Do I need an external amplifier? - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 3 Post By markmanner
  • 1 Post By choombak
  • 2 Post By m0j0
post #1 of 12 Old 02-24-2019, 07:16 AM - Thread Starter
KurtCocain's Avatar
Quoted: 44 Post(s)
I would like to understand if I need an external amp to power my front channels or my AVR is sufficient. Let me give you some parameters as context:
- listening room is a bedroom size of 17 x 12; I usually do 50:50 movies and stereo music listening
- KEF Q300 speakers with 87 dB sensitivity (supposedly 8 ohms, but i read some places may go below 4 ohms)
- a 5.1 setup with an SVS sub
- listening position is 9 feet away
- Denon AVR rated at 105W for 2 channel
- when I listen to music my Master Volume is around 50 for heavily compressed (recent) music (out of 98) and that produces about 70 dB SPL I have measured it with REW
- when I listen to music mastered in 80s and 90s my Master Volume could be around 55 for similar 70 SPL
- when I watch movies my Master Volume is anywhere around 55-60
- I have never had to turn my Denon AVR higher than Master Volume 60
With that being said,
1) Do I need an external amplifier for my front speakers to sound their best at my MLP for when I listen to music only, still leveraging the sub?
2) Would I get better sound quality (not louder, but better) from using an external amplifier?
3) Does not audio quality degrade once you have AVR pre-out --> amplifier via analog RCA connectors? The chain is no longer all digital, so I assume loss of audio quality.
KurtCocain is offline
post #2 of 12 Old 02-24-2019, 08:00 AM
markmanner's Avatar
Quoted: 345 Post(s)
Liked: 294
Originally Posted by KurtCocain View Post
1) Do I need an external amplifier for my front speakers to sound their best at my MLP for when I listn to music only, still leveraging the sub?
1. Given your usage and conservative volume level, it doesn't seem like you need any more amplifier power.
2. If you have a good AVR amplifier, which you seem to have, and aren't clipping due to needing more power, then adding more power won't affect the sound quality.
3. The digital signal in to your AVR is being converted to analog before it goes to the AVR internal amplifier, so that is happening whether it is sent to the internal or external amplifier.
I am sure others will reply, hope this helps,
Mark
fill35U, eljaycanuck and Alan P like this.
System
Spoiler!
markmanner is offline
post #3 of 12 Old 02-24-2019, 08:33 AM - Thread Starter
KurtCocain's Avatar
Quoted: 44 Post(s)
How do I know if I am clipping? Would I only notice clipping if trying to produce 105 dB SPL?
post #4 of 12 Old 02-24-2019, 08:35 AM
Quoted: 94 Post(s)
Liked: 103
1. Based on Crown Audio calculator, you need an amp supplying ~11 watts/channel, to produce reference levels 85 dB, at a distance of 3 meters (~9 ft), with 3 dB of headroom. I'm sure your existing AVR is more than capable of supplying 11 watts/channel, all channels driven, so no, you don't need an external power amp.
2. Not necessarily (mostly no) -- SQ is a complex function of not just the equipment, but also the physical enclosure (room), distances, and so on. You may get better results by playing around with the placement, toe-in, distance from backwall, etc. Experiment.
3. As others have already explained, no.
KurtCocain likes this.
choombak is offline
post #5 of 12 Old 02-24-2019, 09:44 AM
Mickey Mouse's Avatar
Quoted: 319 Post(s)
Liked: 167
you can't measure the level with REW if you haven't calibrated it before. But if you have calibrated it why don't you use your reference directly instead of REW?
with a volume level around 50 you probably never used much more than ONE SINGLE WATT!
the volume control has a logarithmic characteristic, half the volume doesn't mean half the power but 1/10!!!
Mickey Mouse is offline
post #6 of 12 Old 02-24-2019, 10:08 AM
markmanner's Avatar
Quoted: 345 Post(s)
Liked: 294
I am not sure at what db level you would notice it, but for your AVR, with a vol. level at 50-60% of its range, it is not likely clipping. If it is clipping a lot, it would be noticeable I think. It would sound distorted and bad!
System
Spoiler!
post #7 of 12 Old 02-24-2019, 10:28 AM - Thread Starter
KurtCocain's Avatar
Quoted: 44 Post(s)
I am using REW with a calibrated miniDSP UMIK-1 mic and a calibration file for it. Does it make sense?
post #8 of 12 Old 02-24-2019, 10:32 AM
m0j0's Avatar
Quoted: 463 Post(s)
Liked: 380
I want to say power is like cowbell, you could always use some more... However, as everyone else said, based on your usage it seems you are fine with your current setup.
KurtCocain and eljaycanuck like this.
m0j0 is offline
post #9 of 12 Old 02-25-2019, 03:20 PM - Thread Starter
KurtCocain's Avatar
Quoted: 44 Post(s)
Last question - what about my speakers - even though rated at 8 ohms - may be dropping to 4 ohms or even 3 ohms. I think I read somewhere that they may be dropping to 3.2 ohms on some frequency...
In that case, if my power from the AVR still enough? Or the Denon can handle only 4 ohms, ad potentially I am losing sound as speakers drop to 3.2 ohms?
post #10 of 12 Old 02-26-2019, 09:05 AM
Quoted: 319 Post(s)
Liked: 167
"officially" the impedance shouldn't drop below 20% of the nominal impedance.
4Ohm - 20% -> 3.2Ohm
so a speaker with drops below 3.2Ohm isn't even a 4 but 3 Ohm speaker.
in the end it really doesn't matter, you probably never "squeezed" more than 1W out of your amp
post #11 of 12 Old 02-26-2019, 09:32 AM - Thread Starter
KurtCocain's Avatar
Quoted: 44 Post(s)
OK, so if the KEF Q300 are rated at 8 ohms nominal impedance... officially they should not drop more than 6.4 ohms?
post #12 of 12 Old 02-26-2019, 10:03 AM - Thread Starter
KurtCocain's Avatar
Quoted: 44 Post(s)
@Mickey Mouse Here is a German site which if I understand correctly, the speakers do drop below 4 ohms:
https://hifi-selbstbau.de/testberich...r/411-kef-q300
"Impedance minimum of 3.8 ohms around 200 Hz -> the manufacturer's impedance rating of 8 ohms is "buffed" to "simulate" a relatively high voltage efficiency"
