Atmos hook up question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-07-2019, 10:06 AM - Thread Starter
Quoted: 211 Post(s)
Liked: 44
As of yesterday I upgraded my 7.1 to 7.1.2. Immediately fell in love and have now ordered another pair of in-ceiling speakers for top rears. Running an SR 7012 which can process 11.1 but only power 9.1.
My question is, can I use an old receiver that doesn’t have multi-channel inputs to power the back two channels? It has analog audio inputs (just stereo L/R). I don’t see why I couldn’t just connect the pre-outs on the 7012 to the stereo inputs on my little Yamaha v375 and set the receiver/amp to “straight.” Yet all the threads I’ve seen on this topic suggest you NEED multi-channel input to do it.
Am I missing something here?
filmgeek47 is offline
post #2 of 8 Old 02-07-2019, 10:14 AM
usc1995's Avatar
Quoted: 486 Post(s)
Liked: 348
Yes, you can use the stereo input on your old receiver to power your rear speakers. The rear speakers are just two channel stereo, you don’t need a multi channel input to power two speakers. I use an ancient receiver to power my rear surrounds in my 7.2.4 setup with my Pioneer Elite SC-95. It works great!
usc1995 is online now
post #3 of 8 Old 02-07-2019, 10:18 AM - Thread Starter
Quoted: 211 Post(s)
Liked: 44
Awesome. Thanks! I’ll probably buy an Emotiva power amp for my fronts eventually, but it’s just not in the budget right now and this way I can step to 7.1.4 a whole lot quicker
post #4 of 8 Old 02-07-2019, 11:29 AM
Quoted: 439 Post(s)
Liked: 326
depending on which speakers you use you may not need an amp for your fronts. it would be a good idea to wait and see how you like your current setup until your wallet heals. Then maybe a good 3 channel amp for the fronts and center and use the amps on the AVR to power surrounds and atmos.
Rgarc is offline
post #5 of 8 Old 02-07-2019, 12:10 PM - Thread Starter
Quoted: 211 Post(s)
Liked: 44
Oh yeah it’ll be a while. I know I’d benefit at least a little though. Buddy of mine brought in a schiit vadar a while back and the difference was pretty significant. Probably less of a gap since I upgraded my AVR (sr5010 to 7012).
Right now though I’m just shocked at how good the whole setup sounds.
If I do go with a three channel, do you have any recommendations under $700 or so? Most of what I’ve seen are either stereo amps or 5-7 channels. My fronts are Martin Logan motion 40s and a 30, 4ohms but pretty sensitive.
post #6 of 8 Old 02-07-2019, 01:23 PM
Quoted: 439 Post(s)
Liked: 326
for just under $700 I would look at the Emotiva BasX A-300 + a PA-1 monoblock.
Rgarc is offline
post #7 of 8 Old 02-07-2019, 01:42 PM - Thread Starter
Quoted: 211 Post(s)
Liked: 44
I was already looking at the a-300 actually. Hadn’t seen the pa-1 though. Thanks! If I end up getting a proper amp I think I’ll go this route.
post #8 of 8 Old 06-02-2019, 09:02 AM
Tom899's Avatar
Quoted: 176 Post(s)
Liked: 83
This is exactly what I'm doing. The A-300 will be here Tuesday, The PA-1 Wednesday. I hope it works well.
Pioneer UDP-LX500 | Denon AVR-X4400H | Emotiva A-300 2ch amp | Emotiva PA-1 monoblock | JVC DLA-RS1000 Projector | Mini DSP 4x2 | Dune HD Smart D1 | ZIDOO Z9S | Buttkicker system | HSU VTF-3 MK4 subs(2) | HSU MBM-12 MK2 Mid bass module | Klipsch RP-8000F(2) | Klipsch RP-504C | Klipsch RS-62 II(2) | Polk RC80i Ceiling(4) | Carada 134” screen | unRAID 40TB
Tom899 is offline
atmos , external amp
