My new receiver search and related questions... - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #61 of 67 Old 08-05-2018, 05:28 AM
ccotenj's Avatar
Quoted: 170 Post(s)
Liked: 353
Originally Posted by velocci View Post
Hi all, I'm finishing my basement and I had the electrician have a separate power receptacle on its own circuit cause I heard its good for the AVR. But I didn't specify how many amps I wanted the circuit. He gave me 15 amps. this receptacle will have the AVR, computer, media streamer, cable box plugged into it. basically everything except the TV cause I'm wall mounting it and I have a receptacle high up on the wall for it. so my question is, is 15 amps enough for everything except the TV?
yes.
- chris
https://www.avsforum.com/t/1332917/ccotenj-finally-gets-a-projector
ccotenj is offline
post #62 of 67 Old 08-05-2018, 05:31 AM
ccotenj's Avatar
Quoted: 170 Post(s)
Liked: 353
Ok thanks. If it turns out to be not enough, can it be increased?
you can pull 12 gauge from the box, replace the breaker, and make it a 20 amp circuit.
you won’t need to.
- chris
ccotenj is offline
post #63 of 67 Old 08-05-2018, 06:04 AM - Thread Starter
velocci's Avatar
Quoted: 596 Post(s)
Liked: 42
I fogot to mention i will also be plugging in a 12" sub woofer eventually. Does that change anyone's answer?
Family Room: Onkyo TX-NR 646 AVR, Polk Audio RtiA3 fronts, Polk Audio CSiA4 center, BIC America F12 sub, Polk Audio RC-65i rears
Basement: Denon AVR-X3400 AVR, Klipsch RP280f fronts, RP450c center, SVS PB-2000 sub, Polk Audio RC-85i rears & surrounds
Www.jvpix.com
velocci is offline
post #64 of 67 Old 08-05-2018, 06:22 AM
ccotenj's Avatar
Quoted: 170 Post(s)
Liked: 353
nope.
if your situation WAS a problem, avs (as well as other fora) would be LITTERED with posts from people blowing breakers. the vast majority of users don’t even have a dedicated circuit, there’s other stuff (like lights, etc.) on the same circuit as all their stuff.
i ran an avr (and all the associated input devices), a pj and a seaton submersive off of a 15 amp circuit. i really don’t think you are going to have problems.
- chris
ccotenj is offline
post #65 of 67 Old 08-05-2018, 06:51 AM - Thread Starter
velocci's Avatar
Quoted: 596 Post(s)
Liked: 42
ok thanks everyone.
Www.jvpix.com
velocci is offline
post #66 of 67 Old 08-05-2018, 07:00 AM
ccotenj's Avatar
Quoted: 170 Post(s)
Liked: 353
just as an aside. if you are still in the construction phase, run an ethernet cable to both your avr and tv locations.
- chris
ccotenj is offline
post #67 of 67 Old 08-05-2018, 07:14 AM - Thread Starter
velocci's Avatar
Quoted: 596 Post(s)
Liked: 42
the basement is 99% finished so its too late to add cables, but I did put 4 ethernet cables running from the TV/AVR location to the other side where I keep my modem/router/switch. I also payed for a cheep ass conduit from the wall mounted TV to the bottom of the wall. I payed $200 for a narrow ribbed tube that probably costs $2 at a HW store. when the guy told me I should get this, I didn't bother asking what type of tube? how wide?, etc.
Www.jvpix.com
velocci is offline
audio , avr , components , Denon , movies , Onkyo , power , receiver , sound , streamer
