Need Amp to Power Outdoor 8 ohm speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-20-2018, 07:49 AM - Thread Starter
lardo5150's Avatar
I have two weatherproof speakers from monoprice (the 6.5 inch version).
I was looking to just use the Sonos Connect Amp to power them and play music, but at $500 bucks, no way.
I am in need of an amp to power these speakers. I can just use my Chromecast Audio to stream the music, so that is not an issue.
I just need a simple small amp, that won't over heat. I will have an outdoor volume control, but I THINK I would need the volume on the amp turned almost all the way up, and just adjust the volume with the control outside.
Pyle makes a few between $100 and $200 bucks, but reviews and quality make it seem sketchy.
lardo5150 is offline
post #2 of 4 Old 05-20-2018, 01:47 PM
Quoted: 583 Post(s)
Liked: 306
check out the audiosource 100vs (ab) or the ad102 ( class D). these can be had for ~100-200 new, lots of used on ebay 50 -100.
parts express has the dayton audio APA102(class D) basically the same as the audiosource ad102 although rated a little higher WPC. put the amp indoors somehwere...
of interest is the dayton audio hi fly system. they have a pre amp only and and integrated pre+ amp (20 wpc). basically a poor man's sonos - but a fraction of the cost. wpa 02: $38, wfa40 : $88. surprising what 20 wpc can do. But your chromecast audio will do the trick.
this set up could be installed outdoors in a weatherproof box...
you can also find some chinese made class D 2amps for ~25 - 50 on ebay. output power depends on the power supply used.
hope it helps
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #3 of 4 Old 05-20-2018, 06:05 PM - Thread Starter
lardo5150's Avatar
quick question, if I DID go with the Sonos Connect Amp, any issue using it with a pair of these speakers from monoprice?
Any volume issues?
https://www.monoprice.com/product?c_...seq=1&format=2
post #4 of 4 Old 05-20-2018, 06:15 PM
Quoted: 583 Post(s)
Liked: 306
Any volume issues?
those look decent. don't know how they sound
