Owner's thread for Onkyo TX-NR696 7.2ch receiver - AVS Forum | Home Theater Discussions And Reviews
 11Likes
  • 1 Post By dfa973
  • 1 Post By Zoland2020
  • 3 Post By bimmerfreak0
  • 1 Post By Dwalker112
  • 1 Post By dfa973
  • 1 Post By LeoRavus
  • 1 Post By tomer1981
post #1 of 29 Old 03-28-2019, 04:17 AM - Thread Starter
dfa973's Avatar
Quoted: 929 Post(s)
Liked: 907
PRODUCT HIGHLIGHTS
175 W/Ch THX® Certified Select™ DAA system
Works with Sonos, Chromecast built-in*1, AirPlay 2, DTS Play-Fi®, FlareConnect™*2, Spotify®, Amazon Music, TIDAL, Deezer, TuneIn*3
Supports 5.2.2-ch Dolby Atmos® and DTS:X® playback
Dolby Atmos Height Virtualizer*4 and DTS Virtual:X™*4
HDMI Sub/Zone 2 output shares media to a second display or projector
Quad-core SoC supports 802.11ac (2x2 MIMO) Wi-Fi® specification*5
Zone 2/Zone B line-out/Front L/R pre-out with DAC shares D/A audio (including HDMI/SPDIF*6) or connects power amp
Zone 2 outputs distribute D/A audio sources (including HDMI/SPDIF*6)
Stereo Assign Mode to switch Front playback to Height channels
DSP-based Vocal Enhancer improves dialog audibility
GUI with OSD via HDMI features media input/output data display function
HDMI supports 4K/60p, 4K HDR, 4:4:4/24-bit, BT.2020, HDCP 2.2
AccuEQ Advance with AccuReflex™
One-touch volume memory-presets for A/V inputsputs
AMPLIFIER FEATURES
175 W/Ch (6 Ω, 1 kHz, 10% THD, 1 channel driven)
THX Certified Select certified Dynamic Audio Amplification
Custom High-Current Low-Noise Power Transformer
Large custom-made audio power capacitors
Non-phase-shift amp topology with discrete output stage
New dual-transistor amp output stages (L/R/C) doubles instantaneous current output for stunning dynamics and bass impact
Strengthened power-supply line for high-current dynamics
Refined HDMI grounds, short signal paths reduce noise
SoC board remote from audio paths to reduce noise
High-current drive handles 4-ohm speaker loads
High-grade AKM (AK4458) 384 kHz/32-bit multichannel D/A conversion
VLSC™ (Vector Linear Shaping Circuitry) filtering (Front L/R)
PLL (Phase Locked Loop) anti-jitter technology for S/PDIF audio
Tone controls (bass/treble) for front L/R channels
Pure Audio Mode and Direct Mode for high-fidelity sound
VIDEO & AUDIO SUPPORT
Supports HDCP 2.2, 4K/60p, HDR (Dolby Vision, HDR10, HLG), BT.2020, 4:4:4 color-space, 3D Video, ARC (Audio Return Channel), DeepColor™, x.v.Color™, and LipSync via HDMI
Dolby Atmos, DTS:X, Dolby® TrueHD, and DTS-HD Master Audio® decoding
Dolby Atmos Height Virtualizer and DTS Virtual:X 3D processing
Dolby Surround® and DTS® Neural:X upmixing technology
THX listening modes for movies, music, and games
Sound optimization for games (Rock, Sports, Action, and RPG)
SACD (Super Audio CD) playback via HDMI (2.8 MHz 2-ch/multichannel)
Theater-Dimensional virtual surround-sound function
NETWORK FEATURES
Next-Generation Network Audio with multi-room audio, streaming service integration, and remote app control
Works with Sonos certified for the Sonos Home Sound System*7
Chromecast built-in and voice control with the Google Assistant*8
AirPlay 2 multi-room audio and voice control with Siri*9
DTS Play-Fi® multi-room audio via Onkyo Music Control App*10
FlareConnect™ multi-zone audio with compatible components
Quad-core SoC processing evolves network functions and supports high-speed 802.11ac (2x2 MIMO) Wi-Fi specification
Supports Onkyo Controller remote and music streaming app*10
Hi-Res Audio playback via network (DSD 11.2 MHz/5.6 MHz/ 2.8 MHz*11; FLAC, WAV [RIFF], AIFF, and ALAC to 192 kHz/24-bit*12)
CONNECTION TERMINALS
7 HDMI inputs (1 front), 2 outputs (Main [ARC], Sub/Zone 2)
2 digital audio inputs (optical and coaxial, assignable)
4 analog RCA inputs (assignable)
3.5 mm mini-stereo analog input (front)
1 phono input with built-in MM equalizer for turntable
3.5 mm setup mic input for AccuEQ (front)
6.35 mm headphone jack (front)
2 subwoofer pre-outs
Zone 2/Zone B line-out/Front pre-out (analog RCA)
7 screw-type speaker posts
Ethernet terminal for network connection and IP control
USB input (5 V/1 A) for audio playback (rear)
AC socket for detachable power cable
ADVANCED FEATURES
AccuEQ Room Acoustic Calibration and AccuReflex
DSP Vocal Enhancer boosts dialog audibility via remote keys or front panel
Bluetooth® wireless technology and Wake on Play Standby with auto input selection supporting select smart speakers
Advanced Music Optimizer™ improves compressed audio playback
Zone 2 speaker outputs for powered simultaneous multi-source D/A audio distribution (including HDMI/SPDIF) with Zone 2 DAC; output via Zone 2 and Zone 2 line-out
Front/Height/Surround Back switching (layout dependent) for ambient listening in Stereo Assign Mode
Zone 2/Zone B line-out/Front L/R pre-out (analog RCA) with Zone 2 DAC connects compatible audio systems for synced/independent D/A playback (including HDMI/SPDIF) in Main and Zone 2; connects compatible transmitters for wireless headphones; connects power amp for Front L/R speakers
One-touch volume memory-presets for A/V inputs via front panel
1080p to 4K upscaling and GUI with overlaid OSD via HDMI
Crossover adjustment for each channel(40/50/60/70/80/90/100/120/150/180/200 Hz)
A/V Sync Control (up to 500 ms in 5 ms steps at 48 kHz)
Various standby modes and HDMI pass-through
IP control for home automation systems via LAN
3-Mode display dimmer (Normal/Dim/Dimmer)
40 FM/AM random presets
Redesigned simple remote control
Still no HDMI-eARC support...
Zoland2020 likes this.
dfa973 is offline
post #2 of 29 Old 03-28-2019, 06:49 AM
Zoland2020's Avatar
Quoted: 158 Post(s)
Liked: 94
So the only change from last year's NR686 is support for Virtual Atmos and Virtual DTS:X for those without height speakers installed.
dfa973 likes this.
America elevates you to another level.
Zoland2020 is offline
post #3 of 29 Old 03-28-2019, 07:59 AM
bimmerfreak0's Avatar
Quoted: 25 Post(s)
Liked: 33
175 a channel at 10%%%%%%%%%%% distortion wtf....what kind of rating is that. At 6 ohms too. Let's just get the elephant out of the room please. Let's rate all power supplies at 99% harmonic distortion. 100000 watts of P-P-P-POWAAAAAAAA.
bimmerfreak0 is offline
post #4 of 29 Old 03-28-2019, 05:09 PM
Quoted: 23 Post(s)
Liked: 5
Does it come with better ventilation and less hardware issues ?
eriksells916 likes this.
Dwalker112 is offline
post #5 of 29 Old 03-28-2019, 05:34 PM
eriksells916's Avatar
Quoted: 653 Post(s)
Liked: 245
Hopefully they use Pioneer hdmi boards, never seen a complaint about those going bad
eriksells916 is online now
post #6 of 29 Old 08-01-2019, 05:19 PM
bfocussvt's Avatar
Quoted: 54 Post(s)
The press release is a little confusing the way it's structured, but will this guy support IMAX Enhanced?
bfocussvt is offline
post #7 of 29 Old 08-02-2019, 02:57 AM - Thread Starter
dfa973's Avatar
Quoted: 929 Post(s)
Liked: 907
IMAX Enhanced certification program is available only on 9.2ch and up devices, the TX-NR696 is a 7.2ch receiver...
asabrag likes this.
dfa973 is offline
post #8 of 29 Old 08-02-2019, 06:34 AM
Molon_Labe's Avatar
Quoted: 3546 Post(s)
Liked: 4295
My TX-RZ1100 has been trouble free and runs cool going on two years now. It is in my family room so it is powered on most of the day. My Marantz 8805 puts out a lot more heat than the Onkyo.
Molon_Labe is offline
post #9 of 29 Old 09-19-2019, 06:38 AM
Quoted: 49 Post(s)
I recently bought this receiver and it's awesome. No HDMI issues at all (they advertise "refined HDMI grounds") and it sounds great.
I definitely prefer this to the Denon X2500H I just bought.
asabrag likes this.
LeoRavus is offline
post #10 of 29 Old 09-20-2019, 01:43 PM
Quoted: 210 Post(s)
Liked: 90
Originally Posted by dfa973 View Post
PRODUCT HIGHLIGHTS
The Stereo Assign should also let You play Stereo on the Surrounds, not just the Height.
I use this function a lot on my Onkyo.
Can @LeoRavus confirm this is true also in the 696?
asabrag is online now
post #11 of 29 Old 09-20-2019, 11:26 PM
Quoted: 49 Post(s)
Yeah you can assign stereo to play from the fronts, surrounds, surround back or height. I usually pick THX Music and haven't really played with the stereo mode much.
asabrag likes this.
LeoRavus is offline
post #12 of 29 Old 09-21-2019, 07:21 AM
Quoted: 210 Post(s)
Liked: 90
Mmm.. I didnt like THX modes so far...
post #13 of 29 Old 09-21-2019, 09:11 AM
Quoted: 49 Post(s)
For me listening mode depends on the source. Some things sound better in certain modes than others.
Like now I'm streaming CCR in DSur 7.1. I'll click through the various modes and stick to what sounds best for that track.
This receiver is still kind of new to me and trying out various things.
asabrag likes this.
LeoRavus is offline
post #14 of 29 Old 09-21-2019, 09:32 AM
Quoted: 210 Post(s)
Liked: 90
Same here about just discovering the potential.
I will give a second chance to THX Music ...
post #15 of 29 Old 10-20-2019, 03:43 PM
Liked: 2
Thinking of upgrading my old receiver Onkyo 626 to Onkyo 696. What is your experience so far with the new Onkyo 696?
Skickat från min SM-G960F via Tapatalk
krille3001 is offline
post #16 of 29 Old 10-23-2019, 02:03 AM
Liked: 1
Got my 696 a few days ago.
Had trouble getting any image on the TV. Probably an EDID issue. Turned the TV off and on again and it worked.
Other than that, so far so good. Love the sound quality, compared to my older Harman Kardon unit, which couldn't really drive my speakers properly (only 50W per channel)...
For stereo inputs (music streaming, etc) I prefer the "All Channel Stereo" mode over the THX... but that's just me.
asabrag likes this.
tomer1981 is offline
post #17 of 29 Old 11-20-2019, 10:11 AM
TreyS's Avatar
I just picked one up from BB, it was on sale. The website doesn't reflect the sale price but it was a nice discount. I've yet to unbox it, waiting for the new TV to show up Sat then I can watch my wife lose her ***** as I unveil them to her. I'm coming from a older HK AVR3600 receiver. Anxious to get this one installed!!
TreyS is offline
post #18 of 29 Old 11-21-2019, 04:25 PM
Liked: 0
TX-NR696 AccuEQ trouble
Hello,
So I just received my TX-NR696, I ran AccuEQ but am running into some odd behavior, basically the red flag for me that none of it is trustworthy is what it does with the sub, basically no matter what the sub volume is set to the AVR will set it to anywhere in-between 0 and +2, if it's cranked all the way up it just sets the distance to be lower and when turned down it thinks it's further.
For the other channels everything is either 0 or +1 and crossovers at 100hz rears 80hz center and 40 hz front l/r (I was planning on manually changing crossovers anyway)
Any tips or should I just try and learn how to manually calibrate? Or return it?
Speakers used:
Center: Klipsch R-52C
Front L/R: Klipsch R-820F
Surrounds: Klipsch CDT-3650-C
Sub: HSU VTF-3 MK5 HP
TheMontu is offline
post #19 of 29 Old 11-23-2019, 04:53 PM
Liked: 0
No one? :-( I guess I'll call them and see what they say...but I'm half tempted to just give Denon another try.
TheMontu is offline
post #20 of 29 Old 11-23-2019, 07:08 PM
Quoted: 408 Post(s)
Liked: 300
I wouldn't worry about what AccuEQ does - just set it to your liking. AccuEQ has a bad rep but none of these room correction programs are infallible.
KSpan is online now
post #21 of 29 Old 11-23-2019, 07:40 PM
Liked: 0
No one? 😞 I guess I'll call them and see what they say...but I'm half tempted to just give Denon another try.
I'm not sure it's working at all though...I guess a manual calibration would be better anyway ...I'll just have to rely on one of the apps.
TheMontu is offline
post #22 of 29 Old 12-29-2019, 12:06 AM
Liked: 0
disappointed from TX-NR 696 music performance
i got my TX-NR 696 thought that i was upgrading my TX-NR 636
but unfortunately i found its a backward setup
my old 636 was giving a very tight clean punchy bass out of my yamaha NS-SW300
with sub-woofer level set to 0 from the sittings and woofer volume level in the middle
now with the new tx-nr 696 i have to turn on all levels to the max to get a very unclear bass from it
the old 636 was having something called initial volume from settings that was giving sound more dynamic details
can't find the same on the 696 and i have to turn the volume to 40 or so to hear some details
Sherif M. Khalifa is offline
post #23 of 29 Old 12-30-2019, 06:49 PM
Liked: 0
I need help trying to figure out how to engage Dolby Atmos virtualization with Xbox games and 4k movies. I upgraded the firmware but when I'm playing an Xbox game I don't get the options in the listening modes besides multi channel, game rpg, game action, game sports, game rock, full mono, and direct.
On 4k movies I get some additional options like DTS-X but still don't understand how to engage Dolby Atmos.
I've got my Xbox set to "let the receiver decode" in it's settings. And bitstream to Dolby Atmos. But the display on the Onkyo says it's in PCM mode.
gshinert117 is offline
post #24 of 29 Old 01-03-2020, 07:47 PM
Quoted: 77 Post(s)
Liked: 42
Dolby Vision Help
Hey all! So, I know this is the 696 forum. However, I can't find the info I need elsewhere and am hoping to get some good info from someone with more knowledge than me.
I have just picked up the TX-NR686 and hooked it up to my system this evening. I am passing all my devices through the receiver to my Vizio M658-G1. However, the Onkyo is not passing through Dolby Vision. Is there a setting I have missed? I have an Apple TV 4K; Samsung UHD Blu Ray player and neither will give me DV running through the 686. They both will when I hook them straight to the TV, however. I have new Monster HDMI cables that are up to spec as well.
Sony XBR-55X850C
Onkyo TX-SR444
PS4
Polk Audio 5.1.2
Packer fan living in Michigan.
brilithos is offline
post #25 of 29 Old 01-05-2020, 04:26 PM
Liked: 0
You might check your settings that enhanced mode is on. I figured this out by searching others forums and found you have to press and hold the BD/DVD button then press the power button. You will see it say enhanced on your Onkyo Display screen.
The next thing you have to do is go into the settings of the Onkyo and change slit to Main+Sub in the audio settings and you will an option light up to allow Dolby Vision passthrough
post #26 of 29 Old 01-05-2020, 04:41 PM
Liked: 0
That main plus sub setting is under the TV/Out setting. Then you change the HDMI out to Main+Sub and Dolby Vision will light up
post #27 of 29 Old 01-07-2020, 05:44 PM
Liked: 0
Anyone actually have experience with the "Vocal Enhancer"?
It's on all their recent models so not exactly a 696 question, but this seems the most active thread.
It would be a convenient feature if it actually worked, but I have no idea if the effect is any good, and it sounds like it might be disabled a lot of the time anyway, making it useless marketing fluff.
So again, anyone actually used the thing? I appreciate any insight.
bitter_luddite is offline
post #28 of 29 Old 01-14-2020, 08:03 PM
Quoted: 210 Post(s)
Liked: 90
I tried it a few times.
It seems to redirect voice from the center channel to the Fronts. I didnt liked it at all. I preferred increasing the center's channel level.
post #29 of 29 Old 01-19-2020, 04:02 PM
Liked: 1
I bought this receiver 2 weeks ago. I can't get Arc to work in my older Panasonic e50 TV. My hdmi cable supports it. Unsure if it's the tv or receiver. So I tried optical input and the cable won't fit! I tried two cables. Never had this problem before. Could the receptacle be defective? Any else experience this?
carlito172000 is offline
