New IMAX Enhanced Partners and Content Announced - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 96Likes
post #31 of 99 Old 01-19-2019, 09:36 AM
tbaucom's Avatar
Quoted: 401 Post(s)
Liked: 115
Originally Posted by tbaucom View Post
How will this work in conjunction with room eq like audyssey? Audyssey is already attempting to shape a 12 dB per octave roll off that crossover that gets set in the avr.
Should have read further. You explained there is a custom audyssey curve in a later post.
tbaucom is online now
post #32 of 99 Old 01-19-2019, 10:07 AM
sdurani's Avatar
Quoted: 7165 Post(s)
Liked: 6176
Audyssey doesn't do bass management, just EQ. The crossovers are handled by the receiver or pre-pro. The receiver's 12dB per octave high pass is combined with a 12dB per octave high pass in the soundtrack to end up with a 24dB per octave high pass to the speakers at 70Hz. This mimics the 4th order (24dB per octave) high pass at 70Hz used in IMAX theatres. Bass below that ends up in the subwoofer. The custom Audyssey curve is for the overall frequency response (target curve), not the slope of the crossover.
audiofan1 likes this.
Sanjay
sdurani is offline
post #33 of 99 Old 01-19-2019, 10:31 AM
audiofan1's Avatar
Quoted: 2314 Post(s)
Liked: 2872
Thanks sdurani for all you do! time to give you Guru status! Here here
audiofan1 is offline
post #34 of 99 Old 01-19-2019, 10:34 AM
tbaucom's Avatar
Quoted: 401 Post(s)
Liked: 115
According to Chris Kyriakakis, audyssey does try to add a 12 dB per octave roll off as part of its filter at crossover chosen by the avr to optimize the splice.
[URL][https://audyssey.zendesk.com/hc/en-us/articles/212346123-Does-MultEQ-optimize-the-crossover-region-between-satellite-speakers-and-subwoofer-/[URL]
post #35 of 99 Old 01-19-2019, 02:27 PM
matty1137's Avatar
Quoted: 73 Post(s)
Liked: 29
To be fair, the IMAX Enhanced press release does make it sound like a set of quality certifications/assurances. Thankfully, there were a couple demos at CEDIA that clarified details. One of the demos was put on by Sound United (Denon/Marantz) for AVS members, where we were reminded that IMAX theatres have been calibrated/tuned with Audyssey since 2009. As such, one of the features that is supposed to auto-switch when the IMAX Enhanced flag is detected is a custom IMAX target curve on Audyssey-based products that have the IMAX Enhanced mode. Also, most movie soundtracks have their dynamics reduced when remixing or nearfield remastering for home video. Since IMAX boasts about their huge dynamics, their rep said that IMAX Enhanced soundtracks will maintain their full dynamic range on home video.
If we don’t have an IMAX Enhanced AVR, will we still be able to take advantage of the ‘full dynamic range’ soundtrack by playing back the DTS:X/Master Audio track?
matty1137 is offline
post #36 of 99 Old 01-19-2019, 03:29 PM
sdurani's Avatar
Liked: 6176
Chris K said: "Keep in mind that it's a highpass filter applied to the filter and not to the signal." The 12dB per octave highpass filter is applied to their target curve (the filter) so that it doesn't re-shape the slope of the crossover that was set in the receiver. But the crossover (high pass, low pass) is still done in the receiver.
Sanjay
sdurani is offline
post #37 of 99 Old 01-19-2019, 03:31 PM
sdurani's Avatar
Liked: 6176
No guru. Just repeating non-NDA stuff I was told at CEDIA.
Sanjay
sdurani is offline
post #38 of 99 Old 01-19-2019, 03:34 PM
tbaucom's Avatar
Quoted: 401 Post(s)
Liked: 115
I get that. But if audyssey applies a high pass to the filter above or below 70hz won’t that be a problem?
post #39 of 99 Old 01-19-2019, 03:34 PM
sdurani's Avatar
Liked: 6176
Yes, the full dynamic range is built into the soundtrack (no dynamic range compression applied when it was transferred to home video).
tenthplanet and MJB1023 like this.
Sanjay
sdurani is offline
post #40 of 99 Old 01-19-2019, 03:41 PM
sdurani's Avatar
Liked: 6176
Why will it apply the high pass to a frequency other than the selected crossover point?
Sanjay
sdurani is offline
post #41 of 99 Old 01-19-2019, 04:05 PM
tbaucom's Avatar
Quoted: 401 Post(s)
Liked: 115
That is what I am asking . Will it automatically change the roll off in the filter to 70hz?
Maybe I a being dense, but it seems to me arbitrarily changing crossover to all speakers to 70hz has potential to make things sound significantly worse. Many are using very small speakers especially fir the surrounds.
post #42 of 99 Old 01-19-2019, 04:24 PM
tbaucom's Avatar
Quoted: 401 Post(s)
Liked: 115
Maybe I a being dense, but it seems to me arbitrarily changing crossover to all speakers to 70hz has potential to make things sound significantly worse. Many are using very small speakers especially for the surrounds.
post #43 of 99 Old 01-19-2019, 04:39 PM - Thread Starter
Mark Henninger
imagic's Avatar
Quoted: 9071 Post(s)
Liked: 15994
Although there are no IMAX Enhanced certified speakers, there are performance parameters that need to be met. In particular, the entire system should be able to achieve 20 Hz to 20 kHz, and the speakers themselves should all be able to play down to 70 Hz, according to the website FAQ. https://www.imaxenhanced.com/
Mark Henninger
Editor, AVS Forum
imagic is online now
post #44 of 99 Old 01-19-2019, 05:16 PM
tbaucom's Avatar
Quoted: 401 Post(s)
Liked: 115
Thanks. That is what I expected. Most people would likely be better off turning it off IMO. I suspect very few have surround systems capable of that.
post #45 of 99 Old 01-19-2019, 06:52 PM
sdurani's Avatar
Liked: 6176
IF Audyssey applies their filter based on the crossover setting, then it should change when the crossover point is changed.
That's a separate issue. Like asking how to adhere to a THX compliant layout when your very small speakers don't go down to 80Hz. In the case of IMAX Enhanced, you would need to switch out of that mode to regular DTS:X decoding (where you choose the crossover setting).
Sanjay
sdurani is offline
post #46 of 99 Old 01-20-2019, 04:42 AM
renoreigns's Avatar
Quoted: 14 Post(s)
Maybe I misunderstood what this was saying. Are they saying that people with your average or typical setup will still hear or see improvements? I just don't understand how this makes anything better than what's already out there. Please feel free to explain if someone else knows what this all means. I truly feel we are at the pinnacle of what's possible with video and audio. 8k is here and the only advancement with audio I would like to see is making more channels possible without spending a small fortune.
ChldsPlay and dfa973 like this.
renoreigns is offline
post #47 of 99 Old 01-20-2019, 04:57 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 15994
To really reduce it to the basics, it's a different presentation versus other versions of the movie, and it's up to the individual to decide if it is an improvement. I imagine some people don't like aspect ratio shifts, and prefer nearfield mixes with dynamic compression. If someone is in that camp, they should get the normal Blu-ray release. Just like when they go to the movie theater, they can choose between a regular movie theater and an IMAX auditorium. The idea here, at the end of the day, is to come as close as possible, in the home, to replicating the IMAX commercial movie theater experience.
As for the "pinnacle" of what's possible, Technicolor says VR delivered in 12-bit, 8K per eye, 120 fps, with 16 stops of dynamic range... that's the threshold where the experience looks real. Still a few years away from the first systems that might deliver this.
For flat panel viewing, 8K and rec.2020 color and variable frame rate up to 120 Hz would about do it.
Mark Henninger
Editor, AVS Forum
post #48 of 99 Old 01-20-2019, 07:19 AM
tbaucom's Avatar
Quoted: 401 Post(s)
Liked: 115
IF Audyssey applies their filter based on the crossover setting, then it should change when the crossover point is changed. That's a separate issue. Like asking how to adhere to a THX compliant layout when your very small speakers don't go down to 80Hz. In the case of IMAX Enhanced, you would need to switch out of that mode to regular DTS:X decoding (where you choose the crossover setting).
Than you. I know you have access to more information than most of us. Thanks for sharing what you can.
I have no doubt imax enhanced will sound very good on a system capable of playing it back as intended. Unfortunately , I don’t think most of us have such a system.
post #49 of 99 Old 01-20-2019, 09:32 AM
obveron's Avatar
Quoted: 165 Post(s)
Liked: 75
Wow, 16/9 content at home! The future is now!
tenthplanet, ChldsPlay and MJB1023 like this.
obveron is online now
post #50 of 99 Old 01-20-2019, 09:51 AM
Dan Hitchman's Avatar
Quoted: 4591 Post(s)
Liked: 2664
That may be true, but the content won't be there anytime soon. Hell, we're in a 4k world and many films still get 2k DI's.
The only thing 8k will bring is getting displays closer to REC 2020 compliance, maybe true 12 bit processing, and better contrast and brightness if they can nail down the panel tech where they haven't before.
This was stuff promised with 4k and not delivered on, so they could sell you on a bigger pixel count that means absolutely nothing in the grand scheme of things except on giant, premiere cinema screens.
sdurani, MJB1023 and dfa973 like this.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is online now
post #51 of 99 Old 01-20-2019, 02:21 PM
smurraybhm's Avatar
Quoted: 2302 Post(s)
Liked: 3150
So humble
I’ve lost count on how many of your posts have furthered my audio education.
There is no perfect display, quit looking for faults and enjoy
LG OLED 65” B7 and 55” C8
Ascend's with RAAL, Love my PSA v1800 and a 7.2.4 speaker config, Oppo 203 and other stuff
smurraybhm is offline
post #52 of 99 Old 01-20-2019, 05:15 PM
sdurani's Avatar
Liked: 6176
IF you consider more dynamic audio and less noisy picture to be improvements.
MJB1023 likes this.
Sanjay
sdurani is offline
post #53 of 99 Old 01-21-2019, 09:00 AM
MrGrey's Avatar
Quoted: 1728 Post(s)
Liked: 6424
Unless we are getting unfiltered audio, 4K DI IMAX then wtf are these people wasting our time for with this crap?! i don't see this going anywhere with anyone that serious about HT and not gimmicks.
MrGrey is offline
post #54 of 99 Old 01-21-2019, 09:09 AM
gondey99's Avatar
Quoted: 92 Post(s)
Liked: 39
I guess for the av enthusiast this is good? Otherwise a waste of money. Once again he industry trying to sell you things that they think yo you need.
gondey99 is offline
post #55 of 99 Old 01-21-2019, 09:12 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 15994
It could also be phrased as "make available things that you can choose to purchase if it appeals to you for entertainment purposes," And besides, the gear is optional, it just "enhances" the experience but nobody is locked out just because they did not buy a new AVR. You can just buy the disc and play it on an HDR capable display and stop there if that's all you want out of it.
sdurani, tenthplanet, RUR and 1 others like this.
Mark Henninger
Editor, AVS Forum
post #56 of 99 Old 01-21-2019, 11:05 AM
paultimm's Avatar
Quoted: 41 Post(s)
When is the first disc based blockbuster going to released on 4K UHD?
paultimm is offline
post #57 of 99 Old 01-21-2019, 01:39 PM
MJB1023's Avatar
Quoted: 30 Post(s)
Liked: 43
One thing IMAX prides itself on is that its audio systems are capable of reproducing bass down to nearly 20 hz or so. Since IMAX Enhanced is all about giving the consumer the full IMAX dynamics and SQ, I hope they are a little more hesitant in heavily filtering out LFE below 30 hz which seems to be more and more common in standard blu-ray releases. The good news for many of us on AVS is that this new format will reward those who ponied up for more capable speakers and subs. In a world where it seems like everything is being mixed for soundbars and earbuds, that's a wonderful thing.
imagic and the7mcs like this.
MJB1023 is offline
post #58 of 99 Old 01-21-2019, 01:40 PM
the7mcs's Avatar
Quoted: 478 Post(s)
Liked: 215
This is what I don't understand with people... some times people just frustrate the hell out of me when they complain & complain & complain about things they don't understand rather than taking a little bit of time to grasp and understand.
I mean it's not like anyone is kicking doors down with a double barrel 12 gauge to their faces and making them pay.
I for one am glad that I can just buy the disc and still be able to enjoy the visual side of the content with my current 2016 display, unlike with things like 3D where you HAD to buy a TV with it for example.
imagic, MJB1023 and mc_avs like this.
the7mcs is offline
post #59 of 99 Old 01-21-2019, 02:55 PM
Brian Hampton's Avatar
Quoted: 1404 Post(s)
Liked: 827
Quote "The key thing to understand with IMAX Enhanced is that is open. You can get started with experiencing it by simply obtaining the content."
From what I've read the key thing to understand with the IMAX Enhanced is it's empty.
Literally seems to be nothing to it.
It's branding. IMAX says this hardware and software is better.
I guess if it makes people happy or sells stuff then it's good for somebody anyway.
dfa973 likes this.
Brian Hampton is online now
post #60 of 99 Old 01-21-2019, 04:12 PM
jocedeg's Avatar
Quoted: 88 Post(s)
Liked: 93
We don't need you telling the rest of us what IS and ISN'T crap, Mr "Serious About HT".
jocedeg is offline
ces 2019 , imax ehanced
