AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Receivers, Amps, and Processors (https://www.avsforum.com/forum/90-receivers-amps-processors/)
-   -   Marantz 6012 - Need reviews (https://www.avsforum.com/forum/90-receivers-amps-processors/3031836-marantz-6012-need-reviews.html)
Sharan Pynda 12-04-2018 09:15 AM
Hi,
I have svs sb 12 subwoofer, svs ultra bookshelfs, svs ultra center speaker and klipsch rp 402s surround.
Will Marantz 6012 makes a major difference with the above i have or i need to go down to mid range receivers?
Any reviews for marantz 6012 ? Any other suggestions are welcome. Thanks !
jdsmoothie 12-04-2018 10:33 AM
The SR6012 is a mid-range AVR which will readily handle your speakers. It is also the lowest model that uses Audyssey MultEQ XT32.
teachsac 12-04-2018 10:36 AM
Best thing to do is read the user experiences in the official thread.
https://www.avsforum.com/forum/90-re...-s-thread.html
afrogt 12-04-2018 10:44 AM
compared to what? need a reference point.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
