Receiver purchase advice - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jdsmoothie
post #1 of 5 Old 05-21-2019, 11:25 PM - Thread Starter
adaboost's Avatar
Quoted: 13 Post(s)
Liked: 6
Question Receiver purchase advice
Got tired of dealing with 4k HDR routing issues from an
Apple TV -> Marantz 7012 -> JVC RS420
Cables seemed to be fine (4K60 HDR from Apple to JVC through the 50ft was perfect), but could only muster 4K60 non-HDR through Marantz. The Marantz is going back, thinking about just getting the same model but from a reputable dealer as in theory it should have worked? (all firmware updated, trolled through ~20 pages of forums across the internet, both receiver and projector manuals with most combinations of settings). Though was wondering if there were any recommendations for a 5.1.2 setup (B&W 702s2 LR, HTM71S2 Center, Klipsch/Elac top-middle ceilings/side surrounds, HSU VTF-15H). Leaning towards Marantz as it seemed to subjectively have a warmer sound than the Denon I've tried (4400H). Budget is probably somewhere around 1-3k, any pointers / recommendations would be appreciated!
Preferred Requirement(s):
- Known compatibility with Apple 4k HDR -> JVC RSx20/RSx40 HDR
adaboost is offline
post #2 of 5 Old 05-22-2019, 03:04 AM
jdsmoothie's Avatar
Quoted: 21894 Post(s)
Liked: 11866
More than likely a cable related issue as the signal is weakened when passing through an HDMI repeater (ie. AVR) and 50' is an extreme distance for 4k. Consider using a fiber optic HDMI cable.
https://www.amazon.com/d/HDMI-Cables...ing/B077D37MT3
smithsabom likes this.
jdsmoothie is offline
post #3 of 5 Old 05-22-2019, 09:13 PM - Thread Starter
adaboost's Avatar
Quoted: 13 Post(s)
Liked: 6
I thought it was the cable as well (50' Monoprice Luxe CL3), but I brought the receiver over to the projector and used a separate high-speed Amazon cable to connect it within 6ft and still can't seem to pass 4k HDR (SDR only).
I also just tested with a newer SR6013 and still have the issue. Thanks for the pointer to the cable, I'll give it a shot to see if I can rule out more variables. The issues seem very similar to ones discussed over here: http://www.remotecentral.com/cgi-bin...read.cgi?40075
adaboost is offline
post #4 of 5 Old 05-23-2019, 08:16 AM
jdsmoothie's Avatar
Liked: 11866
If you can test with a 6' 4k "Premium" certified HDMI cable, that would be best.
https://www.monoprice.com/product?p_id=15429
post #5 of 5 Old 05-24-2019, 10:24 PM - Thread Starter
adaboost's Avatar
Quoted: 13 Post(s)
Liked: 6
This ended up solving the problem. Thanks JD!
I'm disappointed that a Monoprice branded HDMI cable failed to work w/4k60p w/HDR. I didn't realized adding HDR pushed the bandwidth limits that much more to make the cable fail beyond 4k60p w/SDR
adaboost is offline
