Yamaha RXV465 is there a loudness button? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By ChromeJob
  • 1 Post By Espo77
  • 1 Post By Espo77
post #1 of 7 Old 01-30-2019, 06:33 AM - Thread Starter
stevethebrain's Avatar
Quoted: 152 Post(s)
Liked: 25
couple weeks ago I was messing around w/ some of the configurations, I don’t remember seeing or turning off the loundness however
seams like the loudness is turned off, I now have to seriously turn up the volume to achieve the same volume levels as before me messing around.
when I select menu I have
speaker setup
sound setup
function setup
DSP parameter
memeory guard
I've clicked on every sub category w/in each of pages didn't see a loudness feature or maybe Yamaha refers to loudness as something else.
Thanks for any advice.
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 7 Old 01-30-2019, 07:15 AM
Espo77's Avatar
Quoted: 516 Post(s)
Liked: 226
...anything marked with the words “Dynamic Range” in your menu?
You want max dynamic range turned on.
Some receivers have a “Late Night” setting that will limit some of the loud passages.
...anything marked “enhancement...enhance?
If I had a loudness button, I would never use it!
Maybe when listening at very low volume.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #3 of 7 Old 01-30-2019, 07:40 AM - Thread Starter
Quoted: 152 Post(s)
Liked: 25
been clicking I see IniVol--off
also see MaxVol-+16.5dB 16 would be very loud previously normally kindof loud is 23
unable to adjust MaxVol-+16.5dB can it be adjusted?
post #4 of 7 Old 01-30-2019, 08:46 AM
ChromeJob's Avatar
Quoted: 2011 Post(s)
Liked: 1068
Sounds like you need to do a reset to defaults under Advanced Settings[1] (in most models). You messed with something that you can’t revert, so a reset is probably best. Then you’ll have to run YPAO and any other personalizations you effected.
[1] P. 45 in one of the manuals Yamaha has. Click here for the manual library: https://usa.yamaha.com/support/manua...o_visual&k=465
Espo77 likes this.
"Sell crazy some place else -- we're all stocked up here."
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
A: Yamaha RX-V775; Chromecast Audio; iPod Classic, Touch. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen, Samsung UN40ES6150.
ChromeJob is offline
post #5 of 7 Old 01-30-2019, 09:58 AM
Espo77's Avatar
Quoted: 516 Post(s)
Liked: 226
This is tough to say, but you need to reset, start from the beginning, and go slowly through the setup menu as you grasp everything.
Sometimes I can go for weeks and months without a glitch...riding along with all sails up, “I know everything I need to know about this receiver” LOL...then one day I make a simple change in the menu and, all Hell breaks loose...LOL.
Watch out for “THE DOMINO EFFECT”.
Like suddenly realizing that you are lost in the woods because you made too many wrong turns, and you can’t find your way out.
It’s an awful experience. Hehe
ChromeJob likes this.
Espo77 is offline
post #6 of 7 Old 01-30-2019, 10:06 AM
Espo77's Avatar
Quoted: 516 Post(s)
Liked: 226
I think after calibration, zero DB reading on the receiver should equal about 85 DB in the room. (Did I say that right?)
Redo your room correction.
Espo77 is offline
post #7 of 7 Old 01-30-2019, 12:34 PM
ChromeJob's Avatar
Liked: 1068
The RX-V465 manual reminded me how old this unit it, the OM reminds me of my RX-V663 version.
There aren't too many "tone" or "tweak" options.[1] I recall some older units had a two-step mute option (-20dB or 100%), but I don't find that. You could've disabled a speaker or two. But doing a "init" reset and running YPAO again and turning off all tone, DSP, Dynamic Range Control options should restore normal sound, or identify a new problem with this old AVR. :}
[1]Off the top of my head:
  • PEQ adjustments
  • Tone Control
  • Cinema DSP
  • Bass cross over or extra bass
  • Compressed music Enhancer?
