Affordable Atmos Preamp with digital Outputs - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #1 of 33 Old 08-20-2018, 05:46 AM - Thread Starter
Quoted: 59 Post(s)
Hi there,
is there an affordable Atmos preamp that has digital outputs (for each channel)?
Soldy is offline
post #2 of 33 Old 08-20-2018, 11:24 AM
afrogt's Avatar
Quoted: 2022 Post(s)
Liked: 1361
how do you define digital outputs for each channel? what would you connect these digital outputs to?
smithsabom likes this.
Afro GT
afrogt is offline
post #3 of 33 Old 08-20-2018, 11:38 AM - Thread Starter
Quoted: 59 Post(s)
I am not picky, optical outputs (SPDIF) for example.
Active speakers which use a DSP. I want to avoid an additional conversion: HDMI -> Sound decoder -> DSP -> Speaker Amp
and not: HDMI -> Sound decoder -> DAC -> DAC -> DSP -> Speaker Amp
The DSP will split the signal in multiple ways (3-way active front speakers).
Soldy is offline
post #4 of 33 Old 08-20-2018, 12:31 PM
afrogt's Avatar
Liked: 1361
If you have active speakers, wouldn't each speaker have an analog input? Why not connect each speaker that way to the preouts on the prepro? I guess I'm not familiar with using an optical input on each speaker.
Afro GT
afrogt is offline
post #5 of 33 Old 08-20-2018, 12:55 PM
bobknavs's Avatar
Quoted: 2100 Post(s)
Liked: 1486
I'm curious as to what active speakers will be used.
I saw something similar a couple of years ago when I was looking for new desktop PC speakers: the highly digital ones from Vanatoo.
I'd guess that no consumer-level with digital outputs for each channel exists at the moment. If I'm wrong about that, I'd like to know, although I have no immediate plans to get rid of my analog AV gear.
bobknavs is online now
post #6 of 33 Old 08-21-2018, 01:33 AM - Thread Starter
Quoted: 59 Post(s)
The speakers will be DIY
There are plenty of Amps with analog pre outs, but what I want to avoid is the unnecessary A/D conversion.
Soldy is offline
post #7 of 33 Old 08-21-2018, 05:45 AM
markmon1's Avatar
Quoted: 4438 Post(s)
Liked: 2777
Sorry this doesn't make any sense at all. Speakers don't play digital audio, amplifiers don't amplify digital audio so the digital has to be converted *before* it hits the amplifier. Why can't the pre/pro do the D-->A conversion? It's not being done an additional time, its only being done once - as it should be.
As the audio comes off the HDMI into the processor, it has to decode it to send the proper output to the proper speaker. Even if it were to send it as digital data via SPDIF, it would still have to decode it then reencode it to send digitally. It's not like it can just extract it from the stream. The dolby and dts libraries in the processors are literally libraries of code provided by dolby and dts, and they only decode. They don't reencode.
HDMI --> Processor decoder --> DAC --> Speaker amp with its DSP --> Speaker
markrubin, Montucky and Muphasta like this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #8 of 33 Old 08-21-2018, 07:24 AM - Thread Starter
Quoted: 59 Post(s)
It does make sense if you don't over simplify it. This is the bold part broken down into pieces:
HDMI -> Decoder -> DAC -> DAC -> DSP -> DAC -> amplifier -> speaker
The "D" in DSP stands for digital
And I want to get rid of the underlined conversions.
A DSP with digital input is the MiniDSP HD for instance. And the chain would look like this:
HDMI -> Decoder -> MiniDSP (includes DAC output) -> amp -> speaker
Soldy is offline
post #9 of 33 Old 08-21-2018, 07:34 AM
Montucky's Avatar
Quoted: 753 Post(s)
Liked: 715
You may be way overthinking this all. All you need is an AVR with preamp outs. The AVR does all the necessary processing and DAC work internally, then outputs an analog signal to your external amp of choice. Now if you're worried on trying to maintain as pure of a signal as possible, just know that for short distances, RCA (aka unbalanced) is JUST fine for short distances between your processor and amp. However, if you want to go nuts, you can up your game to a higher end pre-pro and go with XLR interconnects (aka balanced). I used balanced XLR between my Yamaha CX-A5100 processor and MX-A5000 amp. That amp also does standard RCA which I've tried and found no difference (we're talking like a 1.5 foot cable here) but I went XLR because it looked gorgeous in my rack, I love XLR cable heads (they're not going anywhere), and to be honest, it was just plain fun. Yeah, I'm weird. Haha. It CAN make a difference though if you have some good distance between units, but that's typically not the case for most users.
Montucky is offline
post #10 of 33 Old 08-21-2018, 07:44 AM - Thread Starter
Quoted: 59 Post(s)
I know, but I don't want the AVR to the DAC work internally. That is acually the point, I want an AVR which doesn't have a DAC
Your suggestion with the balanced output is the next best thing. But there the signal is still unnecessary converted twice. If you have no DSP afterwards, than digital outputs make no sense
If there is no pre amp with digital output then I have no choice. But if there is, it would be the better solution in my case.
Soldy is offline
post #11 of 33 Old 08-21-2018, 07:55 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 639 Post(s)
Liked: 562
Sure, they exist e.g. Trinnov Altitude 32, but they're expensive. I can't think of an inexpensive example.
Soldy, Montucky and Mashie Saldana like this.
RUR is offline
post #12 of 33 Old 08-21-2018, 08:09 AM - Thread Starter
Quoted: 59 Post(s)
That's one difficult choice: Should I get a pre amp or a new car
Soldy is offline
post #13 of 33 Old 08-21-2018, 08:37 AM
mindedc's Avatar
Quoted: 13 Post(s)
I'm betting that he wants to do active crossovers and/or biamp the speakers.... Its a lot less scary to use a DSP to make your crossover that allows infinite tweaking instead of committing yourself to a complex passive electrical circuit.
I get what you want to do and I think its not going to happen. You're in the .0001% of the market wanting something like this. Those of us using pre/pros are probably 3% of the market and those just using recievers instead of sound bars are probably 20% of the market. The only hope is if a manufacturer makes a proprietary system that uses amplified speakers. Even then you're going to be screwed because the interconnection/cabling is going to have to be reverse engineered as its probably going to send things like digital volume controls, power on/off, DPS maps for room correction etc to the speakers.
The only two systems I know of that operate like that are Meridian and B&O. Not Cheap for such an experiment. I don't know if either currently make an Atmos compatible system. If they do, good luck reverse engineering how the proprietary components talk to each other. Your best hope is to use 24bit DACs and a good reciever. If you are placing the amps/DSP at each speaker (internal?) your best bet is to run balanced XLRs instead of unbalanced RCA. If you are only going a few feet, there is no benefit to balanced cables (unless we're talking about pro audio where there is tons of gear and lighting controls that could produce massive EMI).
The only other thing I can think of that may do something like that is a dolby Lake processor. You would not be buying the mini-DSP and using the lake processor for everything at that point (up to 64 speaker outs on a Lake). You would also be spending megabucks. Speaking of megabucks, you could probably also do this with a Trinninov (Up to 32 speaker outs), again doing everything inside the processor for megabucks. Both of these solutions you would put your active amp in your speaker and run XLR to the speaker.
mindedc is offline
post #14 of 33 Old 08-21-2018, 08:45 AM
scotter's Avatar
Quoted: 63 Post(s)
Liked: 29
I can see what the OP is trying to do, but like most of you, I don't think it's necessary. I am wondering if there is anything in the commercial space from Crestron, QSC, etc that does what he is looking for? But commercial and affordable rarely go hand in hand.
Hijack, but do you like that Yamaha setup? That does a full 7.4.1(2) right? I am not certain on all the new HDMI specs, but does that setup do the HDR, Dolby, etc?
scotter is offline
post #15 of 33 Old 08-21-2018, 08:56 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 639 Post(s)
Liked: 562
Originally Posted by mindedc View Post
…..you could probably also do this with a Trinninov (Up to 32 speaker outs), again doing everything inside the processor...
Can and do, though my amps are external to the speaker.
RUR is offline
post #16 of 33 Old 08-21-2018, 09:03 AM
Super Moderator
markrubin's Avatar
Quoted: 1772 Post(s)
Liked: 3541
intuitively I understand it is best to avoid unnecessary A/D conversions, but....does it really matter?
could you discern the difference in a blind test?
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess HDCP = Hollywood's Draconian Copy Protection system
LG C9 OLED owner
markrubin is offline
post #17 of 33 Old 08-21-2018, 09:53 AM
Montucky's Avatar
Quoted: 753 Post(s)
Liked: 715
I DO love the Yamaha. It's actually an incredible value all things considered. The matching amp is surprisingly quite the powerhouse, even when all channels are being driven. Been super solid and I have no complaints. I had it driving my retail store's dedicated theater room and it absolutely rocked the house. Would highly recommend it.
And you're right that I do believe Crestron, QSC, and the like would have something like OP's looking for, but I guarantee it ain't cheap. We're talking tens of thousands of dollars at the very least as it would definitely be a more commercial application. I bet even a Trinnov would be cheaper than going that route. Haha.
Montucky is offline
post #18 of 33 Old 08-21-2018, 09:54 AM
Montucky's Avatar
Quoted: 753 Post(s)
Liked: 715
Short answer. "Affordable Atmos Preamp with Digital Outputs"? = a HARD no.
RUR likes this.
Montucky is offline
post #19 of 33 Old 08-21-2018, 10:27 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 639 Post(s)
Liked: 562
Ethan Winer's converter loop-back tests.
Only test I know of, Mark. AVS discussion here.
markrubin likes this.
RUR is offline
post #20 of 33 Old 08-21-2018, 11:24 AM - Thread Starter
Quoted: 59 Post(s)
Too bad, but thanks to all of you
Soldy is offline
post #21 of 33 Old 08-21-2018, 12:14 PM
Montucky's Avatar
Quoted: 753 Post(s)
Liked: 715
You got it! That's what we're here for. Interesting question, though. Really. Good luck with your setup!
Montucky is offline
post #22 of 33 Old 08-21-2018, 02:48 PM
markmon1's Avatar
Liked: 2777
A DSP digitally modifies an analog signal. It doesn't mean it works on a digital signal. Your diagram doesn't make sense. It's not converted from analog to digital and back each time processing is done. Haven't you heard of things like the minidsp or amps that have DSP in them? They aren't also DACs. You're quite confused.
markmon1 is offline
post #23 of 33 Old 08-21-2018, 03:32 PM
bobknavs's Avatar
Liked: 1486
I'd heard of the Trinnov, as the pre-pro that could process the most Atmos channels of any device on the market. (32, in its highest end version. 34 is the Dolby specified max for the home version of Atmos.)
I had no idea that it had digital outputs. I've never heard of AES. (Each AES port carries two PCM signals.)
post #24 of 33 Old 08-21-2018, 03:48 PM
Montucky's Avatar
Quoted: 753 Post(s)
Liked: 715
Yup. I've worked with some commercial QSC setups (at a cinema) and the Trinnov appears to basically be one of the closest things to a commercial cinema setup in your home. I want an Altitude 32 SOOOOOOOOOO badly it hurts. Do I have a place for it? No, but that's besides the point. Lol. It's an absolute beast.
Montucky is offline
post #25 of 33 Old 08-21-2018, 03:51 PM
bobknavs's Avatar
Liked: 1486
It's probably a waste of bits to post this, but I suggest that you have a look at this one: MiniDSP DDRC-22D. https://www.minidsp.com/images/docum...f-DDRC-22D.pdf This is a version that only has digital inputs and outputs.
post #26 of 33 Old 08-21-2018, 04:22 PM
Kal Rubinson's Avatar
Quoted: 1193 Post(s)
Liked: 1034
A DSP works on a digital signal, not an analog signal. An analog signal must be converted to digital in order to apply DSP.
Agreed.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #27 of 33 Old 08-21-2018, 04:34 PM
DreamWarrior's Avatar
Quoted: 940 Post(s)
Liked: 539
LOL! Speaking from authority and being absolutely wrong -- certainly an AVS first !
A DSP, by necessity, works on a digital signal -- it is DIGITAL signal processor after all. Thus, in order for it to function with an analog signal, it needs an analog-to-digital converter (ADC) in front of it. And, once you apply the DSP's algorithms (FIR, IIR filters, etc) you need to convert back to analog at some point (hence, a digital-to-analog converter, DAC).
Therefore, a MiniDSP with an analog input and output has both an ADC and a DAC inside it, by necessity! You're the one confused!
Now, as for the original poster -- the answer is simple; NO! As others have said, processors with any digital outputs are expensive. And it's probably only because folks who require such a thing are in the minority and thus in a niche market wherein economies of scale are not as good. Same as folks are want a pure pre-processor vs. a receiver.
Finally, I recognize and appreciate the desire to have a "pure" signal path with a single DAC conversion before amplification, but I'd bet the benefits of performing the x-over / EQ in the digital domain overwhelms any ADC->DAC insertions into your signal chain incurred to do so.
Oh, and if you're going to do volume in the digital domain, as required by having digital outputs, you probably want better than 16-bit resolution typical of S/P-DIF interfaces (though it can support 24bits, I'm uncertain how much consumer gear allows it). Of course, high channel count and higher bitrates / depths is why things like AES67 exist, which, I believe, is what Trinnov supports.
DreamWarrior is offline
post #28 of 33 Old 08-21-2018, 11:08 PM - Thread Starter
Quoted: 59 Post(s)
No offense but you don't seem to know what you are talking about
I already had a feeling this would come, that's why I posted: "The 'D' in DSP stands for digital". A DSP can only process digital signals.
My diagram makes sense and shows exactly how things go down, if the pre amp doesn't have digital outputs.
You are right, it is not. But I also didn't say it is. Thats just in this scenario.
Another thought: Since I come from the DIY sector it might be an option to modify an AVR and exctract the digital signals before they enter the internal DAC. But the money is a little bit to tight for such experiments. If any of you feel like trying be my guest. You could even tell people that it was your idea if it works
Greetings
Soldy is offline
post #29 of 33 Old 08-21-2018, 11:12 PM - Thread Starter
Quoted: 59 Post(s)
My thought was, that it would add up. So not only would I have the x-over/EQ affect the signal quality but also the two conversions. Furthermore I think, that the impact in regards to quality are not very high if a good DSP is used (aside from the unavoidable delay).
Thx for the 24 bit tip.
Soldy is offline
post #30 of 33 Old 08-22-2018, 04:43 PM
Quoted: 940 Post(s)
Liked: 539
I mean, certainly it will "add up" but that's not really the question. The question is, do the additional conversions add up to audible quality loss and, if so, does the loss overwhelm the gain from performing x-over/EQ in the digital domain? Only you can answer that, but see this post by @RUR from within this very thread and you can determine if you can hear a difference between samples that were digitized multiple times.
In my opinion, you're making a mountain out of a mole-hill. There are probably many other weaker links in your chain than an additional A->D->A process (e.g. your room, your speakers, etc). Sure, it's not perfect and "pure", but it's likely inaudible in all but the absolute best systems, in the best rooms, with the best ears. If that's you, then by all means, stress, lol. But, if it is you, be prepared to pony up the $, because it's going to cost you. Fortunately for me, my ears and room aren't good enough to resolve any detail loss from a few (dozen, lol) extra conversions -- I'd recon I'm the norm among people actually willing to admit their ears aren't golden, lol.
