Amplifiers, Buzz, Power Conditioners - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #1 of 66 Old 12-15-2018, 04:39 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
I have just received my first external amplifier, a Monolith 7X, and I have notice that I have a slight buzz coming from the speakers, which gets louder when the receiver is turned on.
To eliminate a ground loop issue, I disconnected the power every component in the system and the buzz is still there.
When I plug the Monolith into my Furman Elite-15 audio outlet, it reduces the buzz quite a bit. My concern is I have read that power conditioners can affect negatively audio performance. Should I worry about this? Is there a better solution?
For the record, I have about 30 light dimmers in my house, which can create some noise I believe.
Your help is the most welcome!
MAKE AUDIO GREAT AGAIN | Dedicated Sonus Faber HT 7.2.4 | FRONTS: Sonus Faber Venere 2.0 CENTER: Sonus Faber Venere Centre FRONT WIDES: Sonus Faber Venere 1.5 SURROUNDS: Sonus Faber Venere 1.5 TF/TR - ATMOS-DTS:X: Sonus Faber Venere Wall (4) | RECEIVER: Marantz SR7010 AMPLIFICATION: Monolith 7x200 | SUBWOOFERS: Dual 18" Dayton RSS460 Custom Build | Behringer iNuke 6000DSP | Velodyne SMS-1 DISPLAY: JVC D-ILA RS-46 w/ 128" 16:9 1.4 TREATMENT: Custom Bass Traps and Acoustic Panels (11)
jsgrise is offline
post #2 of 66 Old 12-15-2018, 05:44 AM
Mickey Mouse's Avatar
Quoted: 324 Post(s)
Liked: 169
probably it's not what you want to hear, but it's my honest opinion
if an amplifier is of such poor quality it produces a buzz and needs an additional power conditioner, I would through it away and buy something more decent...
Mickey Mouse is offline
post #3 of 66 Old 12-15-2018, 05:47 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Indeed, not really what I want to hear lol... I read many reviews before buying and the Amp is suppose to be dead quiet. ATI is a reputable company and make great stuff, I would expect a product free of buzz.
jsgrise is offline
post #4 of 66 Old 12-15-2018, 05:59 AM
Quoted: 324 Post(s)
Liked: 169
does it generate the buzz if you disconnect (shortcut) the input?
if yes it's poor quality or broken
if not you have to dig deeper to find the source
post #5 of 66 Old 12-15-2018, 06:00 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Yes it does.
jsgrise is offline
post #6 of 66 Old 12-15-2018, 06:06 AM
Quoted: 1012 Post(s)
Liked: 1261
The power amp has a three pin connector, the avr is probably double insulated and 2 pin. Try putting a cheater plug on the power amp (less than $1 at Walmart) to lift the ground and see if the sound goes away.
Sent from my SM-N920V using Tapatalk
shivaji and jsgrise like this.
Pradeep2 is offline
post #7 of 66 Old 12-15-2018, 06:12 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Something like this?
jsgrise is offline
post #8 of 66 Old 12-15-2018, 06:18 AM
BillP's Avatar
Quoted: 524 Post(s)
Liked: 456
If you have a ground loop and not a bad amp, can be fairly easy to deal with. First, make sure all of your AV equipment is plugged into the same outlet (not some equipment into one outlet and other equipment into a different outlet). And as you already have seen, your Furman will help. Yes, the Furman may slightly impact your amp's performance (although it probably won't), but shouldn't have an effect on any of your other equipment's performance. I wouldn't worry too much about it, although you can search for power conditioners (usually the more expensive ones) that claim they have one outlet designed for high-power amps. Another potential solution is a ground loop isolator. Ground loops often come from your TV cable as it enters your house (assuming you have cable such as Comcast, Fios, etc). Have you tried detaching the cable where it enters the house to see if that eliminates the buzz? If so, this isolator should help.
https://www.amazon.com/Viewsonics-VS.../dp/B0017I3K9M
Of course, if the cable is the problem, another solution is to have your cable company come and properly ground the cable where it enters your house. Lastly, the problem could be coming from your light dimmers (they are notorious for adding buzz to AV equipment). If none of the other solutions help, you could have an electrician come and isolate all your AV equipment to a dedicated line to your fuse box so that no lights are on the same line.
Hope this help. But also search ground loop on google for more information.
jsgrise, fill35U and biga6761 like this.
BillP is offline
post #9 of 66 Old 12-15-2018, 06:26 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Thank you for your help. I do not have a cable TV, my service (Bell Canada) comes from a pair bonding of 2 telephone lines. It is a fix until fiber to the home is installed in my neighbourhood.
I could try to disconnect the phone lines and see if it helps?
jsgrise is offline
post #10 of 66 Old 12-15-2018, 07:27 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
I have made a home made Cheater plug with an old power bar. The buzz is completely gone when the amp is running by herself. Very slight buzz when I turn on the Marantz SR7010, but much less than usual.
Pradeep2 and bdcody01 like this.
jsgrise is offline
post #11 of 66 Old 12-15-2018, 07:52 AM
Quoted: 53 Post(s)
Your Furman has a dedicated amp hook up and is of high quality. Glad to hear is you are getting this worked out. Pesky issues when you spend that much money and expect perfection. . Good luck
bdcody01 is offline
post #12 of 66 Old 12-15-2018, 07:57 AM
Dave-T's Avatar
Quoted: 1163 Post(s)
Liked: 560
The furman Elite 15-pfi has 4 high caps which are meant for subs and amps. The high caps are the plugs on the left next to the cable/satellite protection.
Dave-T is online now
post #13 of 66 Old 12-15-2018, 08:06 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Mine is not the PFI but the older model (see pic). So I should not experience lower audio quality? Going back and fort last night made me believe I was losing some soundstage when plugged into the Furman. Might be my mind playing me since I was tired...
jsgrise is offline
post #14 of 66 Old 12-15-2018, 08:07 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Thanks! Will tried that again.
jsgrise is offline
post #15 of 66 Old 12-15-2018, 08:22 AM
Dave-T's Avatar
Liked: 560
What model is it? it probably has at least one high cap on it
post #16 of 66 Old 12-15-2018, 08:32 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
It just says “Elite-15” on the front panel. I believe it is this unit reviewed by Audioholics: https://www.audioholics.com/power-co...urman-elite-15
jsgrise is offline
post #17 of 66 Old 12-15-2018, 08:56 AM
Espo77's Avatar
Quoted: 516 Post(s)
Liked: 226
Those light dimmers are awful sharing the same circuit as the A/V gear.
You can carefully check by shutting off one breaker at a time while noting what receptacles go with it. Try to make sure that the A/V gear is on its own circuit.
One of the best things I did for my system was have an electrician install dedicated circuits.
jsgrise, toddman36 and biga6761 like this.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #18 of 66 Old 12-15-2018, 09:34 AM
Espo77's Avatar
Quoted: 516 Post(s)
Liked: 226
...RFI and EMI are always trying to hitch hike a ride on your wires and cables, bringing on noise.
Keep power cords away from other wires. if speaker wire is longer than needed, don't coil it. The coiled wire can pick up nasty stuff and run it through the system as noise.
jsgrise likes this.
Espo77 is offline
post #19 of 66 Old 12-15-2018, 09:55 AM
Location: It looks like ML took his ball and went home. :)
Quoted: 105 Post(s)
Liked: 51
Electrical problems are really tricky to solve. Like you said, someone can be telling you their tales of whoa about how bad a component is, and then you find out that they have a dimmer hooked up to fluorescent lighting in the same room that could be causing all kinds of problems. Each person's case is different, and the components have different methods of shielding that gets rid of most, if not all, of the electrical interference problems. That being said, a cheap AVR could get rid of the noise, while an audiophile grade component happens to detect the noise due to the way the circuitry is designed. I've seen it happen in a lot of cases, but usually the problem is solved by finding a component with shielding that will get rid of a particular electrical interference. All amplifiers and preamplifiers are capable of picking up certain electrical interferences, depending on the users unique situation. Sometimes there is a solution that you just have to stumble upon in order to resolve.
Electrical interference noise is one of the trickiest problems to solve, and nothing is carved in stone as to what needs to be done to remedy the situations. Sometimes it's just trial and error that will remedy the situation, but if you want to practically guarantee an interference, put a lighting circuit in the same room as your sound system, and then hook a rheostat or dimmer up to that circuit. They are on different runs to the main panel, but the switches sometimes house both the lighting circuit wires and the wires that supply the outlets in the room that may share a common wire or a ground, or both.
jsgrise and biga6761 like this.
bootster is offline
post #20 of 66 Old 12-15-2018, 11:43 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Indeed, my system is currently on a dedicated circuit and still get some noise.
I will continue to investigate tomorrow when I have more time.
Thanks guys for all your help, it is greatly appreciated!
jsgrise is offline
post #21 of 66 Old 12-15-2018, 12:02 PM
nonstopdoc1's Avatar
Quoted: 536 Post(s)
Liked: 121
I was just going to start a new thread on my issues with hum/buzz and noticed yours. I am in the same boat. Few days ago, I added Monolith 3x200 to my system. Its hooked to a Yamaha AVR and both are powered by Monster HTS3600 MKII Powercenter. I have connected amp to the dedicated amp outlet on the powercenter.
I my case, everything works fine until I connect the speaker cable to center channel and I get loud hum in center and R speakers. The moment I disconnect center channel speaker cable, the hum goes away. I have tried to swap outlets on powercenter and swap cables but no benefit. I will try some of the tips mentioned in this thread. For now, I am just using L/R channels. Please share if you are able to find a solution.
jsgrise likes this.
My Build Thread
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | Denon AVR | QSC DPA 4.2 | ATI AT528NC | Procella P8/P5V | Revel C763L | Rythmik FV15HP x2
Living Room - LG OLED 65" | Yamaha 2060 | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia CC | Polk Surrounds | Monolith 12" Subs x 2
nonstopdoc1 is offline
post #22 of 66 Old 12-15-2018, 12:06 PM
Quoted: 536 Post(s)
Liked: 121
Does anyone know how can I ground the amplifier? There is a 'GND' outlet on the back which I am assuming can be used to ground the amplifier to resolve the issues.
My Build Thread
post #23 of 66 Old 12-15-2018, 12:07 PM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Funny, me too the buzz is a lot stronger in the Center channel. I thought it was because the speaker was more sensitive, but I could be wrong.
Please share your experiences on this thread
jsgrise is offline
post #24 of 66 Old 12-15-2018, 12:19 PM
Espo77's Avatar
Quoted: 516 Post(s)
Liked: 226
...Yes you can ground the units together, starting with the amp ground that is mentioned above.
Espo77 is offline
post #25 of 66 Old 12-15-2018, 01:10 PM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Do you connect the ground on the Monolith to a screw on the receivers rear panel?
jsgrise is offline
post #26 of 66 Old 12-15-2018, 01:11 PM
Quoted: 536 Post(s)
Liked: 121
Yes and what type of cable/wire do you use?
My Build Thread
post #27 of 66 Old 12-17-2018, 08:15 PM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
I could not get rid of the buzzing no matter what I did, so I tried to ground the receiver and amplifier together. Buzz is now gone like magic!
biga6761 and Pradeep2 like this.
jsgrise is offline
post #28 of 66 Old 12-17-2018, 08:42 PM
Quoted: 536 Post(s)
Liked: 121
Exactly how did you do that? Thanks
Sent from my SM-G950U using Tapatalk
My Build Thread
post #29 of 66 Old 12-17-2018, 08:47 PM
Espo77's Avatar
Quoted: 516 Post(s)
Liked: 226
Good news!
It appears that everything is now on the same ground.
Which makes me wonder if you have isolated grounding along with the dedicated circuits.
Espo77 is offline
post #30 of 66 Old 12-18-2018, 04:37 AM - Thread Starter
jsgrise's Avatar
Quoted: 685 Post(s)
Liked: 689
Attache a 14AWG (or larger) wire from the ground post on the 7X to the ground screw on the back of the receiver.
Good news!
There is something going on, I will investigate in the next days. But I am finally reassured!
nonstopdoc1 likes this.
jsgrise is offline
