AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Receivers, Amps, and Processors (https://www.avsforum.com/forum/90-receivers-amps-processors/)
-   -   buy budget atmos receiver (https://www.avsforum.com/forum/90-receivers-amps-processors/3067664-buy-budget-atmos-receiver.html)
audionewer 05-15-2019 06:50 AM
i am putting this receiver into the room that is 14(L)x12(w)x10(H). do u guys think i can put like 5.1.4 atmos system into this room or not. if so how can i put? what is the min. dimension for 5.1.2 or 5.1.4 system?
KidHorn 05-15-2019 07:52 AM
I don't see why not. You can put atmos in any room as long as there are places to mount the speakers.
Put 3 up front, 2 surrounds on your left and right walls. One set of heights on the ceiling up front, another set on the ceiling near the back.
bobknavs 05-15-2019 08:30 AM
Depends somewhat on the seating.
A lot of possible configurations: https://www.dolby.com/us/en/speaker-...des/index.html
a detailed PDF: https://www.google.com/url?sa=t&rct=...xrHQ-qLxeC3I1z
What receiver are you considering? A year or so ago I would have said that "budget" and 5.1.4 were incompatible, but more recently the Onkyo TX-RZ730 has become available for about $500.
Rgarc 05-15-2019 10:03 AM
If you can put some space between the seating area and the back wall (3ft +) then you should be fine with 5.1.4, but if your seating area is against the back wall the n you should stick with 5.1.2
rennyrb 05-15-2019 11:12 AM
Even cheaper as of late:
Amazon has the Pioneer LX303 (rebranded Onkyo NR787) for $400, which is the lowest price I've seen for a new 9.2 receiver.
They also have the Onkyo RZ830 for $500, which adds some more power, 11ch preouts, and eARC via firmware update.
eriksells916 05-15-2019 11:19 AM
Since you asked about budget 5.1.4 receivers, here are some options off the top of my head. Pricing from low to high as budget is subjective. Check the deals and great found deals threads for locations and pricing (AC4L, Amazon, onkyo direct, etc.)
rz630
nr787
rz730
lx503
rz830 - highly recommended on the forum right now and on sale!!!!!!!!!!!!!!
drx-3.2
x4400
sr6012
drx-4.2
x4500h
sr6013
a2070
sr7012
oops didn't see @rennyrb already posted a good list! I forgot the lx303 too.
Good luck!
audionewer 05-15-2019 11:23 AM
can i still reuse my speakers ? i have all speakers ( right, center,left, 2x rear speakers). all speakers is 6 ohms with 120w.
eriksells916 05-15-2019 11:40 AM
unless you want upfiring modules on your front LR speakers then look into the recommendations by @bobknavs and @KidHorn
Rgb 05-15-2019 11:46 AM
Might want to go with a used Denon 32xx/33xx or 42xx/43xx
audionewer 05-16-2019 11:22 AM
upfiring modules = atmos speaker that put top of left and right speakers.
i am thinking to upfiring modules for it.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
