Monoprice HTP-1 announced. (16ch, 9.1.6 Atmos Surround Sound Processor) - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1918Likes
post #61 of 2108 Old 01-09-2019, 09:52 PM
Quoted: 27 Post(s)
Liked: 5
Originally Posted by mavromatis View Post
Glad you asked that — I’m in the same boat... know they are completely different beasts and the Marantz 8805 is probably more similar, plus the unit isn’t even out yet, and this is based on hypotheticals... which one is better... I’m still leaning towards x8500 given it’s known?
I tend to agree. The Denon 8500 has a slight lead for me right now over the Marantz 8805. However, this one looks very intriguing to me.
Jdogger7 is offline
post #62 of 2108 Old 01-10-2019, 12:12 AM
Jerry Bruckheimer Fan's Avatar
Quoted: 199 Post(s)
Liked: 101
"Q: What is the max unclipped Voltage output from the balanced outputs?
A: The max unclipped output is 24dBu (12Vrms)."
The quote is from Audioholics.
That's pretty good in my book. I don't know any amplifier with an input sensitivity higher than 12Vrms.
Jerry Bruckheimer Fan is offline
post #63 of 2108 Old 01-10-2019, 01:31 AM
Mashie Saldana's Avatar
Quoted: 1371 Post(s)
Liked: 1252
I take 16ch processing and Dirac Live over 14ch processing and Audyssey any day.
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is offline
post #64 of 2108 Old 01-10-2019, 03:05 AM
UKenGB's Avatar
Quoted: 52 Post(s)
Seems to me that 9.2.6 is the optimum layout, but let’s restrict ourselves to the 16 channels available which would allow 9.1.6. So that requires 15 channels of amplification. Monoprice only seem to offer up to 11 channels. Does anyone actually make a 15 channel power amp? Or is one expected to have to use multiple power amps?
Even if only having 7.2.6, that still has 13 channels that need a power amp. Any 13 channel amps?
UKenGB is offline
post #65 of 2108 Old 01-10-2019, 04:15 AM
Liked: 1252
For 13 speakers you can drive them with a single 13ch Emotiva amp like this: https://emotiva.com/collections/amps...14844442542123
The max number of channels you can get from the Emotiva modular amps are 14.
post #66 of 2108 Old 01-10-2019, 04:23 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 2071 Post(s)
Liked: 2576
Why does the Denon 8500 have a slight lead over the Marantz AV8805 for you? The answer to that question will very likely help you decide if the Denon 8500 makes more sense for you than this Monoprice pre-pro. The HTP-1 is going to be a lot more similar to the AV8805 than it is to a Denon receiver as you will need to add external amps to either the AV8805 or HTP-1 and the feature sets of the 2 pre-pros are going to be more similar (other than the number of channels supported).
In general, I'd agree with that, but there's also the question of overall quality of the unit; things like the DAC implementation, build quality, etc. Assuming the HTP-1 is a slightly stripped down version of the ATI ATP16, which is based on the Datasat LS10, it should be very good.
Most people end up with at least 2 power amps. Even with digital amp modules, much beyond 7 channels starts to make for a really large and heavy box if you want decent power output for each channel. But this is a big consideration if the budget is somewhat limited or space is tight as AVR's can offer excellent value, take up less space than a pre-pro and separate amps, and can get surprisingly close to the performance of separates. Consider what your speakers need for amplification as part of this - efficient speakers (like Klipsch, for example), don't require as much power as less efficient speakers.
Swoosh830 likes this.
gsr is offline
post #67 of 2108 Old 01-10-2019, 05:04 AM
Stereojeff's Avatar
Quoted: 252 Post(s)
Liked: 162
GSR:
The prepro is not based on the LS10. The Datasat uses multiple SHARC processors. The Monoprice has a single (new) TI DSP.
Jeff
Stereojeff is offline
post #68 of 2108 Old 01-10-2019, 05:31 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 2576
Hi Jeff - are you saying the ATI or the Monoprice (or both...) is not based on the Datasat LS10? Not sure what the different DSP's actually mean for the feature set and overall capabilities of the resulting product. A newer single DSP with sufficient horsepower could be as capable as older multiple chips, for example. It could also mean that the basic feature set is very similar, but the Monoprice has less room for future expansion. I believe you mentioned in the ATI ATP16 thread that they've changed the design direction somewhat, but it's not clear if the final product will be heavily based on the Datasat LS10, something amounting to a next generation LS10, or a radically different product.
But either way, in looking at the back panel of the Monoprice, there's clearly significant influence from the Datasat LS10. We'll have to wait and see what the actual product turns out to be; just because it looks similar doesn't mean the DAC implementation is as good, for example.
No matter what the final products end up being, I'm glad I went with a Marantz AV8805 for now. The ATI and Monoprice options aren't available yet and the Emotiva RMC1 is kind of a mess at the moment. I'll sit back and see how things shake out - if one of the 3 (ATI, Monoprice, or Emotiva) is a clear upgrade over the Marantz, has no major operational issues, and the price is reasonable, I will consider switching.
gsr is offline
post #69 of 2108 Old 01-10-2019, 05:55 AM
Stereojeff's Avatar
Quoted: 252 Post(s)
Liked: 162
To be completely clear, I retired from ATI in 2017 and am no longer involved in their sales, product development or PR. I do know key personnel at Monoprice and ATI and made a friendly visit to their booths to say hello. I learned a little about both processors during my visit but as I am not actively in the processor market I did not make intensive inquiries.
The physical layout of the new ATI and Monoprice processors certainly resembles the LS-10. There are only so many places one can put 16 XLR connectors and a bank of HDMI's. However I do not believe it is appropriate to assume the internals are similar as we know the LS-10 is several years old and the new processors use radically different DSP solutions.
However, knowing Morris and his development team quite well, I believe we can assume any products emanating from this series will be top performers.
Jeff
post #70 of 2108 Old 01-10-2019, 05:59 AM
Jawaburger's Avatar
Quoted: 235 Post(s)
Liked: 230
Don't need balanced if you can't hear noise.
My Denon x7200wa and Sherbourn 7-350PA combo (RCA to XLR connection) was made COMPLETELY silent by a Panamax M5400-PM power filter/voltage regulator.
I've had a tiny bit of hiss you could hear from the combo from about <2' away until the last month when I bought the Panamax. Now I can walk up to the speaker and not hear it. I don't have balanced on the Denon.
Yeah, but the Monoprice Pre/Pro only has XLR outs, so...
Sharp LC-80LE844U | Marantz BD8002 | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | PSA MTM 210T (FL/FR) | PSA MTM 210C (Center) | Phase Tech PC 3.1 (SL/SR/SB) | Dual PSA S1811 Subs
Jawaburger is offline
post #71 of 2108 Old 01-10-2019, 06:18 AM
Stereojeff's Avatar
Quoted: 252 Post(s)
Liked: 162
Originally Posted by Molon_Labe View Post
Jeff,
Am I reading between the lines that this may be an updated LS-10?
Not between my lines. I have no special knowledge of these processors beyond what I have already written.
Jeff
Molon_Labe likes this.
post #72 of 2108 Old 01-10-2019, 06:43 AM
madhuski's Avatar
Quoted: 1559 Post(s)
Liked: 1019
any word from CES if the end user can do their own Dirac calibrations?
madhuski is offline
post #73 of 2108 Old 01-10-2019, 06:59 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 2576
That really isn't an issue as XLR to RCA adapters are readily available.
Jeff,
Just to be clear, I don't want to put words in Jeff's mouth here and given the limited info that's available at this point, most of us are just making wild guesses and speculating here. That said, I suspect it's likely that the ATI ATP16 is something along the lines of a LS-10 replacement (LS-10V2?) and the Monoprice HTP-1 will be a lower cost version with either fewer features or a somewhat lower end DAC implementation, somewhat akin to the Monoprice Monolith amps which are also made by ATI. I guess the big question here is if all 3 of these (LS-10, ATP16, and HTP-1) share the same product design and engineering team, which would make perfect sense with ATI buying out Datasat.
I suspect it's way too early to get answers to this sort of question, but I think it's pretty unlikely that a product sold by Monoprice would require a dealer visit for a calibration as that really wouldn't make much sense.
gsr is offline
post #74 of 2108 Old 01-10-2019, 06:59 AM
J J A's Avatar
No need for legacy inputs on something like this IMO.
I have just one system, I have don't have a separate 2-channel audio room. With all the XLR outputs I'm disappointed it doesn't have a single set of XLR stereo inputs and probably no "pure audio" unprocessed no-video path. But nobody seems to be doing that anymore.
J J A is offline
post #75 of 2108 Old 01-10-2019, 07:11 AM
Jawaburger's Avatar
Quoted: 235 Post(s)
Liked: 230
Marantz does, if you get their 8805 processor!
post #76 of 2108 Old 01-10-2019, 07:15 AM
Jawaburger's Avatar
Quoted: 235 Post(s)
Liked: 230
Very true, you can get XLR to RCA cables direct from Monoprice, which I use for my subs since they don't have XLR inputs on them. Thank you for the reminder.
post #77 of 2108 Old 01-10-2019, 07:32 AM
Quoted: 27 Post(s)
Liked: 5
[QUOTE=gsr;57411588]Why does the Denon 8500 have a slight lead over the Marantz AV8805 for you? The answer to that question will very likely help you decide if the Denon 8500 makes more sense for you than this Monoprice pre-pro. The HTP-1 is going to be a lot more similar to the AV8805 than it is to a Denon receiver as you will need to add external amps to either the AV8805 or HTP-1 and the feature sets of the 2 pre-pros are going to be more similar (other than the number of channels supported).
Thanks for the question. I will be posting the same question later on which I should go with between the Denon 8500, Marantz AV8805, and Anthem AVM 60. Would love your input when I do. Seeing new options right around this corner like this makes me interested in possibly waiting. I am in no way a pro at this, so trying to make sure I make the right choice since it is a pretty big investment.
So far, I have a hard time seeing the value of spending another $3k+ on the Marantz (since I also need to add amplifiers) since I don't seem to be getting much more than the Denon. I could always add one amp to the Denon to power some of the speakers in the future and still use the other ones for atmos. I am still getting Audessey in both (and from what I hear it is not the best). This one gets more interesting due to Dirac since I hear great things about it. If I can do it myself fairly easily with a machine like this, then it may be worth the extra cost if it truly works. I may be using faulty logic, so feel free to tell me if I am!
Jdogger7 is offline
post #78 of 2108 Old 01-10-2019, 07:45 AM
Molon_Labe's Avatar
Quoted: 3582 Post(s)
Liked: 4383
Yes, Dirac Live truly works and in my opinion is head and shoulders above Audyssey because it corrects both the frequency and impulse response.
RUR and Th601 like this.
Molon_Labe is offline
post #79 of 2108 Old 01-10-2019, 07:51 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 2576
First things first - you need to decide on a budget. That alone may make the choice easy for you as a pre-pro plus amps is pretty much always going to cost more than a receiver for comparable quality. But you need to decide what your short and long term goals are, consider what the rest of your system consists of, and so on. A few things to consider:
  • I have no idea what you have, but if you've got relatively lower end speakers, it doesn't make sense to spend extra money on a pre-pro and amps instead of a receiver. You won't be able to appreciate the better sound quality from the better electronics if your speakers aren't up to the task. You'd be better off upgrading the speakers and going with a lower cost receiver. There is, of course, the option of upgrading things out of order; just don't spend big bucks on electronics if never intending to get speakers that can take advantage of it.
  • Even if Dirac can be calibrated by the user, it's probably going to be more difficult than doing your own Audyssey calibration. If you aren't very technical, this would be an important consideration.
  • The extra cost for the pre-pro + amps compared to a receiver isn't as much about tangible things like additional features as it is about better sound quality. The only tangible feature difference you're really going to see is something like support for more channels. But support for the latest and greatest HDMI and HDCP features and most other checklist items should be pretty much the same either way.
  • A larger company like Denon / Marantz is typically going to have more of the flashy checklist items and extra features than a smaller company like ATI. But keep in mind that some of those items (such as HEOS, just to pick an example) can be added with external boxes (again, HEOS would be an example of that). Given the choice, I would choose to omit some of the flashy extra features that can be added on with extra boxes in favor of things like a better DAC implementation.
gsr is offline
post #80 of 2108 Old 01-10-2019, 07:56 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 2576
If you have a moment, please fix the quote in your post to make it clear that I didn't write the text you responded to.
gsr is offline
post #81 of 2108 Old 01-10-2019, 08:02 AM
Molon_Labe's Avatar
Liked: 4383
Sorry about that man, I didn't realize there was an additional quote bracket in there when I quoted the post.
gsr likes this.
post #82 of 2108 Old 01-10-2019, 08:06 AM
hogues's Avatar
Quoted: 128 Post(s)
Liked: 97
I would love to know if Monoprice will be offering any other pre/pro or receiver (didn't see anything in the articles that I read). I'm looking for a DIRAC solution but only need 5.2.4. I don't want emotiva and am wary about NAD and the others. I would have a bit more confidence buying from Monoprice.
hogues is offline
post #83 of 2108 Old 01-10-2019, 08:09 AM
Molon_Labe's Avatar
Liked: 4383
My NAD has been trouble free. Hold your nickles and send me a friend request because I will be selling my 777v3 whenever the Monoprice or Emotiva goes prime time and the bugs are sorted.
hogues likes this.
post #84 of 2108 Old 01-10-2019, 08:42 AM
J J A's Avatar
Oh yeah, thanks. And I guess it's not much more $$$ than the HTP-1. My Onkyo 5508 has died and I was hoping for something in that class (price range).
J J A is offline
post #85 of 2108 Old 01-10-2019, 09:00 AM
Quoted: 1361 Post(s)
Liked: 801
This one has my attention. On paper it seems like the right mix of features and price. ATI is also more likely to get the basics (bass management, for example) than the Emotiva folks. Based on history I don’t trust them to know what they’re doing. Very interested to see the UI and final features.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #86 of 2108 Old 01-10-2019, 10:15 AM
Quoted: 27 Post(s)
Liked: 5
Given the choice, I would choose to omit some of the flashy extra features that can be added on with extra boxes in favor of things like a better DAC implementation.[/LIST]
Good input gsr. Thanks. I sold my entire system with my house and am not building from scratch again, so have a lot of work to do. I did keep the B&W CM10 S2 left, right, and center. Thanks again for the input.
Jdogger7 is offline
post #87 of 2108 Old 01-10-2019, 10:21 AM
Quoted: 27 Post(s)
Liked: 5
Meant to say I am "now" building from scratch!
Jdogger7 is offline
post #88 of 2108 Old 01-10-2019, 11:12 AM
batpig's Avatar
Quoted: 5061 Post(s)
Liked: 5567
Which would you rather have? Denon 8500 or this new one? I know it is a little apples to oranges, but I am in the process of upgrading, and not sure I want to spend the money on the 8500 if I just want to buy something else in 6 months. I narrowed it down to the Denon 8500 over the Anthym Pre/Post but this one now has me thinking. Thoughts?
Others have said it already, but this is WAY apples to oranges. When you factor in the extra amplification these come in at totally different price points. Conservatively you're probably going to have to spend at least another $2500+ on amplification with a 13-15ch pre/pro (e.g. a Monoprice Monolith 9ch amp for $2K for the 9 floor speakers and $500 for a cheap 7ch amp to run the overheads).
So you shouldn't really be cross-shopping those at all, rather the first question you need to answer is do you want a receiver or full separates?
If the the answer to that question is separates, then you are comparing the Monoprice to the Marantz 8805 not the Denon 8500.
Then secondarily you want to decide how many channels you want. The Anthem options are great and ARC is well reviewed but they max out at 11ch solutions.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #89 of 2108 Old 01-10-2019, 12:28 PM
loudogp250's Avatar
Any thoughts on the Monolith HTP-1 paired with the Outlaw Model 7000x? This might be a nice setup.
loudogp250 is offline
post #90 of 2108 Old 01-10-2019, 12:51 PM
batpig's Avatar
Liked: 5567
Just in case people missed it, this Audioholics article from yesterday includes an interview with Hobie Sechrest, Business Unit Manager of Monoprice, about the HTP-1: https://www.audioholics.com/av-pream...monolith-htp-1
gsr, giomania, COACH2369 and 4 others like this.
Setup Guide and FAQ
batpig is offline
