Problem with Xbox One X Audio Setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-19-2018, 01:26 PM - Thread Starter
Liked: 0
Question Problem with Xbox One X Audio Setup
I am having trouble enabling 5.1 audio output on my Xbox One X. Whenever I select "Uncompressed 5.1" as output in my Xbox, I see the error as show in the photo. I can select Bitstream. But, it doesn't play anything on the rare 2 speakers. Also, after rebooting Xbox audio sets back to "Uncompressed Stereo".
Let me explain in detail how my setup is. I recently bought a Xbox One X and Samsung NU8000 UHD TV. Due budget constraints I am not currently ready to buy a A/V receiver (which would support 4K and HDR). I have 5.1 surround speakers in my living room. To avoid having to buy a new A/V receiver just to use my 5.1, I have set up things as below:
1) Xbox One X is connected by HDMI to the TV.
2) TV is connected to my current Onkyo TX-NR616 AV receiver by HDMI using ARC.
3) Onkyo connects to all 5 speakers as usual.
There are 2 possibilities here.
1) Problem between ARC connection between TV to Onkyo:
I tested this with Youtube app on TV. I ran the Dolby test video and I was able to hear distinct sound from all 5 speakers one by one. [Passed]
2) Problem between Xbox and TV:
a. At first I thought may be TV cannot process 1 HDMI input and 1 HDMI output at a time in full stream. So, I setup TV output to "TV speakers" and "Optical" instead of "HDMI RHID Speakers". But the problem persisted.
b. I changed my TV's audio input format from bitstream to PCM. Didn’t help.
Any idea what can I do to have Xbox output 5.1 output to TV? My Xbox to TV HDMI cable is 20 ft long. Could that be the reason? I am totally clueless now. Any help would be appreciated. Thanks.
paddy_pilani is offline
post #2 of 4 Old 12-19-2018, 03:18 PM
Rissross's Avatar
Quoted: 22 Post(s)
Liked: 4
As far as I know, hdmi doesn't have the bandwidth to send uncompressed 5.1 pcm and 4k video over arc.
Sent from my ONEPLUS A6013 using Tapatalk
Rissross is offline
post #3 of 4 Old 12-20-2018, 01:07 AM
Worf's Avatar
Quoted: 840 Post(s)
Liked: 567
The problem is arc. It can only do 5.1 if you send it an encoded signal. I believe the xbox has the ability to do this - you need to set the output as Dolby digital which will engage the xbox built in audio encoder.
You can't use uncompressed multichannel audio while using arc.
Worf is offline
post #4 of 4 Old 12-20-2018, 08:09 AM - Thread Starter
Liked: 0
I think you guys are right. I found this in Anynet+ (HDMI-CEC) section of the TV manual.
"To listen to 5.1 channel audio from an external device, connect the device to the TV via an HDMI cable and connect a 5.1
home theater system directly to the external device's digital audio output connector."
I will definitely try setting Xbox's output to Dolby Digital.
Other than that, looks like my option is to run an optical cable to my receiver.
Thanks for your help.
audio , hdtv , Onkyo , surround , Xbox
