Monoprice HTP-1 announced. (16ch, 9.1.6 Atmos Surround Sound Processor) - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 876Likes
post #421 of 1036 Old 05-04-2019, 08:02 PM
Quoted: 287 Post(s)
Liked: 148
If this thing is for real, it will be the motivation I need to re vamp the the theater. I hope this baby is signing by year end and I can get construction going again!
Marantz SR7010 - Emotiva XPA-3 Gen 3 - SeymourAV 16:9 Premier 130" XD - JVC DLA-RS540 - 7.2.4 - L/C/R DIY Fusion 15 Sentinel - Surrounds RSL CG3 - Ceiling Polk RC80i - Dual UM-18s in sealed 4 cu ft with bridged Crown XLS 2002s
klimo is offline
post #422 of 1036 Old 05-05-2019, 06:03 AM
Spizz's Avatar
Quoted: 511 Post(s)
Liked: 356
Originally Posted by MonolithGuy View Post
You will be able to control the brightness levels of the display and the power button LED.
We're trying to develop a rack mount solution, but there isn't a solid timeframe for it right now, but I do hear the concern.
Or send it to Middle Atlantic so they can make a custom face plate to add to their database so anyone can order it for their racks.
Spizz is offline
post #423 of 1036 Old 05-05-2019, 11:14 PM
Marc Alexander's Avatar
Quoted: 5486 Post(s)
Liked: 4989
Originally Posted by enricoclaudio View Post
I know most "advanced processors" are moving away from using OSD. In fact, Lonnie from Emotiva asked on the Lounge what were our thoughts about moving away from using OSD overlay on Emotiva processors as that would make their codec job easier and about 90% responded that if they did that, most customers will go another route.
It's partially your fault Enrico! Think of all of the headaches the HDMI w/OSD has caused for Emotiva and their owners. How can you abandon them and not trade-in for an RMC-1 or XMC-2? You helped make this bed.
J/K, I suspect they would be in the exact same place trying to develop a web or VNC interface.
gsr and llang269 like this.
Marc Alexander is offline
post #424 of 1036 Old 05-06-2019, 10:03 AM
Quoted: 58 Post(s)
Liked: 197
Originally Posted by Extreman View Post
Can we also have a picture of the rear, please?
The rear is incomplete on this unit. I don't think it would be of much benefit to show.
Extreman and llang269 like this.
Hobie
Monoprice - Monolith
MonolithGuy is offline
post #425 of 1036 Old 05-06-2019, 12:55 PM
ereed's Avatar
Quoted: 2307 Post(s)
Liked: 1627
Such a tease!
drh3b likes this.
Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1075 | Rotel RMB-1077 | Rotel RSP-1068 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
ereed is online now
post #426 of 1036 Old 05-07-2019, 04:28 AM
Frohlich's Avatar
Quoted: 2059 Post(s)
Liked: 2270
This one is definitely on my radar. Moving into a new house in August so hopefully the timelines will match up
Frohlich is offline
post #427 of 1036 Old 05-07-2019, 08:44 AM
Seraphic-'s Avatar
Quoted: 62 Post(s)
Really like what I am reading so far about this unit as someone who is also considering the RMC-1/RMC-1L line.
I like how this unit is including Auro3D, Dirac and fully differential/balanced XLR. Is there any confirmation if Dirac will run at 96khz or 192khz and if it uses the new Dirac 2.0 version?
Noticed in the Q/A on Monoprice's page that a Staff replied that IMAX Enhanced will not be supported. Is that set it stone or may change in future?
And doesn't IMAX Enhanced contain an "updated" DTS codec and is that at all related to DTS:Pro? Is DTS:Pro coming to this unit? If so, v.i firmware update or part of HDMI 2.1 upgrade?
Finally, does this unit have XLR L/R inputs or only toslink/rca? Was looking to use the ERC-4 which has XLR L/R outputs into the HTP-1.
Seraphic- is offline
post #428 of 1036 Old 05-07-2019, 09:03 AM
sdurani's Avatar
Quoted: 7260 Post(s)
Liked: 6300
Standard DTS:X decoding is used for IMAX Enhanced soundtracks (which are 7.1.4 channels). IMAX Enhanced is unrelated to DTS:X Pro (Pro just means more than 11.1).
batpig likes this.
Sanjay
sdurani is offline
post #429 of 1036 Old 05-07-2019, 08:25 PM
McLuvin's Avatar
Quoted: 354 Post(s)
Liked: 149
Controlling brightness levels and being able to black out completely are two different things. The Yamaha for instances dims but doesn’t allow to black out the display like @gsr listed. PLEASE PLEASE PLEASE offer a blackout option!!!!
This please!!
1) Ensure there's a setup option to disable the blue LED on the power button.
2) Ensure there's a setup option to turn the display off completely, turn the display on briefly when there's input from the user, and a mode that leaves the display on all the times.
McLuvin is online now
post #430 of 1036 Old 05-08-2019, 03:52 AM
Mashie Saldana's Avatar
Quoted: 1214 Post(s)
Liked: 1064
Any info what the physical size/weight is of this unit?
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is offline
post #431 of 1036 Old 05-08-2019, 01:40 PM
noah katz's Avatar
Quoted: 2021 Post(s)
Liked: 737
Originally Posted by theblackangus View Post
Is there going to be a feature to matrix front wides with front and side so there is always sound from them?
This would greatly enhance the attraction of the HTP-1.
With Dolby prohibiting DTS:Neural processing to get Front Wides on Dolby soundtracks, I'll likely go for a Lyngdorf MP-50, which allows matrixed wides for all sources.
Noah
noah katz is offline
post #432 of 1036 Old 05-08-2019, 03:01 PM
batpig's Avatar
Quoted: 4866 Post(s)
Liked: 5192
@MonolithGuy - a cool feature which somewhat relates to the comments above is the ability to have different speaker "mappings" saved as templates which can be quickly recalled for different surround modes. This is a common feature with higher priced SSP's like Datasat or Trinnov and greatly increases the flexibility of how the speaker layout is used.
Some examples of use cases I've seen people deploy with other processers:
- Being able to designate the height speakers as "Top Front + Top Rear" for Atmos playback, but having a separate template where they are designated "Front Height + Rear Height" for DTS:X or Auro3D playback.
- If you have a x.x.6 layout being able use a single pair of "Top Middle" speakers remapped as a dual mono array for the Auro3D "Top Surround" speaker (aka "Voice of God").
- If wide matrixing is not possible, having a saved template with the Surrounds + Wides designated as an array for SL/SR signals so the speakers are still used to broaden the surround immersion, while still having the standard template that can be used for native Atmos tracks
- Bonus points if the above scenario can happen with templates saving more detailed settings like level/delay... I know of Trinnov users who have a template where they feed the Front Wide speakers a copy of the FR/FL stereo signal but with some extra delay and reduction in level so they are sort of producing a synthesized lateral reflection to increase envelopment and keep those speakers in play vs. sitting there silent.
(also if you need another beta tester down the road in San Diego, I wouldn't say no )
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #433 of 1036 Old 05-08-2019, 03:31 PM
Quoted: 58 Post(s)
Liked: 197
Roughly 5.75 inches tall, 17 inches wide, 6.5 inches deep. The weight is being finalized as we finish the linear power supply.
Hobie
post #434 of 1036 Old 05-08-2019, 03:33 PM
sdurani's Avatar
Liked: 6300
That's a very generous use of the word "matrixed", considering that there is no matrix processing going on. Instead, each Front channel and Side channel are copied to their respective Wide speaker. Sending the same channel to two speakers isn't matrixing any more than a Y-splitter is.
Sanjay
sdurani is offline
post #435 of 1036 Old 05-08-2019, 03:37 PM
Liked: 1064
With all the special request posted in this thread the RMC-1 will be out of beta long before the HTP-1 will see the light of day.
post #436 of 1036 Old 05-08-2019, 03:38 PM
Oppo Beta Group
RichB's Avatar
Quoted: 1969 Post(s)
Liked: 1431
6.5 inched deep is really amazing!
If you in the marker for veteran beta testers, the Oppo beta group comes highly recommended
They are discreet, experienced, and bathe regularly.
- Rich
gsr, giomania, llang269 and 2 others like this.
Oppo UPD-205 x 2 | UPD-203 | Sonica DAC | Emotiva XMC-1 (v3) | Revel Salon2s, Voice2, Studio2s | Benchmark AHB2 x 4 | ATI AT522NC | Velodyne HGS-15 | LG 77C9 | Lumagen 2020 | HDFury Vertex x 2
RichB is online now
post #437 of 1036 Old 05-08-2019, 03:41 PM
Liked: 1064
Thanks, that will be a perfect fit on my AV stand.
I hope your UK branch will stock these in the future.
Phil1975m likes this.
post #438 of 1036 Old 05-08-2019, 04:03 PM
rec head's Avatar
Quoted: 296 Post(s)
Liked: 268
I'll avoid the RMC-1 jokes but all the stuff in @batpig s 's post (for example) could be included in the future. Get the unit stable including Dirac shipping within a couple months of the scheduled release and it will be a winner.
rec head is offline
post #439 of 1036 Old 05-08-2019, 04:41 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1936 Post(s)
Liked: 2326
That almost sounds like a mistake... 6.5 inches doesn’t allow much room for circuit boards and a power supply.
Well, most of us on the Oppo beta team bathe regularly.
giomania likes this.
gsr is offline
post #440 of 1036 Old 05-08-2019, 04:51 PM
Frohlich's Avatar
Liked: 2270
That 6.5 has to be a typo, it actually would look silly at 6.5. The original first post in this thread said 12" for depth. The pictures certainly make it look closer to 12 or maybe 16.5?
First post says:
Chassis
Size: 17.1”W x 5.7” H x 12” D
Front panel touch screen 4.3 inch diagonal, RGB 480 × 272
Frohlich is offline
post #441 of 1036 Old 05-08-2019, 06:06 PM
Gooddoc's Avatar
Quoted: 3774 Post(s)
Liked: 3380
I think a Kuerig attachment should be a release priority. I can't stay awake till the end of most movies. What good is a processor I'm not conscious to appreciate? (Oh, and it should have the new latte frothy thingy included)
Gooddoc is offline
post #442 of 1036 Old 05-08-2019, 06:21 PM
Liked: 4989
In pro-audio this is called matrix mixing. ADI and StormAudio use the same term. They aren't pulling the wool over anyone's eyes. That's just what it is.
From the Lyngdorf MP-50 manual:
Matrix-Generated Extra Channels
The decoder in the device will decode a maximum of 12 discrete channels. However, for Atmos setups it will be possible to use up to four additional speaker positions which will then be generated in the switch matrix. Using the 12 discrete channels, the largest possible setups are either 5.1.6, 7.1.4 or 9.1.2. With the 4 extra positions, setups up to 9.1.6 are possible. When creating the larger setups, the switch matrix can generate Front Wide positions by mixing together Front channels with Surround channels and it can create Top Middle positions by mixing together Top Front and Top Rear channels. In the maximum possible example of 9.1.6, the decoder will use the 12 discrete channels for L, R, LS, RS, C, LFE, LRS, RRS, LTF, RTF, LTR and RTR.
• LW will then be generated as a mix of L and LS
• RW as a mix of R and RS
• LTM as a mix of LTF and LTR
• RTM will be a mix of RTF and RTR.
post #443 of 1036 Old 05-08-2019, 07:25 PM
gdfein's Avatar
Quoted: 127 Post(s)
Liked: 52
Not to take anything from the suggestions above but I don’t think this unit (and it’s ATI cousin) are targeting the same AV enthusiast demographic as the Altitude 16/32 does for price point.
Even the Alt16 is more than $12k and talking $20k plus for the Alt32-16. For the sub $4k target this is pointed for those are different customers, imho. I say this as a follower of both threads. In this thread I’m a future customer. In the Altitude thread I’m a dreamer/window shopper.
gdfein is online now
post #444 of 1036 Old 05-08-2019, 07:50 PM
Archaea's Avatar
Quoted: 3899 Post(s)
Liked: 3693
You must be new to Emotiva.
gsr, giomania, Stereodude and 6 others like this.
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is online now
post #445 of 1036 Old 05-09-2019, 07:14 AM
OsoSolitario's Avatar
Quoted: 105 Post(s)
Liked: 68
Great to read that finally we'll see a linear power supply onboard against an ordinary PSU one (less audio oriented)!!
This HTP-1 seems more and more promising!!
OsoSolitario is offline
post #446 of 1036 Old 05-09-2019, 07:29 AM
Jermmd's Avatar
Quoted: 13 Post(s)
I'm sorry if this has already been discussed but I searched and didn't see it. I haven't read all 15 pages of this thread.
I wish this processor would offer standard outputs in addition to XLR especially for the subwoofers. I have the Monolith 7 amp which has XLR inputs but my subwoofer amp doesn't have them and I love my sub (an old ACI subwoofer)! I suppose I can always buy XLR to RCA cables.
Joey M.
Joe M.
Jermmd is offline
post #447 of 1036 Old 05-09-2019, 07:32 AM
Jermmd's Avatar
Quoted: 13 Post(s)
Even $4k is a bit of a stretch for me. Half that would be more of my ballpark but you never know.
Joey M.
Joe M.
Jermmd is offline
post #448 of 1036 Old 05-09-2019, 07:45 AM
Oppo Beta Group
RichB's Avatar
Liked: 1431
Performance need not be measured by the pound.
A switching power supply can match and even out-perform a linear power supply when properly implemented.
BenchmarkMedia products provide reference performance using switched supplies.
Any specifications on output voltage, signal to noise, and distortion (with and without processing enabled)?
- Rich
RichB is online now
post #449 of 1036 Old 05-09-2019, 04:11 PM
Quoted: 407 Post(s)
Liked: 293
Has it ever been stated if HTP-1 is a fully balanced design? As the real competition is going to be the RMC-1L (if they ever get the firmware stable and release it) vs HTP-1 most likely for me (as they are at the same price point), and the thd advantage of running the dacs in mono is a compelling feature.
That said mono balanced isn’t everything. I’m just curious. It would actually be an interesting comparison as if I remember right HTP-1 has the dac model above the rmc which would negate some of the noise advantages of running the dacs in mono mode. Then it would all come down to power supplies and firmware :P
amnesia0287 is offline
post #450 of 1036 Old 05-09-2019, 06:22 PM
juanchibiris's Avatar
Quoted: 58 Post(s)
Liked: 47
The Description says ‘16 Balanced XLR Connectors (primary)’ for the audio output - are all of these truly balanced?
A shopper on Feb 19, 2019
BEST ANSWER: Yes, fully differential and balanced.
Reply Inaccurate New User U Staff on Feb 19, 2019
According to Q&A in the monoprice web
juanchibiris is online now
