Need help to choose/eliminate/differences - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 02-20-2019, 11:44 AM - Thread Starter
Clipse's Avatar
Quoted: 39 Post(s)
On my list is the onkyo 676 and 686 and its competition is the x1400 and x1500.
Will be running klipsch RP-160 and 150s with probably a pb-2000.
What are, if any, real differences among these four?
Mainly gaming and movies, music is not a priority
Clipse is offline
post #2 of 11 Old 02-20-2019, 01:15 PM
Quoted: 424 Post(s)
Liked: 308
I would go with the Denon 1400 since you can find great deals on those and its a firmware update away from being very similar to the 1500. Check prices in the deals stickie or check Amazon or Crutchfield.
Rgarc is offline
post #3 of 11 Old 02-20-2019, 01:19 PM
afrogt's Avatar
Quoted: 2222 Post(s)
Liked: 1465
The Denon x1400 and x1500 only have a single HDMI out while those two Onkyos have dual HDMI out. Make sure that is okay for your setup.
Afro GT
afrogt is offline
post #4 of 11 Old 02-20-2019, 01:58 PM - Thread Starter
Clipse's Avatar
Quoted: 39 Post(s)
Beyond the dual hdmi anything else?
I can get pretty much all within like 50$ of each other
Clipse is offline
post #5 of 11 Old 02-20-2019, 02:55 PM
Quoted: 424 Post(s)
Liked: 308
The onkyo 686 also has more analog inputs that the either of the Denon choices if you need any of those. The Onkyo has a better DAC than the Denons as well. Both Denon have or will have Airplay 2 compatibility while the Onkyo is limited to Airplay if Apple compatibility is a factor for you. Watts-wise the difference is minimal.
Rgarc is offline
post #6 of 11 Old 02-20-2019, 03:24 PM
Quoted: 13 Post(s)
Liked: 1
I believe those listed Denons use exactly the same DAC as the Onkyos, the Asahi Kasei AK4458. Maybe @jdsmoothie could corroborate that.
audionewb2 is offline
post #7 of 11 Old 02-20-2019, 04:17 PM - Thread Starter
Clipse's Avatar
Quoted: 39 Post(s)
Looks like both use same dac. The extra hdmi is a bonus. I'm just freaked out by all the onkyo hdmi issues and other stuff with onkyo but the denon seem to have its share of issues too
Clipse is offline
post #8 of 11 Old 02-20-2019, 04:37 PM
Quoted: 424 Post(s)
Liked: 308
I may be wrong but Denon does indicate that the 1500's DAC is 192 kHz/32 Bit (1400 is 24 bit); while the Onkyo 686 boasts a 384 kHz/32-bit DAC. Was not able to find information as to which specific DAC model is being used in either case.
Rgarc is offline
post #9 of 11 Old 02-20-2019, 05:31 PM
RKSKYDANCER's Avatar
Quoted: 369 Post(s)
Liked: 151
The Onkyo's have better DAC's then the Denon and as for the HDMI issues, that was a thing of the past. This is not a problem on current models so no need to be concerned with that.
Any brand receiver can have issues. Just stick with brand new (not refurbished) and buy from a authorized dealer like Crutchfield, Safe & sound inc, Frys, Best Buy or World wide stereo for good support.
I would go with the Onkyo TX-NR686 over the Denon's if it were me. Also look at the Sony STR-DN1080. On sale at crutchfield and has been choosen as one of the best budget AVR's for 2018.
Good luck with what ever you choose!
(Living Room) Sony XBR-65X900E 4K TV, Sony UBP-X800 4K BD player, Pioneer SC-LX502, Def Tech BP9020's, A90 atmos, CS-9040 C and Di 5.5R surrounds
(Garage) Sherwood RX-4105 Receiver, Samsung DVD/CD player, Klipsch 2.5 med oak speakers
RKSKYDANCER is offline
post #10 of 11 Old 02-21-2019, 04:47 PM - Thread Starter
Clipse's Avatar
Quoted: 39 Post(s)
[QUOTE=RKSKYDANCER;57633564]
Looks The Onkyo's have better DAC's then the Denon and as for the HDMI issues, that was a thing of the past. This is not a problem on current models so no need to be concerned with that.
I came across an open box x2400h in retail store for same price as the 686. Where does thst fall into the scheme of things
Clipse is offline
post #11 of 11 Old 02-22-2019, 05:57 PM
Quoted: 369 Post(s)
Liked: 151
[quote=Clipse;57638666]
I would still take the Onkyo 686 over the Denon X2400x even if it was new! I wouldn't be interested in open box just like i would not buy a refurb unit.
I had a new Denon AVR-X3400h. Had it for about 9 months. Decent receiver but not impressive for my living room set up. My brother tried 2 refurb Denon's from A4less. Both were terrible units.
I own a Pioneer SC-LX502 now and it's very impressive. Onkyo makes Pioneer so there are many similarities. I was looking at the Onkyo TX-NR787 or TX-RZ730 before finding the deal i got on the Pioneer Elite.
It's really going to come down to what features you want. Do a comparison thru crutchfield on the models you like. Denon's are good receivers. i just think for $500.00 or less the Onkyo's are a better value.
