Shallow Depth Receiver Needed? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-19-2019, 07:09 AM - Thread Starter
Liked: 0
I recently purchased a home that is wired for multi-zone tv and sound. The living room has wires for 5 speakers a TV mount above the fireplace with an HDMI and coaxial cables. The dining room is wired for a TV mount above the fireplace with HDMI and coaxial cables. There are two speakers on the outside patio. Everything is wired to run from an open, built-in shelf in the living room. The biggest problem I have encountered is that the shelf for the receiver is only 10" deep! I can't find a system that will fit.
Any thoughts, suggestions and help is greatly appreciated!
Jessica Driver is offline
post #2 of 4 Old 06-19-2019, 12:27 PM
jdsmoothie's Avatar
Quoted: 22007 Post(s)
Liked: 11931
Taking into account about 2" for cable connections, that means a receiver with an 8" depth. What is the height of the shelf and is there an open back for proper ventilation? Suggest you find a new location for the receiver.
jdsmoothie is offline
post #3 of 4 Old 06-19-2019, 02:21 PM - Thread Starter
Liked: 0
Thanks for your response!
The shelf is adjustable height. Right now it is set at about 24". Since it's already wired for that location, I really don't want to spend the money to rewire it elsewhere.
post #4 of 4 Old 06-19-2019, 09:03 PM
KD5MDK's Avatar
Quoted: 37 Post(s)
Can you take a picture? It may be possible to install a larger shelf.
KD5MDK is offline
av receiver
