How much pre-amp -> amp cables matter? - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 177Likes
post #241 of 244 Old 09-02-2018, 10:52 AM
Gabre's Avatar
Quoted: 456 Post(s)
Liked: 71
Buddy, you are convincing yourself they are the best speakers and they are worth that money. Do you get my point.
Why don't you throw those cables to garbage and order ur self monoprice wire for 20$
GO
Sent from my HTC U11 using Tapatalk
Gabre is online now
post #242 of 244 Old 09-02-2018, 11:03 AM
Mickey Mouse's Avatar
Quoted: 324 Post(s)
Liked: 169
that is NOT the point!
i have compared my speakers with a lot of others, shall i post pictures of the switching equipment for that as well or do you believe me i have it?
you stated everybody should buy cables for 100...200 bucks, or am i mistaken?
by chance i have a pair of RCA cables here which i compared with the currently used XLR cables for less than $10.
and i have done other tests with 10ft RGB video cables (Amazon Basic) used as audio/RCA cables since i have a second source not directly beside the power amp.s
same result, no difference.
the point is: do a REAL and FAIR comparison!
Mickey Mouse is offline
post #243 of 244 Old 09-02-2018, 01:14 PM
eljr's Avatar
Quoted: 1377 Post(s)
Liked: 11916
you stated everybody should by cables for 100...200 bucks, or am i mistaken?
If you have done double blind listening tests and all in attendance heard a difference and that difference was consistently that the same cable sounded better than the other then you need to publish your results as this would be a world's first and sound engineers from around the globe would need to be aware.
Keith Crusher likes this.
eljr is offline
post #244 of 244 Old 09-03-2018, 12:26 PM
bobknavs's Avatar
Quoted: 2327 Post(s)
Liked: 1656
Thank the deity of your choice. With luck, this thread is dead.
eljr and leecreek like this.
bobknavs is online now
