The "Official" Yamaha RX-A3080, RX-A2080 and RX-A1080 AVENTAGE AVR Thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 325Likes
post #991 of 1153 Old 05-24-2019, 02:01 AM
Ben Tan's Avatar
Quoted: 519 Post(s)
Liked: 504
So Axx80 series has issues with handshaking with the HDMI 2.1 ports on the LG 9 series OLEDs? This is rather worrying.
SVS Ultra Bookshelf + SVS Ultra Center
Prime Bookshelf Surround with Prime Elevation Heights
Dual Rythmik FV15HP
Yamaha RX-A3060 + Parasound Halo A31 + Emotiva A500
Ben Tan is offline
post #992 of 1153 Old 05-24-2019, 05:50 AM
dhackney's Avatar
Quoted: 34 Post(s)
Originally Posted by junior00027 View Post
can you try if dts:x work with earc
Yes, DTS:X works.
See attached photos.
Name:	2019-05-24-Pixel 3 XL-072605-2400.jpg
ID:	2571026   Click image for larger version
Name:	2019-05-24-Pixel 3 XL-072421-2400.jpg
ID:	2571028   Click image for larger version
Name:	2019-05-24-Pixel 3 XL-072520-2400.jpg
dhackney is offline
post #993 of 1153 Old 05-24-2019, 05:51 AM
dhackney's Avatar
Quoted: 34 Post(s)
Originally Posted by Gotanda View Post
Have you been able to get Atmos recognized through eARC?
Yes, Dolby Atmos works.
Name:	2019-05-24-Pixel 3 XL-072918-2400.jpg
ID:	2571032   Click image for larger version
Name:	2019-05-24-Pixel 3 XL-072818-2400.jpg
ID:	2571034   Click image for larger version
Name:	2019-05-24-Pixel 3 XL-072848-2400.jpg
dhackney is offline
post #994 of 1153 Old 05-24-2019, 06:21 AM
dhackney's Avatar
Quoted: 34 Post(s)
Originally Posted by peterjcat View Post
I can’t get multichannel PCM, only stereo PCM.
It is my understanding that the C9, and TVs in general, do not support this format as an input or passthrough.
You can find more information on this topic in the C9/E9 owner's thread here:
https://www.avsforum.com/forum/40-ol...rice-talk.html
dhackney is offline
post #995 of 1153 Old 05-24-2019, 07:17 AM
Liked: 1
Originally Posted by dhackney View Post
Yes, DTS:X works.
thanks
junior00027 is online now
post #996 of 1153 Old 05-24-2019, 10:13 AM
Gotanda's Avatar
Weird, still comes up as just DTHD on my end, can't figure out why.
On a side note, after updating the C9 to 03.60.02 I'm now able to run the Sony UBP-X700 through the RX-A1080 without HDCP issues...
Gotanda is offline
post #997 of 1153 Old 05-24-2019, 10:22 AM
dhackney's Avatar
Quoted: 34 Post(s)
Can you get DTHD Atmos on the 1080 if you are patched: Sony UBP-X700 ---> RX-A1080 ---> LG C9 ?
That's great news!
Thanks for posting that info.
dhackney is offline
post #998 of 1153 Old 05-24-2019, 12:13 PM
Gotanda's Avatar
Haha, mystery solved, and it is truly silly... While I was testing and swapping components back and forth I had simplified the setup and had the RX-A1080 speaker config set to just 3.0.0, and here's the catch: at least the RX-A1080 will not recognize/show Atmos for bitstream (DD+, DTHD) inputs if you don't have surround speakers configured. Reenabling the surround speakers, Atmos/DD+ and Atmos/DTHD comes back up as expected. Contributing to the confusion, the RX-A1080 recognizes Atmos/PCM (from Apple TV) regardless of speaker config. Ah well, silly me for wasting time on this...
Atmos/DD+, Atmos/DTHD and Atmos/PCM all work across eARC as well. I have not been able to get any better than Atmos/DD+ over eARC from the internal C9 apps, but I'm guessing that's more of an app limitation at this point.
Any luck with your Panasonic player using the new C9 firmware?
That's great news!
Gotanda is offline
post #999 of 1153 Old 05-25-2019, 08:37 AM
dhackney's Avatar
Quoted: 34 Post(s)
Unfortunately, updating our LG C9 to 03.60.02 did not fix the HDCP2.2 handshake fail between the Panasonic DP-UB820 ---> RX-A3080 ---> LG C9
dhackney is offline
post #1000 of 1153 Old 05-25-2019, 08:56 AM
dhackney's Avatar
Quoted: 34 Post(s)
Dolby Atmos out of the RX-A3080 using the DP-UB820 Netflix app
I had a PM question on a particular scenario using the RX-A3080 with the Panasonic DP-UB820's Netflix app.
The question: Can you get Dolby Atmos out of the RX-A3080 using the DP-UB820 Netflix app?
Here's the scenario:
Netflix Atmos content (Luke Cage) ---> Panasonic DP-UB820's Netflix app ---> DP-UB820 HDMI video/audio output ---> RX-A3080 AV1 HDMI ---> RX-A3080 AV1 HDMI output 1 ---> LG C9 eARC
TL;DR: no
The Panasonic DP-UB820's Netflix app recognizes the RX-A3080 ---> LG C9 as a valid Atmos chain, but when you play the content, it is only available as "Dolby Surround - DD+" on the RX-A3080.
A 4K Atmos disc plays Atmos normally on the RX-A3080 with the same connections: DP-UB820 HDMI video/audio output ---> RX-A3080 AV1 HDMI ---> RX-A3080 AV1 HDMI output 1 ---> LG C9 eARC
LG C9 firmware: v03.60.02
Panasonic DP-UB820: 1.55
Yamaha RX-A3080: 1.65
See attached photos for details
Name:	2019-05-25-Pixel 3 XL-14-3-2400.jpg
ID:	2571522   Click image for larger version
Name:	2019-05-25-Pixel 3 XL-18-2400.jpg
ID:	2571524   Click image for larger version
Name:	2019-05-25-Pixel 3 XL-26-2-2400.jpg
ID:	2571526   Click image for larger version
Name:	2019-05-25-Pixel 3 XL-27-2-2400.jpg
ID:	2571528   Click image for larger version
Name:	2019-05-25-Pixel 3 XL-27-2400.jpg
dhackney is offline
post #1001 of 1153 Old 05-25-2019, 09:20 AM
dhackney's Avatar
Quoted: 34 Post(s)
While testing the question about the DP-820 Netflix app, I discovered that the LG C9 Netflix app either does not support Atmos or does not recognize the RX-A3080 as a valid Atmos output chain.
Note: I haven't researched whether the LG C9 Netflix app supports Atmos or not on the C9 owners thread yet. I am assuming it does.
Scenario is:
Netflix Atmos content (Luke Cage) ---> LG C9 Netflix app ---> LG C9 eARC HDMI 2.1 ---> RX-A3080 AV1 HDMI output 1
Result: LG C9 Netflix app does not recognize a valid Atmos output chain (or does not support Atmos, see note above)
RX-A3080 firmware: v1.65
See attached thumbnail for details
Name:	2019-05-25-Pixel 3 XL-01-2-2400.jpg
dhackney is offline
post #1002 of 1153 Old 05-25-2019, 10:11 AM
Renatto's Avatar
Quoted: 54 Post(s)
Liked: 31
OFF: Klipsch.
ON:
As I see it should work on the C9, but not on the Panasonic (only Apple TV 4K and Xbox One supports): https://www.cnet.com/how-to/how-to-s...du-and-amazon/ Maybe a future firmware update will resolve the issue on the LG.
DOLBY ATMOS 5.2.4 - Yamaha RX-A2080 - Klipsch RP-280F - RP-450C - RP-250S - RP-140SA - R-112SW - LG OLED 55B7 - HiMedia Q30 - Xbox One X SE
Renatto is offline
post #1003 of 1153 Old 05-25-2019, 01:07 PM
dhackney's Avatar
Quoted: 34 Post(s)
Note that this test was run with the decoder set to "auto" which is why the display showed 5.2.4.
With the decoder set to "straight" there are no presence speakers on the display.
see attached photos
Name:	2019-05-25-Pixel 3 XL-31-2400.jpg
dhackney is offline
post #1004 of 1153 Old 05-25-2019, 05:34 PM
dhackney's Avatar
Quoted: 34 Post(s)
RX-A3080 firmware v1.65 with LG C9 firmware v03.60.02
If you update your C9 to v03.60.02 you will break the eARC enabled by the RX-A3080 firmware v1.65.
You need to reset the C9 to factory settings and that will restore eARC with the RX-A3080.
Unfortunately, I do no know of any way to backup/restore the settings on the C9, so it's a re-setup job.
dhackney is offline
post #1005 of 1153 Old 05-26-2019, 08:44 AM
dhackney's Avatar
Quoted: 34 Post(s)
TL;DR: no
Some additional testing on this:
Test one:
Video: Netflix Atmos content (Luke Cage) ---> Panasonic DP-UB820's Netflix app ---> DP-UB820 HDMI video/audio output ---> LG C9 HDMI 3
Audio: Netflix Atmos content (Luke Cage) ---> Panasonic DP-UB820's Netflix app ---> DP-UB820 HDMI video/audio output (bitstream) ---> LG C9 HDMI 3 --> LG C9 eARC (bitstream) ---> RX-A3080 HDMI output 1 eARC
In this test, the DP-UB820 Netflix app showed only "Dolby Vistion" and 5.1 audio
Test two:
Audio: Netflix Atmos content (Luke Cage) ---> Panasonic DP-UB820's Netflix app ---> DP-UB820 HDMI audio output (bitstream) ---> RX-A3080 AV1
In this test, the DP-UB820 Netflix app showed "Dolby Vision" and "Atmos"
In both patch scenarios, selecting "Straight" mode on the 3080 showed 5.2 on the 3080 display.
see attached thumbnails for results
Name:	2019-05-25-Pixel 3 XL-08-2400-edit.jpg
ID:	2571962   Click image for larger version
Name:	2019-05-25-Pixel 3 XL-09-3-2400-edit.jpg
ID:	2571964   Click image for larger version
Name:	2019-05-25-Pixel 3 XL-10-3-2400-edit.jpg
ID:	2571966   Click image for larger version
Name:	2019-05-26-Pixel 3 XL-47-2400-edit.jpg
ID:	2571968   Click image for larger version
Name:	2019-05-26-Pixel 3 XL-48-6-2400-edit.jpg
Name:	2019-05-26-Pixel 3 XL-48-10-2400.jpg
ID:	2571988   Click image for larger version
Name:	2019-05-26-Pixel 3 XL-48-11-2400-edit.jpg
dhackney is offline
post #1006 of 1153 Old 05-26-2019, 10:20 AM
Renatto's Avatar
Quoted: 54 Post(s)
Liked: 31
Even Netflix recognize ATMOS, the receiver shows only DD+ and not Atmos/DD+, so it seems the player still can't send out (the embedded Atmos).
junior00027 likes this.
Renatto is offline
post #1007 of 1153 Old 05-26-2019, 02:57 PM
docrog's Avatar
Quoted: 1059 Post(s)
Liked: 361
Can YPAO be run twice: once for each of the 2 possible speaker patterns (configurations)?
JVC NX7, Yamaha RX-A3080 (7.2.4 speaker layouts: Dolby Atmos & DTS:X), Panasonic UB820, Oppo 103D, ATV4K, Roku Ultra, TiVo Bolt Vox, Vandersteen Model 3 Signatures & VCC-1 Signature, SVS SB-2000 (2), Clark Synthesis Tactile Bass Transducers (2), Polk PSW-12
docrog is offline
post #1008 of 1153 Old 05-27-2019, 06:13 AM
dhackney's Avatar
Quoted: 34 Post(s)
Yes.
You can then use each of the two patterns to include in different scenes, e.g. one viewer, two viewers.
dhackney is offline
post #1009 of 1153 Old 05-27-2019, 08:16 AM
docrog's Avatar
Liked: 361
Yes. You can then use each of the two patterns to include in different scenes, e.g. one viewer, two viewers.
Thanks for your reply. You continue to be a source of excellent help for me. I guess I'll give it a try...............
docrog is offline
post #1010 of 1153 Old 05-28-2019, 09:09 AM
doyoid's Avatar
Quoted: 29 Post(s)
Liked: 38
Firmware version 1.65 is available for download now, in case anyone wants to install via USB.
doyoid is offline
post #1011 of 1153 Old 05-28-2019, 10:08 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6390 Post(s)
Liked: 6388
Seems like you can always run into hand shake issues, I have not seen anything showing a "big" trend.....
Cleveland Plasma is online now
post #1012 of 1153 Old 05-28-2019, 10:31 AM
RonBoyd's Avatar
Quoted: 111 Post(s)
Liked: 58
https://usa.yamaha.com/support/updat..._rx-v3085.html
1) Vizio PQ65-F1 and 2) Visio D32F-F1
Yamaha RX-A3080 - Darbee Darblet DVP-5000
Roku - 2) Ultra, 1) Premiere, 1) nVidia Shield
SageTV v9 - HD300, Tablo QUAD
4) SiliconDust HDHomeRun units (10 tuners)
RonBoyd is offline
post #1013 of 1153 Old 05-28-2019, 04:36 PM
docrog's Avatar
Liked: 361
I've just reviewed the YPAO section in the 3080 user manual. I'm unable to find any reference to being able to run a 2nd YPAO based on speaker configuration/pattern. Am I missing something?
docrog is offline
post #1014 of 1153 Old 05-28-2019, 04:41 PM
kdouglas10's Avatar
Liked: 0
Had this issue with known good high speed HDMI cables. Finally gave up and ordered Belkin “Ultra HD HDMI cables” and my brand new (February 2019) RX-A3080 would finally connect to my ROKU and OPPO boxes. The Amazon reviews drove my cable selection. Seems there are many supposed HDCP 2.2 capable cables that have deficiencies (or Yamaha is looking for bits that are not properly transmitted in some cables??). Link here for what I bought: “Belkin Ultra HD High Speed HDMI Cable, Optimal Viewing for Apple TV and Apple TV 4K, 4K/Dolby Vision HDR, 2 m/6.6 ft – Black” [edit link to make http proper]:
https:// www dot amazon dot com/ dp/B075N83B9X/ref=cm_sw_r_cp_api_i_OpC7Cb3QFE3BN
kdouglas10 is offline
post #1015 of 1153 Old 05-28-2019, 05:34 PM
dhackney's Avatar
Quoted: 34 Post(s)
1) Run YPAO, which will set the results into pattern one
2) Copy pattern one to pattern two (manual page 131)
3) Run YPAO, which will again set the results into pattern one
That will give you two different patterns based on the two different YPAO runs.
Select either pattern one or two along with the other settings, input, etc. that you want and use the configuration to set a scene, e.g., scene 4.
Repeat the process with the other pattern, settings, input, etc. and use that configuration to set a scene, e.g., scene 5.
For example, I use this method to set scenes for either one viewer or two for different input devices.
dhackney is offline
post #1016 of 1153 Old 05-28-2019, 05:48 PM
docrog's Avatar
Liked: 361
Thanks! Although I was aware of the "copy" function, I didn't realize that running an additional YPAO program wouldn't overwrite both speaker pattern settings (leave speaker pattern #2 intact). It would have been so simple for Yamaha to make this fact known in the user manual.............
docrog is offline
post #1017 of 1153 Old 05-29-2019, 08:33 AM
Liked: 0
Turns out it was a lightning strike, and its wasn't complicated for me to fix but it took a while changing components.
Originally Posted by Cleveland Plasma View Post
Nice So what was wrong with it, was it an easy fix?
Smart man, don't want to take a step back......
faulkster is offline
post #1018 of 1153 Old 05-29-2019, 08:34 AM
Liked: 0
Anyone have any ideas?
Originally Posted by faulkster View Post
Hey everyone new Yamaha owner here (long-time Pioneer Elite owner until now). This question may have been asked before, but I've been looking through the manual and threads here but still can't seem to find the answer I need.
I just pick up an RX-A1080 from a customer that said it wouldn't turn on. He scrapped the unit and I was able to repair it.
I have the unit in my bedroom with very little space. The only speaker I have at the moment is a single Mackie HR824 powered studio monitor (I have 3 of these in my main living room theater ). It has an XLR and 1/4" input.
I'm getting sound, but the issue is that multi-channel sound is being sent to the monitor so I get bits and pieces of the overall sound.
The question...is there a specific sound/output setting to simulate the front channels to a single speaker (not at all concerned with surround right now)? I'm using the RCA pre-amp output and going to the 1/4" input on the monitor.
post #1019 of 1153 Old 05-30-2019, 02:28 AM
ht guy's Avatar
Quoted: 195 Post(s)
Liked: 161
Party mode? (or is that only mono for stereo sources?)
ht guy is offline
post #1020 of 1153 Old 05-30-2019, 08:23 AM
docrog's Avatar
Liked: 361
After several P.M. dialogues with 2 helpful owners of both the Panasonic UB820/9000 UHD player and Yamaha RX-A3080/CX-A5200 I purchased a Yamaha RX-A3080 with the expectation that I would get Dolby Atmos from my UB820's Netflix app. I can report that, without any question, the UB820 does provide Netflix Atmos via this receiver/Pre-Pro combination.
I can't comment on whether or not the RX-A1080/2080 is capable of this outcome, but all previous generations of Yamaha AVRs were incapable of "unpacking" the DD+ codec as Atmos from the UB820/9000. As I had previously stated, this was solely a problem with previous Yamaha AVR decoding of certain DD+ Atmos "packages", and not specifically due to the app in Panasonic's current UHD players providing Netflix Atmos.
EDIT: Atmos is still unavailable for the UB820's Amazon Video app, with "Jack Ryan" only decoding DD 5.1 on my 3080.
Moscoe likes this.
docrog is offline
bluetooth headphones , yamaha 1080
