Denon AVR 2308CI plastic insulating pads - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Mark 461
post #1 of 3 Old 05-25-2019, 10:09 PM - Thread Starter
Mark 461's Avatar
Question Denon AVR 2308CI plastic insulating pads
Good Morning all,
Recently opened up this receiver since I was having problems with the left channel. I thought it was due to cracked or worn
solder but it wasn't. After cleaning the unit and putting it back together, it started blowing 10 amp fuses. The CPU
seems to be fine since it's blinking green when starting up, and then solid green but the relay near the output terminals
doesn't turn on. Anyway, after reading on the web and trying to figure out why the fuse kept blowing, a repair article stated
to replace the plastic insulating pads for the transistors or it's going to short out on the heat sink. I didn't realize the plastic
pads purpose when putting it back together and I threw them away. Does anyone know where I can find a suitable
replacement? Is it a special kind of plastic? Thanks.
Mark 461 is offline
post #2 of 3 Old 05-26-2019, 01:29 AM - Thread Starter
Mark 461's Avatar
Just a follow-up after further research. I've found they're actually called transistor insulator pads. The ones in the amp appear to be of the mica variety. As for where to source these locally, I have no idea. Would a hardware or building supply store have something like this? Or an alternative in sheet form.
deangale123 likes this.
Mark 461 is offline
post #3 of 3 Old 05-26-2019, 02:25 AM
Liked: 0
Try element 14 or Digikey type in transistor insulating pads
Sent from my SM-T113 using Tapatalk
deangale123 is offline
