How to make rear speakers wireless using rocketfish, OSD or others? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-02-2019, 06:50 AM - Thread Starter
super kermit's Avatar
Quoted: 71 Post(s)
Looking to make my rears wireless
OSD WRSK250 2X25W 2.4GHz Wireless Speaker and Subwoofer Kit with Transmitter and Receiver
https://www.amazon.com/OSD-WRSK250-W...T0NDAY4WR22X91
Amphony 1700 Wireless Speaker Kit with one Wireless Amplifier, 2x40 Watts, 300ft range
https://www.amazon.com/Amphony-1700-...T0NDAY4WR22X91
Rocketfish™ - Wireless Rear Speaker Kit Model:RF-WRSK18
https://www.bestbuy.com/site/rocketf...?skuId=6254098
Which one is the best option please?
super kermit is offline
post #2 of 4 Old 05-02-2019, 08:40 AM
Quoted: 583 Post(s)
Liked: 306
probably all in the same league... either way the rear speakers are wired to the amp/wireless receiver... but they are all cheap enough to try out(assuming you are not budget constrained)
if one of those doesn't work for you there is some pro audio gear that might - alto audio makes good wireless system for powered speakers (https://www.altoproaudio.com/products/stealth-wireless) there are many powered speakers that are reasonably prices that would work well with this. And each of your surrounds could be independent of the other.
good luck.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #3 of 4 Old 12-02-2019, 02:13 PM
alanimal's Avatar
Hey did you have any luck on this? I am curious to know what product you ended up with.
I have a similar situation where I cannot run cables to my rear speakers from my Anthem receiver and would like to see if Wireless is ok?
alanimal is offline
post #4 of 4 Old 12-02-2019, 03:12 PM
eriksells916's Avatar
Quoted: 651 Post(s)
Liked: 245
I don't think anything will send a signal to passive speakers, as smithsabom mentioned.
In my research, OSD and the PE (dayton) units are good, the outlaw audio units have the least amount of dropouts and can play from 10hz to 20khz. https://www.outlawaudio.com/products/OAW4.html
eriksells916 is offline
