Denon AVR-S540BT Settings?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-18-2019, 05:13 PM - Thread Starter
Liked: 0
I just put together a garage stereo setup using my 4 15'' Planet Audio Subwoofers and everything sounds pretty good but I know it can sound cleaner and better and I need help with the technical stuff.
Here's my whole setup:
Four - 38cm (15") Subwoofer from the X Serie 275W RMS 400W MAX Impedancy: 4 Ohm Frequency response: 22Hz - 2,5kHz 75oz. Magnet Efficiency: 93dB @ 1w/1m 51mm Alu Voice Coil Steelbasket Cevlar Cone Depth: 159mm
Two - BOSTON ACOUSTICS A25 5.25" 2-Way Bookshelf Speaker Gloss Black
One - DENON AVR-S540BT 5.2-Ch x 70 Watts Bluetooth A/V Receiver
One - BEHRINGER KM750 Professional 750-Watt Stereo Power Amplifier with ATR (Accelerated Transient Response)
Like I say it works great and I have the Behgringer turned up about halfway but it seems like the bass is muddy or muffled. I'm not sure what settings I can adjust on my receiver to make everything play nicely together. As of right now everything is default and I just play music from my iphone. Any advice would be greatly appreciated!
Name:	SPEAKERS SETup.jpg
SlashtaCross is offline
post #2 of 6 Old 05-21-2019, 11:32 AM - Thread Starter
Liked: 0
bump
post #3 of 6 Old 05-21-2019, 12:09 PM
afrogt's Avatar
Quoted: 2254 Post(s)
Liked: 1486
Are those 4 subs powered or are you using the Behringer amp to drive them? Are you using the sub outs on the Denon at all? How is everything connected?
more info would be helpful
Afro GT
afrogt is offline
post #4 of 6 Old 05-21-2019, 12:32 PM - Thread Starter
Liked: 0
The subs are ran to the behringer and then the behringer is connected to the Sub out on the back of the denon
post #5 of 6 Old 05-21-2019, 12:38 PM
afrogt's Avatar
Liked: 1486
Did you plug in the microphone and run the calibration program on the Denon? Then set your front speakers to SMALL with a crossover of 80hz?
Four 15" woofers in a lot of bass.
Afro GT
afrogt is offline
post #6 of 6 Old 05-21-2019, 12:52 PM
Moderator
rboster's Avatar
Quoted: 1656 Post(s)
Liked: 2347
Please post your questions in the owner's thread for your receiver
https://www.avsforum.com/forum/90-re...sts-1-8-a.html
rboster is offline
Closed Thread Receivers, Amps, and Processors
