I broke the rules: Component video Cable for Amplifier - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By DreamWarrior
  • 1 Post By bobknavs
post #1 of 18 Old 07-10-2018, 08:30 AM - Thread Starter
eightninesuited's Avatar
Quoted: 310 Post(s)
Liked: 317
So because of the weight of my Parasound amp, I had to move it down my chain.
All my audio cables are Belkin or Fosgate. They do their job - but they are also only 3 feet.
So I got into a situation where I needed about 3 1/2 feet between my Integra Processor and my Parasound Amps.
We'll, enter the good old, haven't used it in 10 years Monster Ultra Component video cables that's 8 foot.
So it is now connecting my LCR channels and you know what?
It sounds pretty good. I don't notice any difference between this and my audio cables. And it looks pretty damn sexy as well.
Proud Member of "Bass-a-holic Anonymous" - Dual Bottle of Choice: SVS PC-13 Ultra + SVS PC-12 NSD. Drink of Choice: Ready Player One Delorean Race
DaLite 0.9 Grey 110" screen. Epson 3000 1080P Projection. 7.2 SVS and Energy Reference + Parasound THX Ultra Amplification system.
eightninesuited is offline
post #2 of 18 Old 07-10-2018, 08:34 AM
drunkpenguin's Avatar
Quoted: 1898 Post(s)
Liked: 1819
I can only load pictures about half the time on AVS these days so I cant see the sexyness, but if its working congratulations! I've been buying the Amazon choice cables lately and they seem to work great and are really cheap. Not all that sexy, but ugly things need love too!
drunkpenguin is offline
post #3 of 18 Old 07-10-2018, 08:36 AM
jcmccorm's Avatar
Quoted: 611 Post(s)
Liked: 461
Well count me in as an audio criminal too because that's what I use between my AVR and amp with my LCR; a component video cable. Works like a champ.
jcmccorm is offline
post #4 of 18 Old 07-10-2018, 08:45 AM
DonoMan's Avatar
Quoted: 246 Post(s)
Liked: 194
Did you actually expect a difference?
Honestly from an electrical standpoint you shouldn't be even slightly surprised. These cables are the exact same, except they may have better shielding because video has a higher bandwidth. Possibly even lower capacitance too as video cables often use foam dielectrics and such to lower capacitance.
DonoMan is offline
post #5 of 18 Old 07-10-2018, 09:30 AM - Thread Starter
Quoted: 310 Post(s)
Liked: 317
I had a feeling but I never did it. It's like an unwritten rule - a cardinal sin if you break it.
And putting a component cable to connect between 2 pieces of $1000+ gear isn't exactly common.
So before I ordered 7 6 foot digital coax cables, some old component cables just worked.
The Monster Cable worked perfectly. It's color coded so the green wire went to center as indicated on my processor.
post #6 of 18 Old 07-10-2018, 09:35 AM
DonoMan's Avatar
Quoted: 246 Post(s)
Liked: 194
Literally any cable you can buy on the shelf with 2 RCA ends will work for audio. 50 ohm cable, 75 ohm cable, analog or digital, audio or video, it doesn't matter at audio frequencies. You can even use S/PDIF coax for analog audio with zero problems - though using analog audio cables for S/PDIF may or may not work since the cables aren't guaranteed to have a characteristic impedance that S/PDIF needs (analog audio doesn't need that).
DonoMan is offline
post #7 of 18 Old 07-10-2018, 09:39 AM
DreamWarrior's Avatar
Quoted: 993 Post(s)
Liked: 579
Really wanna blow your mind? A coaxial digital RCA cable will work, too, lol!
But, really, this isn't a surprise -- the only difference is a component video (and coax digital) RCA cable just has to have a 75ohm impedance and, likely, will be better shielded. A decent RCA audio cable will likely be usable as component video or coax digital, too, but it's not guaranteed to have the proper impedance, so may not.
edit -- guess @DonoMan beat me to it, lol.
DonoMan likes this.
DreamWarrior is offline
post #8 of 18 Old 07-10-2018, 10:17 AM
bobknavs's Avatar
Quoted: 2334 Post(s)
Liked: 1663
I'm using something from an older school: a composite video set. Red, white, and yellow. As far as I know, all 3 cables are identical coaxial ones. Yellow I use for the center.
Works perfectly, of course.
drunkpenguin likes this.
bobknavs is offline
post #9 of 18 Old 07-10-2018, 10:30 AM
Liked: 1819
I'm doing the same thing!
post #10 of 18 Old 07-10-2018, 11:11 AM
jcmccorm's Avatar
Quoted: 611 Post(s)
Liked: 461
Nice.
First one that comes in and says they're using an s-video cable with home-made RCA adapters on each end is the winner.
jcmccorm is offline
post #11 of 18 Old 07-10-2018, 11:42 AM
noah katz's Avatar
Quoted: 2010 Post(s)
Liked: 732
Why would you expect a cable with a much higher freq requirement (video vs. audio) to perform worse?
Noah
noah katz is offline
post #12 of 18 Old 07-10-2018, 11:46 AM
Ben Tan's Avatar
Quoted: 528 Post(s)
Liked: 514
Don't bring this over to reddit or headfi, you'd get hang.
SVS Ultra Bookshelf + SVS Ultra Center
Prime Bookshelf Surround with Prime Elevation Heights
Dual Rythmik FV15HP
Yamaha RX-A3060 + Parasound Halo A31 + Emotiva A500
Ben Tan is offline
post #13 of 18 Old 07-10-2018, 12:25 PM - Thread Starter
Quoted: 310 Post(s)
Liked: 317
There's a $3500 cable on USaudiomart that might interest you.
I'll never understand why people spend so much on cables.
post #14 of 18 Old 07-10-2018, 12:27 PM - Thread Starter
Quoted: 310 Post(s)
Liked: 317
Nice.
First one that comes in and says they're using an s-video cable with home-made RCA adapters on each end is the winner. [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Oh yea? I'm just gonna use a metal hanger now to connect my amp to my processor. Beat that!!! Lol
post #15 of 18 Old 07-10-2018, 12:34 PM
jcmccorm's Avatar
Quoted: 611 Post(s)
Liked: 461
Ha!
Wasn't there some test done doing just that (using a coat hanger) and they couldn't hear a difference? Seems like I read about it on AVS but it was quite a few years ago.
jcmccorm is offline
post #16 of 18 Old 07-10-2018, 01:13 PM
DonoMan's Avatar
Quoted: 246 Post(s)
Liked: 194
Ha!
While that might work for line level signals in some cases, it works better as speaker cable. When noise is induced into a cable, it is usually* (edit to add word usually) done so weakly, such that if you have a low impedance like a speaker, the noise will basically be shorted out to almost nothing (there isn't enough energy in the noise to really do much through an 8 or 4 ohm speaker). But when driving a high-impedance signal like the input to an amplifier, the noise is capable of changing the voltage more, because the signal is much lower power and is not able to "drown out" the noise so easily.
https://consumerist.com/2008/03/03/d...les/index.html is the link
Note that while the image at the top shows RCAs, the text says speaker wire.
DonoMan is offline
post #17 of 18 Old 07-10-2018, 02:10 PM
bobknavs's Avatar
Liked: 1663
Aluminum foil. Coat hanger wire is too stiff.
bobknavs is offline
post #18 of 18 Old 07-10-2018, 04:42 PM
gene c353's Avatar
Quoted: 177 Post(s)
Liked: 133
I've always used component video cables for my analog audio connections. Even for the 6/8 channel anolog audio ins/outs of the old universal dvd players. And right now excellent quality component video cables are dirt cheap. Why not use them?
gene c353 is offline
