"OFFICIAL" 2019 Denon "S-Series" / "X-Series" AVR Owner's Thread + FAQ (Posts 1-8) - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 362Likes
post #481 of 1074 Old 09-04-2019, 05:09 PM - Thread Starter
jdsmoothie's Avatar
Quoted: 22914 Post(s)
Liked: 12536
Originally Posted by Dirk Manderin View Post
I just ran Audyssey on my x3600h, but the side surrounds are now way too loud (90 degrees from my seating position) vs the rest of the speakers. Anyone else run into this before? I followed the Audyssey guide in the thread pinned at the top of the forum.
If this is true for all sources, you have the ability to go into Manual Setup and adjust the speaker/sub volume levels to suit your preference; otherwise, if for only one or two sources, than you can select OPTION - CHANNEL LEVEL ADJUST - SURROUND BACK for each source you feel this applies to.
Madmax67 likes this.
jdsmoothie is offline
post #482 of 1074 Old 09-04-2019, 06:58 PM
eqzitara's Avatar
Quoted: 54 Post(s)
Thinking about buying a second amp to get 11 channels but a bit leery - How difficult is it to get the set of speakers balanced with the others? Like I plan to plug 1 set of atmos speakers to it but how hard would it be to balance it with the other two? It looks like just a knob is the way you adjust it.
eqzitara is offline
post #483 of 1074 Old 09-04-2019, 07:15 PM
batpig's Avatar
Quoted: 4931 Post(s)
Liked: 5338
If it was that big of a deal don't you think you'd hear about it?
The external amp doesn't need volume control, the AVR is controlling the individual speaker levels and overall volume. It's literally no more difficult than using the internal amps, just run Audyssey and it does it for you.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #484 of 1074 Old 09-04-2019, 07:27 PM
eqzitara's Avatar
Quoted: 54 Post(s)
Thanks, I just saw the cheap looking volume knob and it seemed really off. I thought it would be feeding electricity based on volume but I guess I misread that.
eqzitara is offline
post #485 of 1074 Old 09-04-2019, 09:17 PM - Thread Starter
jdsmoothie's Avatar
Liked: 12536
Have you reviewed post 8?
post #486 of 1074 Old 09-05-2019, 12:26 AM
mastermaybe's Avatar
Quoted: 571 Post(s)
Liked: 424
Hola:
Forgive me as this has likely been addressed on units with airplay 2...
Seeing the new appletvs have dumped an optical output...and assuming I cannot overlay the hdmi audio of one imput over another- even 2 channel- can one use the airplay 2 audio of the AVR (say a 1600) and overlay that onto an hdmi input? Useful of course for those want to watch a ballgame and listen to music.
I am assuming not- and as mentioned; I’m also assuming we have not yet reached the point where we can overlay the hdmi audio of one input over another...been a while since I have stayed completely on top of such items.
I may be missing how airplay 2 works as well- not sure if the avr “automatically” switches as an airplay source when selected or it it’s on the selectable “input” side of things.
Guess I’ve been oddly contented for a time and niot following such things, lol.
James
My Parlor and Theatre: "Jimbo's Dugout" : https://www.avsforum.com/forum/15-gen...re-parlor.html
Actual phone call (see pic to left):
 Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #487 of 1074 Old 09-05-2019, 12:45 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12536
Originally Posted by mastermaybe View Post
Hola:
James
Although the former (HDMI over HDMI) is still not possible, the <Video Select> feature (HDMI video w/Network audio to include Airplay) has been around since 2013.
post #488 of 1074 Old 09-05-2019, 01:13 PM
batpig's Avatar
Liked: 5338
What amp specifically are you looking at? Most dedicated amps don't have volume knobs, just a fixed gain.
A "volume knob" on an amplifier would actually be a gain knob -- it's just there to attenuate the input signal (if needed) to get the voltage within the right area that the amplifier will produce the desired levels. If it's there, it's a "set and forget' thing where once the gain is in the right place you never touch it again.
Setup Guide and FAQ
batpig is offline
post #489 of 1074 Old 09-05-2019, 01:16 PM
eqzitara's Avatar
Quoted: 54 Post(s)
Didn't buy it yet - was looking at an auction and considering it.
AudioSource Amp 100
Still on the fence if its okay to buy a used one and plug into a new speakers + $1000 denon 2019 - A bit afraid of something being wrong with it. I read instructions according to post 6 or 8. It said to leave it at 80%
eqzitara is offline
post #490 of 1074 Old 09-05-2019, 01:25 PM
batpig's Avatar
Liked: 5338
AudioSource Amp 100
OK that amp will be just fine. The volume knob is because this amp is primarily used for audio distribution not home theater, so it's convenient to have to set the levels properly. But like I said, for home theater it will be a "set and forget" situation.
The 80% recommendation is for people using an old receiver as an amplifier. With a dedicated amplifier you'll just set it where you need to set it so the speakers output approximately 75dB on the test tones.
Setup Guide and FAQ
batpig is offline
post #491 of 1074 Old 09-06-2019, 06:28 PM
eqzitara's Avatar
Quoted: 54 Post(s)
Oh, its like the same as the subwoofer test? Thats no big deal - was kind of afraid of something where I had to play it by ear. Always feel like something is off then.
eqzitara is offline
post #492 of 1074 Old 09-06-2019, 09:17 PM
shyko's Avatar
Quoted: 48 Post(s)
Hi All,
I just got my 750H today and testing a bit but there are some issues I wanted help or understanding.
When I am using my XBOX One X or PS4 Pro, I am always seeing Multi in. I used My xbox to play NETFLIX on ATMOS movies but they are all showing Multi in instead of ATMOS, Is there a config I need to set and force it to ATMOS?
If i directly instead an ATMOS or DTS:X disc it into both systems it does display them, my only problem is playing Streaming contents using XBOX is not allowing to display ATMOS.
Additional, the input signal is detected as below:
Multi Ch In
PCM
shyko is offline
post #493 of 1074 Old 09-06-2019, 11:16 PM
Madmax67's Avatar
Quoted: 2318 Post(s)
Liked: 2608
Originally Posted by shyko View Post
Hi All,
Multi Ch In
PCM
You need to set the source device to bitstream if possible. Otherwise the audio processing is handled by the source device and not the receiver thus the PCM multi channel in that you're seeing.
dfa973 likes this.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #494 of 1074 Old 09-07-2019, 05:34 AM
shyko's Avatar
Quoted: 48 Post(s)
Hi All,
Multi Ch In
PCM
Hi,
Is already under bitstream, if I put a disc it does show Atmos correctly. The only problem is playing with Netflix which shows PCM somehow.
shyko is offline
post #495 of 1074 Old 09-07-2019, 12:18 PM
SoCalGuy-99's Avatar
Quoted: 178 Post(s)
Liked: 251
X3600 Using Front Pre-Outs
As a follow up to the conversation we were having regarding using the X3600 as a pre-pro and configuring L/R Front Pre-Outs to disconnect the internal amps. Now that the holiday weekend is over and I'm back in town I wanted to confirm that the only way to do this is by using all 11 channels (either externally or a mixture of external & internal amps).
On the X3600 I'm running a 5.2.4 configuration and if I switch the amp configuration to 11 channels and configure the Pre-outs to Front - then I lose all Audussey settings (greyed out) even though the speakers configuration is 5.2.4.
Originally Posted by AudioHolics.com
Front L/R channel preamp disconnect ONLY happens in a 11CH speaker configuration. If you have simply a 9.1 channel configuration (5.1.4) or less, and you want to drive front L/R speakers out of external amplifier, or L/R/C, or L/R/C/SL/SR speakers out of external 5 channel amplifiers, internal amplifiers will Not be disconnected. There is no selecting or sensing mechanism to allow that unless you activate 11.1 channel Amp Assign mode and select Front L and R for pre-outs.
I want to confirm this is correct and not a user error on my part before instructing others moving forward - but due to AudioHolics and my own testing I understand that one must use All 11 channels to disconnect the L/R Front internal amps from the L/R pre-out amps.
SCG
SoCalGuy-99 is offline
post #496 of 1074 Old 09-07-2019, 12:19 PM
eqzitara's Avatar
Quoted: 54 Post(s)
Connecting REAR SURROUND to amp instead of atmos?
I got an Audio Source 100vs
https://www.crutchfield.com/S-moF28Y...-AMP100VS.html
And I am about to hook it up to my x3600h receiver. Everywhere I read recommends that I use ATMOS and hook it up to the 100vs. I am wondering if it would be an issue to use REAR SURROUND instead. I like the idea because its close to my head and less then 4 feet from view position meanwhile atmos is like 10 feet. I also don't have to worry about not noticing the atmos isn't kicking on and matching up the 4 speakers in volume/etc. I assumed the reason for doing atmos was power reasons but I am using ALWAYS ON and just using a powerstrip where its a slave to my receiver anyways.
I use standard bookshelf Klipsch 8 ohm speakers for rear and atmos speakers that are mounted on wall are 8 ohm as well.
https://www.amazon.com/Klipsch-R-15M.../dp/B00LMF41IY
eqzitara is offline
post #497 of 1074 Old 09-07-2019, 12:46 PM
mrtickleuk's Avatar
Quoted: 5203 Post(s)
Liked: 7530
Hi,
There are two settings that both have to be correct. 1, bitstream. 2, "secondary audio" off.
The second one is sometimes used for "sound effects" when you move the highlight around the menus of a disc.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #498 of 1074 Old 09-07-2019, 06:26 PM
smile's Avatar
Quoted: 91 Post(s)
Liked: 29
x3600h will not display my cable TV box.
It worked for a few weeks, when the stars were aligned, but not now.
I have bought new premium cables, switched to different HDMI input slots, turned equipment on and off in different sequences. Now, the last 2 efforts, it will operate for maybe a minute and them go blank and quiet.
This cable box worked just fine with the 5yo Anthem receiver it replaced. Only difference is the Denon.
Whats my answer? Who do I call? How do I fix this? Is my unit broken? An AVR that will not operate by simply plugging in the source. Can you tell I'm fed up? Oh, and will somebody tell me the score of the game I am not watching?
Thx for any guidance.
smile is offline
post #499 of 1074 Old 09-07-2019, 08:28 PM
Madmax67's Avatar
Liked: 2608
This is correct. Also anytime you change an amp assign setting Audyssey will need to be rerun. There's not much sleep to be lost over this amp disconnected or not disconnected thing. If you run an 11 channels setup and externally amplify the mains it's a minor benefit spec wise. If not no big deal.
dfa973 likes this.
Madmax67 is offline
post #500 of 1074 Old 09-08-2019, 12:20 AM
Madmax67's Avatar
Liked: 2608
Whats my answer? Who do I call? How do I fix this? Is my unit broken or is it just a piece of shxt equipment? An AVR that will not operate by simply plugging in the source. Can you tell I'm fed up? Oh, and will somebody tell me the score of the game I am not watching?
The difference to concentrate on is the 3 weeks the Denon was working fine not necessarily the receiver swap. Start with checking settings in the cable box then check settings in the receiver. Cable changes are usually meant for no passthrough from the beginning rather than after almost a month of having no passthrough issues and no bandwidth changes. Yes, HDMI cables can go bad but that's very rare so unless your passing through higher bitrate content than before I'd start with preset settings in both the box and the receiver. HDMI standard/enhanced settings etc..
Madmax67 is offline
post #501 of 1074 Old 09-08-2019, 12:45 AM
Liked: 0
Denon x3600h help
I have the denon x3600h and an audiosource AMP100vs and cant seem to get the amp to trigger in via rca cable. What am I doing wrong. I thought I could do it without the actual trigger cable. Both brand new items so I need help please
Ruknasty is offline
post #502 of 1074 Old 09-08-2019, 01:13 AM
Worf's Avatar
Quoted: 862 Post(s)
Liked: 591
You could,but your rear surrounds are so close, it's not really a good use of your amplifier. Remember the closer the speaker is to you, the less power you need to drive it to a particular volume.
Typically Atmos speakers are further away and thus need more power to drive. Of course, if this is the only amp in your system, you would be best off using it on the left and right front mains where most of the sound comes from.
Worf is offline
post #503 of 1074 Old 09-08-2019, 01:20 AM - Thread Starter
jdsmoothie's Avatar
Liked: 12536
The AudioSource is only a 50W amp and suggested for the 2nd set of Atmos speakers as they generally will require less power than any of the floor speakers.
Note also, the X3600H is discussed in the 2019 Denon Owner's thread. Review posts 1-8 for some general helpful information.
https://www.avsforum.com/forum/90-re...sts-1-8-a.html
post #504 of 1074 Old 09-08-2019, 07:07 AM
smile's Avatar
Quoted: 91 Post(s)
Liked: 29
The Denon never worked fine. There are posts from me several weeks back. I originally would turn all off, change the HDMI input a few times and it would work. Someone suggested new cables, which I bought and tried. The Anthem worked for years. I buy a new Denon and drop it in, and I get this.
There are no meaningful options in the cable box settings I can access. I have tried 3 different cables, to include 2 new premium ones.
Now, it turns on, works for 30 seconds, then I lose picture and sound. One occasion last night it worked for 10 minutes; I turned off only the TV and went to bed. Turned only the TV back on this morning and it worked for 30 seconds before it disappeared. This is different behavior than originally, but it has never operated properly.
smile is offline
post #505 of 1074 Old 09-08-2019, 07:50 AM
Baff's Avatar
Quoted: 203 Post(s)
Liked: 184
Have you tried plugging the cable box directly into the tv to see if the same thing happens? I understand it worked fine with your old AVR, but you've been moving stuff around. It is possible that your cable box or tv was about to go bad, and a little extra jostling pushed one of them over the edge. I've had that happen before.
With my current setup I also had a an issue at first where everything would turn off after 10 minutes. It had to do with my Shield box. When I turned on the tv, it would wake up the Shield box. If I wasn't using the Shield box it would go to sleep after 10 minutes and send a signal via CEC for my AVR and tv to turn off too. Took a while to figure that one out, but was easy to fix once I did. So if you have anything else plugged into your AVR or tv, also try unplugging those to see if that has any effect.
LG 65" C9; Denon AVR-S750H
5.1.2: Emotiva Airmotiv C2, T-Zero (x2), E1 (x4); HSU VTF-2
Baff is offline
post #506 of 1074 Old 09-08-2019, 09:06 AM
two_tonn's Avatar
Hi All,
Multi Ch In
PCM
When you play a game/Netflix with the Xbox One that has Atmos, it's using PCM/Dolby MAT 2.0 for this....otherwise known as "lossy" Atmos. That is why you see PCM(Atmos data overlayed onto the PCM). When you play a Blu-ray you're seeing Atmos -TrueHD because it's the lossless audio coming from the disc.
It's two totally different versions of Atmos... Lossy vs Lossless . Dolby MAT 2.0 vs TrueHD
two_tonn is offline
post #507 of 1074 Old 09-08-2019, 10:08 AM
bobknavs's Avatar
Quoted: 2444 Post(s)
Liked: 1743
I'm not familiar with the 3600.
I have a 4300. The allowed speaker pairs that do not use the internal amps are either the LR fronts or the rear heights. If the 3600 is the same, what you ask is unavailable. That assumes that you want 11 channels using only the 3600 and an external stereo amp.
bobknavs is offline
post #508 of 1074 Old 09-08-2019, 10:36 AM
bobknavs's Avatar
Liked: 1743
Stupid question, probably:
The AMP100VS has a mode switch on the back with three settings: trigger, auto on, and normal. I believe that you want auto on. (I don't own the amp. I have its AD1002 Class D cousin, although I'm not using it any more.)
I prefer the trigger cable. It has a 3.5 mm male mono plug at each end. You don't need to buy a cable that is advertised as a trigger cable, as long as it has the right plugs.
bobknavs is offline
post #509 of 1074 Old 09-08-2019, 03:30 PM
smile's Avatar
Quoted: 91 Post(s)
Liked: 29
Good advice, thank you very much. I removed all inputs and the trigger, excepting the Cable box. Now seems to be working fine. Something screwy with the ROKU remote signal, as well or in addition.
smile is offline
post #510 of 1074 Old 09-08-2019, 06:58 PM
Baff's Avatar
Quoted: 203 Post(s)
Liked: 184
If it is the Roku causing the problem, on the Roku you can go to Settings > System > Control Other Devices >
Should be something there you can change that should stop it.
Baff is offline
