 Ω (PRE OUT)
1 V/470 Ω (SUBWOOFER PRE OUT)
1 V, 200 mV/470 Ω (ZONE 2 PRE/LINE OUT)
1 V, 200 mV/470 Ω (ZONE 3 PRE/LINE OUT)"
post #398 of 688 Old 04-19-2019, 08:42 AM
jsb75's Avatar
Quoted: 350 Post(s)
Liked: 88
1 V/470 Ω (PRE OUT)
Ok, so it's the same as the onkyo. Thanks
redtommy76 likes this.
jsb75 is online now
post #399 of 688 Old 04-19-2019, 09:43 AM - Thread Starter
Liked: 9
Seems the VSX-LX504 and VSX-LX304 are bringing back the Advanced MCACC. Glad to see they've done this.
https://www.pioneer-audiovisual.eu/e...ucts/vsx-lx504
https://www.pioneer-audiovisual.eu/e...ucts/vsx-lx304
many03 is offline
post #400 of 688 Old 04-19-2019, 11:44 AM
eriksells916's Avatar
Quoted: 514 Post(s)
Liked: 195
good timing, I have the 503 in my cart at Frys for under $500......what to do, what to do?
eriksells916 is online now
post #401 of 688 Old 04-19-2019, 12:01 PM
Quoted: 514 Post(s)
Liked: 195
If you search the speaker and receiver threads, you will often see that others think there is very little benefit to bi-amping. If you were going to do anything, then use the LR preouts with a more robust 2 channel amp to take some load off the 503.
my $.02
post #402 of 688 Old 04-19-2019, 01:50 PM - Thread Starter
Liked: 9
If you think having Advanced MCACC is not worth it, I'd go for the LX503.
Having used it previously on the 23TXH, IMHO, I'd wait and get LX504 since you get more freedom to fiddle with its settings.
many03 is offline
post #403 of 688 Old 04-19-2019, 02:16 PM
Quoted: 514 Post(s)
Liked: 195
Yea good call. I was looking at the rz730 since accueq allows some tweaking, but I have really only seen comments about how mediocre it was.
I could even settle for the 304 since I don't need 11 channels or preouts.
post #404 of 688 Old 04-19-2019, 03:00 PM - Thread Starter
Liked: 9
I'd steer away from AccuEq.
Seeing there's only 100w difference between the power supply of the LX304 (750w) vs LX504 (850w), I wouldn't have an issue in settling with the LX304.
many03 is offline
post #405 of 688 Old 04-21-2019, 12:02 PM
Quoted: 63 Post(s)
Liked: 44
What's wrong with 1 V? The way I see it, the following power amp just needs to have sufficient voltage gain to amplify one Volt into the voltage necessary to deliver the desired maximum power to, say, an 8 Ohm load. Here Pmax = (Vout^2)/8. So if you wish to deliver, say, 150 Watts to 8 Ohm speakers, the amp must be able to put out Vout = Sqrt(8*Pmax) = 34.64 V. So one merely requires a power amp with a voltage gain of 30 dB. Such meager gain is routinely available for any power amp worth its salt.
post #406 of 688 Old 04-21-2019, 02:40 PM
dutchedoven's Avatar
Originally Posted by JChin View Post
Hi dutchedoven, see page 99 in OM
At the time of purchase, the remote controller is in the mode to control playback in the main room. To play a source in ZONE 2, set the remote controller to the ZONE control mode (ZONE 2). To control the main room play again, restore the remote controller to the main room control mode.
Using the buttons at bottom of the remote:
1. While pressing and holding MODE, press ZONE 2 at least 3 seconds until the
remote indicator blinks twice.
• The mode of the remote controller switches to the mode to control ZONE 2.
• To restore the main room control mode, while pressing and holding MODE,
press MAIN at least 3 seconds until the remote indicator blinks once.
I did this, my remote lights up but none of the buttons work on zone 2. I tried everything and even held the remote directly in front of the receiver. I kept my side screen on and zone 2 works when I turn it on with the app or manually using the front receiver buttons but no go on the remote. Any suggestions?
dutchedoven is offline
post #407 of 688 Old 04-21-2019, 05:57 PM
Quoted: 21 Post(s)
Liked: 27
Latest Update Problems
I just did the latest 503 update and all the new functions are present. HOWEVER, when I adjust the volume on the receiver, the TV picture goes out. Completely blank, but I hear the volume increase or decrease. After releasing the volume control, the picture comes back. Anyone else having this problem? Any ideas? Thanks!
Tjonathan0 is offline
post #408 of 688 Old 04-21-2019, 06:20 PM
Liked: 5
The pdf on the new 4k signal format option state "• There may be some image disruption depending on
the connected component and the HDMI cable. If this
occurs, switch to "Standard"." vs. 'Enhanced'
give it a shot
post #409 of 688 Old 04-21-2019, 06:46 PM
Quoted: 21 Post(s)
Liked: 27
I could not find the instructions on how to do this. Wouild you please let me know what page of the manual they’re on? Or what setting I need to go to. Thanks.
post #410 of 688 Old 04-21-2019, 06:50 PM
Quoted: 21 Post(s)
Liked: 27
Found it. Giving it a try.
post #411 of 688 Old 04-21-2019, 07:11 PM
Liked: 5
page 64 of the link I put in the last post (the pdf)
post #412 of 688 Old 04-21-2019, 07:30 PM
Quoted: 21 Post(s)
Liked: 27
Didn’t work
post #413 of 688 Old 04-21-2019, 08:14 PM
Liked: 5
Didn’t work
Something else you can try, front the front panel only.... Hold (Dimmer) then press (Return) this will open a menu for the HDMI inputs with three modes for each. Try Mode 1 or 3 for each input with the issue. Mode 2 can cause issues per Pioneer. This adjusts handshake between devices. Mode 1 is always the default. Other than that, you can try the non-destructive restart option for when the unit gets funky (Page 159 of the regular manual under 'try restarting the unit'). It will reload settings when it comes back up. Do not use the factory default reset in the second section unless you really want to start over with all of your settings.
When the unit is operating erratically
❏❏Try restarting the unit
Restarting this unit may solve the problem. After turning the unit to standby mode, press and hold the STANDBY/ON button of the main unit for at least 5 seconds,
and then restart the unit. (The settings on this unit are kept.) If the problem persists after restarting the unit, unplug and plug the power cords of this unit and connected
devices.
Good luck!
mwinc likes this.
post #414 of 688 Old 04-21-2019, 11:35 PM
Quoted: 17 Post(s)
Liked: 3
Hmmm maybe will will get advanced MCACC via firmware update?
Hokies83 is offline
post #415 of 688 Old 04-22-2019, 02:28 PM
jsb75's Avatar
Quoted: 350 Post(s)
Liked: 88
The guys from audioholics seem to recommend 2v. Don't have much experience in external amps my self, besides my subwoofer amps. But it seems most receivers list 1v on there pre outs.
jsb75 is online now
post #416 of 688 Old 04-22-2019, 05:26 PM
Quoted: 63 Post(s)
Liked: 44
In your case, you need to turn your question around and what i s the sensitivity of my power amp? The sensitivity is a measure of the minimum voltage required to drive output to its rated power at specified load. I'm confident that you will typically find this to be less than one volt. Indeed, in the old days, preamps were designed to deliver one milliWatt of power into a 600 Ohm load. As such, this amounted to 0.775 Vrms. Let me end with an example, it should be obvious that the Pio's 1V is sufficent to drive its own power amp to the rated output level. Other modern power stages behave similarly.
post #417 of 688 Old 04-24-2019, 01:13 PM
godfatherip's Avatar
Quoted: 259 Post(s)
Liked: 191
Casting with google play music seems more reliable since the latest firmware update.
| LG OLED65C8P | Pioneer VSX-LX503 | Def Tech BP9040 + CS9040 + A90 + SR9080 | Klipsch R-112SW |
godfatherip is offline
post #418 of 688 Old 04-24-2019, 02:13 PM
Quoted: 100 Post(s)
So what is difference between standard and enhanced? I have cable and xbox ran thru tv (samsung q70) and reciever connected via arc.
(Sometimes i do switch and run xbox thru receiver then to tv)
Mike Wheaton is offline
post #419 of 688 Old 04-24-2019, 02:18 PM
Quoted: 100 Post(s)
Nvrmnd i found it. So if i run everything thru tv and no video to receiver it doesnt do anything for me. Unless i switch the xbox to go thru receiver 1st correct
post #420 of 688 Old 04-24-2019, 02:31 PM
Quoted: 259 Post(s)
Liked: 191
Yes if you run everything through the TV and just use ARC then the standard/enhanced setting shouldn't matter. If you run something through the AVR and it supports the higher bandwidth 4K signals like 4K 60Hz 4:4:4 or 4K 60Hz 4:2:2 12bit then you should set it to enhanced to get the best PQ possible.
