"Official" (kinda) thread for Onkyo TX-RZ630-730-830 Networking A/V receivers - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 78Likes
post #241 of 310 Old 06-30-2019, 02:12 PM
Quoted: 78 Post(s)
Liked: 38
Originally Posted by ku4ever2 View Post
Thanks for the info. If I go the Emotiva 5 channel route, how does that work with my main receiver (the Onkyo 830). Assume the Onkyo is still handling all the processing for the 7.2.4 setup..but the Emotiva would give me more power to the L/R/C and still be able to drive the Rears (so would not have to buy another separate power amp for that)
Again sorry if that is stupid question..just first time thru this so appreciate any help on how I would do that setup with the Onkyo.
Correct. Its just a 5 channel power amp. Can put any speaker pre outs to it. I would still choose the lcr and the rear surrounds since you have to power them. its not much more for the 5 channel over a 2 channel power amp unless you start looking used and find a deal.
Gold87 is online now
post #242 of 310 Old 06-30-2019, 02:22 PM
ku4ever2's Avatar
Liked: 0
Ok..great. So do you think its a big improvement to drive the Front stage off the Emotiva vs the Onkyo? As you stated, not much more than buying just a 2 channel for the Rears..but wondering if worth the cost. I figure it would also help the Onkyo run less hot?
Also, if I do go that route, I do have one other question. For my last set of ceiling speakers behind the media area. Could I drive those 2 together with the other 2 Rears in parallel into 2 channels for the Emotiva (so would be a 4 ohm load). If that is a bad option was going to just wire them into the Zone 2 of the Onkyo and use only in a pinch (probably only will use those speakers when wanting to drive music to full basement including the media area). But driving 4 rears is an interesting option since I have a 3rd row bar behind the main seating and I think the 4 rears together would drive a wider rear stage?
ku4ever2 is offline
post #243 of 310 Old 06-30-2019, 02:25 PM
Quoted: 78 Post(s)
Liked: 38
If you want more channel will need something like the denon 8500 thats 3k for 13 channels or emotiva rmc-1 that 5k for 16 channels but is only a pre-amp so you need power amps for all channels.
post #244 of 310 Old 06-30-2019, 02:34 PM
Quoted: 78 Post(s)
Liked: 38
I noticed a difference going from the onkyo to the emotiva for my lcr. Alot more dynamics it seemed. Put it this way the onkyo puts out a max output of 240 watts for all 11 channels, that 22 watts a channel. The emotiva will do 80 watts a channel all 5 driven. Huge difference. The onkyo 830 has never run hot. Mine is in a pretty open area under the tv and has no back to it. I also have 4 ohm speakers on mine.
Not sure about the second speaker set never used the zones. It does have a zone 2 hook up and think you can run zone 2 and mains at the same time. Would have to look in the manual or maybe someone else knows.
MALICIOUS ONE likes this.
post #245 of 310 Old 06-30-2019, 02:44 PM
ku4ever2's Avatar
Liked: 0
Awesome! That sounds like the best route for me to go to maximize sound/options within my budget. I am running Polk 255c-Rt for Center and Polk 265 RT for L/R. So as you mentioned should drive better output to the front stage and help handle the extra power amp I need for the Rears.
Thanks again!
ku4ever2 is offline
post #246 of 310 Old 07-04-2019, 11:58 AM
opcode's Avatar
Quoted: 12 Post(s)
Hi!
I am a new owner of an Onkyo TX-RZ830. Although I generally very happy with the quality and feature set, this morning I experienced something weird with the receiver. Well, actually since I first installed it about a week ago, I have been noticing some random "relay" clicks, even when the receiver was in stand by mode.
Then this morning I was using Airplay for the first time with my iPhone XS. A few songs in, the music stopped. After some investigation I detected the problem: wifi connection was dead in the Onkyo, status "failed". I tried to turn off and on the receiver, turn off and on the wifi connection, but nothing fixed the issue. During all of this, I noticed that the receiver UI was behaving very sluggishly, a couple of seconds between pressing a key and the cursor moving on screen.
So I decided to turn off the receiver and unplug power. Waited a few seconds, plugged back, it initialized and was back to normal operation, including wifi.
My question is, has anyone here experienced this same issue? Should I be worried? It seems to me my receiver experienced some sort of partial system crash, perhaps a firmware bug, but perhaps it is something else?
Thank you!
opcode is offline
post #247 of 310 Old 07-04-2019, 07:36 PM
Barrettmr's Avatar
Quoted: 140 Post(s)
Liked: 45
I also have the RZ830 with an Emotiva 5 channel amp which is rated at 200w per channel (1000w total) so it is best to use that for L/R/C and the two surround back channels which is the 7. then use the RZ830 for the 4 Atmos channels which don't need as much power. You just hook up the pre-out for the 7. channels to the Emotiva and I use the trigger line so the amp comes on/off with the Rz830
Epson 5050UB - Falcon Screens AT 131"
Onkyo TX RZ830 - Emotiva XPA-5 - Panamax M5300
Polk 265LS/255cLS L/C/R - 2 sets 80F/X-LS Atmos & LSiM703 surrounds - Dual SVS PB2000 subs
Panasonic DP-UB820 - HTPC with Emby
Barrettmr is offline
post #248 of 310 Old 07-05-2019, 04:29 AM
Quoted: 88 Post(s)
Liked: 25
How does it sound combining the RZ-830 with the Emotiva XPA-5 Gen 3? Is the preout voltage enough from the Onkyo RZ-830 for the Emotiva’s required 1.5v for full rated power?
yodog is offline
post #249 of 310 Old 07-05-2019, 08:45 AM
Mr.G's Avatar
Quoted: 1328 Post(s)
Liked: 1725
Originally Posted by opcode View Post
Hi!
Thank you!
I've never heard any clicks when the RZ830 is off. An occasional click when it is on. A power reset like you performed can often clear up operation issues. You should continue to monitor your unit for any recurring problem and return if you are not happy.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #250 of 310 Old 07-15-2019, 07:53 AM
Quoted: 88 Post(s)
Liked: 25
Does the Onkyo RZ-830 provide enough pre out RCA voltage? I know the Emotiva XPA-5's need 1.5v to get the full rated power. I'm on the fence about buying this RZ-830... how does the pre processor/DAC in the RZ-830 compare to the likes of like a Denon 4500 or Marantz 6013?
yodog is offline
post #251 of 310 Old 07-15-2019, 02:49 PM
eriksells916's Avatar
Quoted: 511 Post(s)
Liked: 195
@yodog I imagine others here have used the preouts with emotiva amps just fine, so do a quick google search.
The rz830, x4500h and sr6013 all have the premium akm4458 dac's, so I imagine they will all sound similar without correction. Once you add correction, the xt32 with subeqht is a far superior solution on paper and has true dual sub control. However, your room, like many others here, may be just fine with accueq. Especially if you have minidsp to control the subs.
One site (shall remain nameless) says the power supply of the rz830 is larger than the x4500 and sr6013, but I am not able to confirm that.
The rz730/830 and lx503 are probably the best, most powerful and feature rich 9 channel receivers under $600. The sr6013 is a pumped up x3500h and is great for HT and music with preins and hdam circuits, while the x4500h was once rated as the best 9 channel HT receiver under $1500. The NAD 758v3 is right there too as it is similar but has the superior dirac live room correction.
I own none of those, that is purely my $.02 from what I have read. hope that helps?
eriksells916 is online now
post #252 of 310 Old 07-15-2019, 02:51 PM
Quoted: 88 Post(s)
Liked: 25
Helps greatly... thank you....
Sadly the RZ830 just went up $50-70 in price so I may not even get it now.... sucks because I was looking st the price of $495-498 for many weeks and the day I was going to buy it, the price jumps up... 😕
Do it all or don't do it at all.
yodog is offline
post #253 of 310 Old 07-17-2019, 04:16 PM
vinniemeatball's Avatar
Zone 2 - Sounds like Crap
Just rec'd RZ630. I have a 5.1 setup in main room and hooked up some outdoor speakers to Zone 2 and 3. Previously had a separate receiver running the outdoor speakers. I have a Polk 8 SDI hooked up with both left and right. After hooking up and playing music on Zone 2 the speaker sounds awful. The music is loud and can barely hear the voice, no lows.
Anyone else experience this and have an idea how to fix?
vinniemeatball is offline
post #254 of 310 Old 07-20-2019, 01:29 PM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Quoted: 84 Post(s)
Liked: 56
I just received and hooked up a new RZ630 this morning. We've been listening to Zone 2 outside for a couple of hours today - sounds no worse than the 606 Zone 2 I had there until today. Zone 3 worked nicely too.
Something get mis-connected, perhaps? I assume you have it set-up properly with Zones 2 & 3 powered via the rear surrounds and heights? Are you using an analog source for Zone 2, or relying on conversion from HDMI? (I have both connected, honestly don't know what the receiver is using as a default.)
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
post #255 of 310 Old 07-20-2019, 02:59 PM
Quoted: 511 Post(s)
Liked: 195
Are you using zone 2 preouts and zone 3 stereo outs or both zone 2/3 stereo outs?
The rz630 has a dac to play digital sources to zone 2 only, iirc?
post #256 of 310 Old 07-21-2019, 07:17 AM
shinksma's Avatar
Quoted: 84 Post(s)
Liked: 56
Originally Posted by Buteobander View Post
So far I only seem to be able to select Source on zone 2. Zone 2 should be able to play a different input than Main, but I either have not gotten this to work, or not figured it out yet. Onkyo also had no explanation for why I heard nothing from the zone 2 speakers during the multi-zone test when I redid the initial setup.
When I did the initial set-up I also did not get a test tone for Zone 2. I wonder if the initial (factory default) volume is set so low that you just can't hear it, though, because once I sent a source to the other Zones it worked fine after I boosted the volume from "10" or something too low to hear.
One other note: the interface on the amp itself (controls) are much less user friendly than on the 606 for zone 2. The 606 had dedicated volume buttons for zone 2. The 603 does not, and also when playing music through main and zone 2, and then turning off the amp, it turns off only the main speakers. Seems one has to set the remote control to zone 2 to turn them off... nuts. Doesn't seem to be an easy way to do this on the amp itself.
The 630 is actually quite nice, IMHO, with how Zone 2/3 controls work - on the receiver itself you press Zone 2 or 3, and the controls all switch over to that zone - volume, source selection, power, until you don't hit something for 5 seconds (or maybe 3 seconds).
And on my Harmony remote, when I programmed it for the 630 it added two "additional receivers", which have discrete controls for those two zones.
Much better than the 606, IMHO, once I figured it out.
shinksma is offline
post #257 of 310 Old 07-21-2019, 01:10 PM
ericvq's Avatar
Firmware Update 7/4/19
Anyone know if updating will erase my setting? Thanks.
https://www.onkyousa.com/downloads/
Firmware Update Onkyo TX-NR787, TX- RZ630, TX-RZ730, TX-RZ830
(7-4-2019)
We are pleased to offer this firmware update for the best possible performance of your Onkyo AV Receiver.
This update may be installed via USB or Network. We recommend USB for faster, more reliable installation.
Onkyo TX-NR787, TX-RZ630, TX-RZ730, TX-RZ830 (Current Version 1060-8000-1050-0010)
The 7/4/2019 update will address the following and includes previous updates:
1. Improve playback stability for Chromecast Built-in.
2. Improve playback stability for Airplay.
3. Improve the playability for certain WAV files.
ericvq is offline
post #258 of 310 Old 07-22-2019, 07:17 AM
Patsfan123's Avatar
Quoted: 501 Post(s)
Liked: 325
(7-4-2019)
I applied it and my settings were intact. Same with all prior FW.
LG 65C6P FW: 05.30.70 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #259 of 310 Old 07-22-2019, 01:41 PM
iraweiss's Avatar
Quoted: 116 Post(s)
Liked: 66
Same here. Did the network update and it took only a few minutes.
iraweiss is offline
post #260 of 310 Old 07-22-2019, 02:13 PM
Quoted: 351 Post(s)
Liked: 257
Stupid question - does the RZ730 have a cooling fan in it, like at the top of the chassis? Was looking at an NR787 and it has one so I assume the 730 does as well.
Also, I have no idea if there is any significance but the power supplies in the 9-series NR floor models I was looking at don't seem to have the 'HCPS' stickers on them; to contrast, the NR787 floor model does. The Onkyo US site still has HCPS listed as a feature but it caught my eye that the stickers aren't there.
KSpan is online now
post #261 of 310 Old 07-23-2019, 06:51 AM
Patsfan123's Avatar
Quoted: 501 Post(s)
Liked: 325
The 730 has a fan but I've never noticed it turn on. That basically goes for all the Onkyos with fans that I've owned. They must only turn on at crazy high temps.
MALICIOUS ONE and KSpan like this.
post #262 of 310 Old 07-23-2019, 09:20 AM
ericvq's Avatar
Thanks guys. Last update I did was before I put all my setting in. Will update this evening.
ericvq is offline
post #263 of 310 Old 07-25-2019, 06:16 PM
french_guy's Avatar
Quoted: 26 Post(s)
Does anyone know why the price went up? It was $498 on A4L for a while, and people were saying it was because the 840 was getting released....But now, the 830 is at $579 !!!
french_guy is offline
post #264 of 310 Old 07-25-2019, 07:16 PM
Quoted: 88 Post(s)
Liked: 25
Supply and demand
yodog is offline
post #265 of 310 Old 08-10-2019, 07:24 PM
Quoted: 12 Post(s)
I messed up guys, went to move a speaker and the wire came out and touched the receiver (RZ830). Heard a short pop and now it won't stay on past a few seconds. I tried the resets I found in the manual but nothing seems to reset what i'm assuming is the protection kicking in. Is my only option now to send it in? Under warranty but my stupidity caused it so i'm assuming i'm paying something. Definitely learned a lesson. Hooked stuff up to another processor and it's all working so at least that stuff is fine... Any insight would help, maybe there is a reset I don't know about. Unplugged it for an hour or so and plugged it back in, tried the hold the power button / CBL and power button resets, no dice.
StrangeFlavor is offline
post #266 of 310 Old 08-11-2019, 02:39 AM
Lindahl's Avatar
Quoted: 57 Post(s)
When using a phone to trigger audio playback using Chromecast built-in, how many seconds does it take from receiver off (standby) to get to the point where the receivers are actually playing the requested audio?
Lindahl is online now
post #267 of 310 Old 08-11-2019, 09:52 AM
Mr.G's Avatar
Liked: 1725
I don't use the Chromecast built-in by using the Onkyo app on my Moto X4 phone I can start the receiver from stand-by, switch to Tune IN, presets and Cinemix channel in about 30-45 seconds.
Mr.G is offline
post #268 of 310 Old 08-11-2019, 09:56 AM
Mr.G's Avatar
Liked: 1725
Had a odd one happen last night. Was watching the Raiders of the Lost Ark (1080p) Blu-ray and towards the end of the film my RZ830 clicks off while the rest of my equipment, Panasonic UB820 player and Epson HC4000 4K projector remained on. After about 30 seconds the RZ830 clicked back on and the movie completed. First time occurrence.
Mr.G is offline
post #269 of 310 Old 08-11-2019, 01:50 PM
Lindahl's Avatar
Quoted: 57 Post(s)
I'm only interested in startup time for Chromecast built-in. Thanks though!
post #270 of 310 Old 08-11-2019, 07:03 PM
iraweiss's Avatar
Quoted: 116 Post(s)
Liked: 66
Have you tried unplugging the receiver,from AC unplugging all the speakers, plugging the receiver back into AC and then turning the power on with no speakers attached?
To avoid the problem of loose wires I use banana plugs.
iraweiss is offline
Onkyo , onkyo tx-rz630
