Anthem 720 plus AMP vs 1120 in regards to Atmos - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-11-2019, 10:52 AM - Thread Starter
Liked: 0
I want to upgrade to the Anthem 720 but I also want to put up 4 Atmos speakers in the ceiling. I know I can do it with the 720 as long as i add a 2 channel amp. So the question is should i just get the 1120 or buy the 720 with a cheaper amp so its less than the cost of a 1120. As for a amp, what do you suggest.
OldHumey is offline
post #2 of 3 Old 04-15-2019, 03:10 PM
bokap's Avatar
Quoted: 197 Post(s)
Liked: 30
I had the same decision to make and I have the 1120 on order. I just thought the 1120 would be better than 720 and worth the extra money
bokap is offline
post #3 of 3 Old 04-15-2019, 03:57 PM
markmon1's Avatar
Quoted: 4395 Post(s)
Liked: 2759
I got the 720 and use it exclusively as an AVM60 with external amps. If your cost for 720 + amp is lower than 1120, you should go that route. There's no benefit to the 1120 over 720 except more amps.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
