Receiver behind projector - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By jcmccorm
  • 1 Post By ChromeJob
post #1 of 9 Old 01-30-2019, 10:37 AM - Thread Starter
Liked: 0
Hey guys so I recently setup my ht and my only option for now is to put the receiver behind the projector screen. Problem now is that the remote doesn’t work through the screen and I have to get up and go behind to adjust. Can you guys recommend a fix for this? I know there little devices u can put over the receiver and put the sensor elsewhere, can u guys recommend a brand you’ve used
One_thirsty_speaker is offline
post #2 of 9 Old 01-30-2019, 10:45 AM
shivaji's Avatar
Quoted: 1106 Post(s)
Liked: 1028
The thing to look for is IR repeaters.
https://www.amazon.com/s/ref=nb_sb_n...ds=ir+repeater
shivaji is online now
post #3 of 9 Old 01-30-2019, 10:56 AM
rfb6435's Avatar
Quoted: 202 Post(s)
Liked: 89
I have a monoprice IR repeater with my AVR in a remote closet.
I am able to use a simple 3.5mm stereo cable connected between it and the Marantz or Denon "Flasher" input. No need to use the glue on IR lamp to the front sensor. I am pretty sure that Yamaha, Onkyo and others that have the input will also work this way.
It is a simple and good solution.
-Rich
Quad Marantz AVR 9.2.(4+2) Atmos/DTS:X using Dual sr7010's + Dual scAtmos nr1403's
Marantz MM8003 150W/ch Amplifier Driving (L/C/R/SL/SR/SBL/SBR)
HTD Speakers L3 Tower L/R, L3 Center, Dual 12" L3 Subs, L2 Tower SL/SR, L2 Bkshlf SBL/SBR, Flat Panel WL/WR, Angled 6.5" In Ceiling FH/RH, 8" In Ceiling TM
Epson 5040UB Faux-K/3D with 106" Multi-Format Screen.
rfb6435 is offline
post #4 of 9 Old 01-30-2019, 11:15 AM
toddman36's Avatar
Quoted: 507 Post(s)
Liked: 182
As others have mentioned a ir repeater will work fine for your situation. Most are inexpensive and simple to install/setup, depending on what you purchase...
Ive installed these ir repeaters for others, and they work perfectly with no issues when equipment or device is out of site. Most can be purchase i different lengths.
https://www.amazon.com/Cable-Matters...ords=ir+sensor
https://www.amazon.com/BAFX-Products...PFNYQQX0VZHZC3
(R&L: Infinity Beta 50) (Center: Infinity Beta C360) (Surround Side & Back: Infinity IW ERS 210 x 4) (TM: Infinity IC ERS 110 x 2) (Sub: Def Tech SC1)
(7.2.2 Config.) (AVR: Denon-4500) (Audiosource Amp 110 for TM's) (BRP: Pioneer 80FD) (Nvidia Shield TV) (Display: LG-65C9)
toddman36 is offline
post #5 of 9 Old 01-30-2019, 11:50 AM
jcmccorm's Avatar
Quoted: 587 Post(s)
Liked: 435
I use the BAFX repeater linked above by @toddman36 . My receiver/bluray/cablebox/etc is behind the wall that my LCD TV is mounted on. No issues whatsoever with this repeater.
unretarded and toddman36 like this.
jcmccorm is offline
post #6 of 9 Old 01-30-2019, 01:00 PM - Thread Starter
Liked: 0
Thanks so much for the reply’s I am looking at the recommendations now
post #7 of 9 Old 01-31-2019, 08:17 AM
ChromeJob's Avatar
Quoted: 1983 Post(s)
Liked: 1050
Check if your AVR has a network connection, and an app to control over the LAN, if you haven’t used that before. The Yamaha AV Controller app would be ideal.
shivaji likes this.
"Sell crazy some place else -- we're all stocked up here."
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
A: Yamaha RX-V775; Chromecast Audio; iPod Classic, Touch. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen, Samsung UN40ES6150.
ChromeJob is offline
post #8 of 9 Old 01-31-2019, 01:51 PM - Thread Starter
Liked: 0
Thanks chrome job I actually took a look and found an app to use as a remote for the receiver. Good looking out
post #9 of 9 Old 02-01-2019, 07:44 PM
ChromeJob's Avatar
Liked: 1050
Bravo, sir. (high five)
