Denon x4400 or x6400 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 1 Post By zorax2
  • 1 Post By Jive Turkey
  • 1 Post By zorax2
  • 1 Post By jdsmoothie
  • 1 Post By jjackkrash
  • 1 Post By zorax2
  • 2 Post By afrogt
post #1 of 24 Old 06-04-2018, 05:32 PM - Thread Starter
pda15's Avatar
Quoted: 462 Post(s)
Liked: 190
Need help.
Room Size: 45 x 15 x 9
Use: 90% HT / 10% Music
Current Setup: (7.2)
Dual SVS PB-2000
C - Infinity RC263
L - Infinity R162
R - Infinity R162
LSS - Infinity R162
RSS -Infinity R162
LRS - Infinity RS152
RRS - Infinity RS152
Looking to add 4 in-ceiling speakers most likely RSL C34E.
Which AVR should I get? I know the x4400 can only power 9 channels and I would have to add a 2 channel amp to power the other 2 (rears). But it's only around $1.1k vs the x6400 which goes for $700 more. A 2 channel amp goes for around $200.
Which is more practical?
pda15 is offline
post #2 of 24 Old 06-04-2018, 05:42 PM
zorax2's Avatar
Quoted: 260 Post(s)
Liked: 268
I've got a 4300 that I use essentially as a pre/pro with a couple of ATI amps. You may want to consider a nice amp for your mains and possibly enough channels for your center and surrounds (2 to 5 or 7 channels). The advantage to this is you'll always have enough amplification channels so you don't have to buy the extra amplification channels every time you buy a new AVR. We did some blind testing with a couple of systems and couldn't hear the difference between a Marantz 8802 and the Denon 4300 using the same external amps. Just a thought to consider. . .
pda15 likes this.
7.2.4 with Denon X4300W, ATI 2005 & 1807 Amps, Kef Reference 203 Mains, 202c Ctr, 201 Surr, Ci200RR-THX Top Rears, Q300 Frt Hts, E301 Rear Surr, Power Sound Audio PSA dual S3600i Subs,
GIK & DIY Acoustics, JVC X790/RS540 Projector, Stewart Neve 100" Screen, Panasonic Blu-Ray DMP-UB900, Xbox One X, Crowson Transducers, INSTEON, UDI ISY994i, Amazon Echo
zorax2 is offline
post #3 of 24 Old 06-04-2018, 06:05 PM
Jive Turkey's Avatar
Quoted: 556 Post(s)
Liked: 415
You might want to see if Crutchfield or B&H Photo still have 6300's. I got a good price on one and have been quite pleased so far (I upgraded from a 5200).
pda15 likes this.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #4 of 24 Old 06-05-2018, 08:43 AM - Thread Starter
pda15's Avatar
Quoted: 462 Post(s)
Liked: 190
Thanks for the tip. 6300s are going for $1,500 everywhere including eBay.
pda15 is offline
post #5 of 24 Old 06-05-2018, 08:54 AM - Thread Starter
pda15's Avatar
Quoted: 462 Post(s)
Liked: 190
Can you recommend budget 2 channel amps?
pda15 is offline
post #6 of 24 Old 06-05-2018, 09:31 AM
zorax2's Avatar
Quoted: 260 Post(s)
Liked: 268
I think there are some amps listed in the main model year Denon threads. I think @jdsmoothie posted the recommendations.
pda15 likes this.
zorax2 is offline
post #7 of 24 Old 06-05-2018, 10:01 AM
jdsmoothie's Avatar
Quoted: 21894 Post(s)
Liked: 11866
The most often recommended 2CH amp is the AudioSource Amp100VS (50W) from Amazon.
pda15 likes this.
jdsmoothie is offline
post #8 of 24 Old 06-05-2018, 10:06 AM - Thread Starter
pda15's Avatar
Quoted: 462 Post(s)
Liked: 190
Cool. Thanks! That's affordable. Sorry noob question. How do I connect this to the AVR let's say Denon 4400?
pda15 is offline
post #9 of 24 Old 06-05-2018, 10:15 AM
jdsmoothie's Avatar
Liked: 11866
The Denon AVRs are covered each year in their respective Owner's thread. Review posts 1-8 in the 2017 Denon AVR Owner's thread for more helpful information and specifically post 8 for expanding the X4400H from 9CH --> 11CH.
https://www.avsforum.com/forum/90-rec...l#post51748441
pda15 likes this.
post #10 of 24 Old 06-05-2018, 10:28 AM - Thread Starter
pda15's Avatar
Quoted: 462 Post(s)
Liked: 190
Thank you!
pda15 is offline
post #11 of 24 Old 06-05-2018, 11:23 AM - Thread Starter
pda15's Avatar
Quoted: 462 Post(s)
Liked: 190
Which route should I go?
Denon 4400 ($1,100) + AudioSource Amp100VS (50W) from Amazon ($150) = $1,250
or
Denon 6300 ($1,500)
pda15 is offline
post #12 of 24 Old 06-05-2018, 11:40 AM
jjackkrash's Avatar
Quoted: 2223 Post(s)
Liked: 2328
or
Denon 6300 ($1,500)
A one box solution is nice if you are not inclined to run more robust power for the L/C/R. The 6300 will have a slightly better build quality and its made in Japan. You likely will not be able to tell the difference between the two by listening to them and the features are pretty similar. I'd personally get the 6300 given your choices, but there's no wrong or bad answer.
Jive Turkey likes this.
jjackkrash is offline
post #13 of 24 Old 06-05-2018, 12:04 PM - Thread Starter
pda15's Avatar
Quoted: 462 Post(s)
Liked: 190
I only need the amp to run 2 rear surrounds. Are all 6300 made in Japan? Having just one box is a plus for me. I'm trying to have as less gears as possible on my stage. On the other hand, the 4400 + amp will save me couple bucks.
pda15 is offline
post #14 of 24 Old 06-05-2018, 12:04 PM
zorax2's Avatar
Quoted: 260 Post(s)
Liked: 268
If you have the rack space, I'd go with the 4400 and Audiosource amp which will likely save you money in the long run by not having to purchase additional amplification channels in an AVR. As mentioned by @jjackkrash , you won't hear the difference between them. I'm not familiar with your speakers, but if they are power hungry or you listen LOUD, then you may want to consider a decent 3 or more channel amp (possibly used) to go with the 4400. Be sure to check with @jdsmoothie before purchasing elsewhere. He contributes a lot to the forum and will get you a good solution.
pda15 likes this.
zorax2 is offline
post #15 of 24 Old 06-05-2018, 12:49 PM
afrogt's Avatar
Quoted: 2025 Post(s)
Liked: 1364
or
Denon 6300 ($1,500)
Since you're in Los Angeles wait for Fry's to have another sale on the x4400. You'll save a few hundred dollars. Fry's puts this AVR on sale at least once a month for a week long period.
You can sign up for Fry's promo codes here.
https://www.frys.com/workflow/AcctMa...annertop032615
Pretty soon, either July or August everyone will start discounting the x4400 as they get ready for the x4500 which usually arrives late September.
jjackkrash and pda15 like this.
Afro GT
afrogt is offline
post #16 of 24 Old 06-05-2018, 02:46 PM - Thread Starter
pda15's Avatar
Quoted: 462 Post(s)
Liked: 190
I have dual PB-2000
7 Infinity Reference speakers
Looking to add 4 in ceiling speakers
pda15 is offline
post #17 of 24 Old 06-05-2018, 02:48 PM - Thread Starter
pda15's Avatar
Quoted: 462 Post(s)
Liked: 190
Lowest at Fry's was $899 3 months ago. I guess no tax as well. The amp is $100 at Crutchfield. Total would be $1,000. Not bad vs $1,500 for 6300.
pda15 is offline
post #18 of 24 Old 06-05-2018, 03:41 PM
markg35's Avatar
Quoted: 344 Post(s)
Liked: 267
Fry's in Norcal had that price two weeks ago.They seem to to have it on sale every 3-4 weeks.
markg35 is online now
post #19 of 24 Old 06-05-2018, 04:01 PM
jdsmoothie's Avatar
Liked: 11866
As a reminder .. there is no price discussion in AVS Forum threads other than the stickied Deals thread.
https://www.avsforum.com/forum/90-rec...ls-sticky.html
post #20 of 24 Old 06-05-2018, 04:27 PM
jjackkrash's Avatar
Liked: 2328
As far as I know, yes, the 6300 (and 6400), 7200, 8500, and Marantz flagship processor (8802/8805) are all made in Japan.
post #21 of 24 Old 06-06-2018, 05:04 PM - Thread Starter
pda15's Avatar
Quoted: 462 Post(s)
Liked: 190
With the current eBay sale, I can get this 6300 for $999. Brand new is $1,500. Anyone with experience purchasing from ListenUp?
pda15 is offline
post #22 of 24 Old 11-10-2018, 07:08 AM
Liked: 0
This is going to sound like a daft question but if you have an external amp powering 2 speakers do the pre-outs also send volume information so when you increase volume on the main AVR the volume also goes up on the external AMP?
Heaf is offline
post #23 of 24 Old 11-10-2018, 07:39 AM
markg35's Avatar
Quoted: 344 Post(s)
Liked: 267
That is correct.
post #24 of 24 Old 11-10-2018, 08:02 AM
Liked: 0
Originally Posted by markg35 View Post
That is correct.
Heaf is offline
