My AVR-X4000 has started shutting off randomly on me again. This time it is out of warranty. Also just downgraded from 7.2 down to 5.2 system.
What do you guy recommend for a 5.2 system with 2 HDMI inputs as an AVR?
I have a 2 channel parasound amp for the two fronts. Looking to get a 5 channel amp to power all speakers eventually (in the next 3-5 months). The room is at 3000 sq ft and speakers are all Polk (250Watt 8 ohm RTiA5, 200 Watt 8 ohm CSiA6, 150 Watt 8 ohm FXiA6) with two HSU subs. Use the AVR primarily for movies and some gameplay off xbox, little to none audio only.
I'm not interested in having all the future compatibility. Currently running a HTPC into a Panasonic Plasma tv. If I ever have to upgrade, i'll have to so a complete overhaul. Only interested in the minimum to keep my system running for 3-5 years. Also plan on getting some MiniDSP Dirac Live room correction added soon.
So to keep a system like this running I'm sure there are lots of options. Looking into primarily something reliable and high quality.
