NAD Masters M10 BluOS DAC/Amp with Dirac Live at CES 2019 - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 132Likes
post #331 of 350 Old 07-21-2019, 11:05 AM
NottsMFC's Avatar
Liked: 4
Originally Posted by pippo de clown View Post
Could anyone check this.
With SACD FILES 24/88,2 from HDtracks i'll get a distortion in the right loudspeaker.
Several weeks ago I had crackling from my right speaker's tweeter when listening to a couple of MQA tracks on Tidal, 1 was In Degrees by Foals, can't remember the other. I rebooted the M10 & was fine after.
Not sure if related to your issue.
NottsMFC is offline
post #332 of 350 Old 07-21-2019, 11:17 AM
Liked: 0
Oke'
Can you tell me how to reboot the M10
pippo de clown is offline
post #333 of 350 Old 07-21-2019, 11:34 AM
NottsMFC's Avatar
Liked: 4
Oke'
Not at home but in the app, settings, help. Think option to reboot is there but will check when back home.
NottsMFC is offline
post #334 of 350 Old 07-21-2019, 01:41 PM
NottsMFC's Avatar
Liked: 4
Oke'
Not settings. Main menu, Help, Diagnostics. Reboot button is at bottom.
NottsMFC is offline
post #335 of 350 Old 07-21-2019, 10:03 PM
Liked: 0
Thank you!
post #336 of 350 Old 07-24-2019, 01:32 PM
Liked: 3
Hey
To follow up on this, directly from NAD engineering:
“The displayed Temperature Left/Right readings are not outer casing or enclosure temperature measurements. The temperature shown is actually the internal temperature measured along the amplifier core/FETs sections which are considerably high. A temperature reading up to 79C is normal while 80C to 90C is considered warm and still normal. Anything above 90C will lead to the unit going to protect mode with the unit recovering when the temperature reading goes down to 78C.
In summary, your M10 is operating correctly. We hope this information is reassuring and helps to remove any concerns.“
markrubin and NottsMFC like this.
lyncks is offline
post #337 of 350 Old 08-06-2019, 12:03 PM
NottsMFC's Avatar
Liked: 4
Should the proximity sensor be working on the M10? It doesn't on mine but in this review it's stated that was working.
https://www.hifinews.com/content/nad...ming-amplifier
KenM10759 likes this.
NottsMFC is offline
post #338 of 350 Old 08-08-2019, 01:38 AM
NottsMFC's Avatar
Liked: 4
Is anyone able to check if this is working on their M10 please & let me know? I'm concerned I may have a faulty unit as it's definitely not working on mine.
I read that it would be activated via a firmware upgrade at some point but not sure if has happened or not. In the review I quoted it sounds like was working on the test unit.
NottsMFC is offline
post #339 of 350 Old 08-08-2019, 03:14 AM
KenM10759's Avatar
Quoted: 3376 Post(s)
Liked: 1862
I've never known any of them to have a proximity switch work in the way you might expect. Mine requires even the lightest imaginable touch, but it DOES need to have contact.
NottsMFC likes this.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Office: NAD M10, KEF LS50, KEF Kube 10b, Pro-Ject RPM1 TT w/ Ortofon 2M Red. Guest room: Hafler 300 L-R, KEF Reference Model 100 center, KEF iQ10 surrounds, modded M&K V-90 sub, Bluesound Vault 2.
KenM10759 is online now
post #340 of 350 Old 08-08-2019, 03:23 AM
NottsMFC's Avatar
Liked: 4
Thanks Ken. In the review he suggests the screen changes as he walks towards it. Like you my screen does nothing unless contact is made.
NottsMFC is offline
post #341 of 350 Old 08-09-2019, 07:26 PM
Quoted: 16 Post(s)
can anyone help me
i have calibrate my loudspeakers with the mobile dirac app.
How do i get the nad dirac curve in my M10.
I want more bass
Thx
You can download the NAD curve here: https://nadelectronics.com/dirac-live/
I'm not sure how to load it from the dirac mobile app, when clicking the load target curve option in the settings, it doesn't open a file explorer. But from the desktop app it's possible to load it.
basketcase14240 is offline
post #342 of 350 Old 08-10-2019, 10:57 AM
SpeedDemon's Avatar
Quoted: 134 Post(s)
Liked: 73
The NAD curve is a good starting point, but I recommend a steeper decreasing slope so that it returns to 0db by about 90hz-100hz. I enjoy the warmth from the NAD curves added lower bass, but find the added bass from 100hz to 150hz to sound too boomy.
Spoiler!
SpeedDemon is online now
post #343 of 350 Old 08-12-2019, 07:07 PM
Quoted: 16 Post(s)
Thanks I'll give that a try. I'm loving this amp so far guys! The Roon endpoint and BlueOS app are great! One small thing..sometimes when I get home..the blueos app isn't picking up the M10 even after closing the app. I'll restart my phone and then it sees it. Any other tricks to fixing this besides having to restart the phone?
post #344 of 350 Old 08-12-2019, 07:31 PM
KenM10759's Avatar
Liked: 1862
That's strange. My Google Pixel never loses it or any of the two other Bluesound/NAD devices on my network. Neither does my cheap Insignia Android tablet.
If you haven't, make sure your phone is connected to your wireless network. That would be the primary reason for devices not showing up.
post #345 of 350 Old 08-26-2019, 01:15 PM
Liked: 0
Nobody notice with sacd rips and Dirac on,there is some crackling from the right loudspeaker ??
post #346 of 350 Old 09-04-2019, 04:27 AM
flax's Avatar
Quoted: 184 Post(s)
Liked: 290
Dirac enabled NAD M10 has been awarded as best smart amplifier by EISA:
https://www.eisa.eu/awards/nad-m10/
About EISA awards:
https://www.eisa.eu/faq-rules/
Flavio
Warning: My posts might be biased even if in good faith, I work for Dirac Research :-)
flax is offline
post #347 of 350 Old 09-04-2019, 02:05 PM
KenM10759's Avatar
Liked: 1862
About EISA awards:
Flavio
LOL....the M10 won all kinds of awards from me the moment I saw it, more when I bought it minutes later, and more when I heard it at home!
SpeedDemon likes this.
post #348 of 350 Old 09-06-2019, 06:11 PM
tonygeno's Avatar
Quoted: 372 Post(s)
Liked: 132
Does Dirac Live still work when using the M10 as a preamplifier? In other words, if I use the pre-outs to a power amp to get more power, can I still run Dirac Live with the speakers attached to the power amp?
Tony
In search of the Holy Grail.
tonygeno is offline
post #349 of 350 Old 09-06-2019, 06:42 PM
tonygeno's Avatar
Quoted: 372 Post(s)
Liked: 132
I tested it, and it seems to apply the Dirac presets even through the analog outs of the M10.
Tony
tonygeno is offline
post #350 of 350 Old 09-10-2019, 05:33 PM
nexus99's Avatar
Quoted: 167 Post(s)
Liked: 72
This is NAD talking about their M10 at RMAF 2019:
JDM World: https://www.youtube.com/jdmworld
GSG Full Marty Build: https://youtu.be/-U1deD_0j9c
UM18-22 Sealed Subwoofer Build: https://youtu.be/7ifac8Rh8gk
nexus99 is offline
ces 2019 , dirac live , nad m10
