How to use 12v Trigger - AVR--->AVR - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jdsmoothie
post #1 of 3 Old 06-20-2019, 08:36 AM - Thread Starter
Quoted: 226 Post(s)
Hello,
I use two AVRs for 7.1.4.
LCR = Old Denon 1906. All other speakers are on a Denon x4300h. All sources connect to the x4300h.
In order to have the 1906 turn on automatically when I turn on the x4300, what do I need to do?
I don't see a 12v trigger on the 1906, but I'm not sure if there is another way.
x4300
https://assets.denon.com/assets/imag...?RenditionID=1
x1906
cowbodude99 is offline
post #2 of 3 Old 06-20-2019, 10:01 AM
jdsmoothie's Avatar
Quoted: 22770 Post(s)
Liked: 12419
Denon receivers have 12v trigger "outputs" as opposed to amps that have 12v trigger "inputs." Consider purchasing a smart power strip that would power on the "slave" devices when the "master" (ie. X4300H) powers on.
https://www.amazon.com/Smart-Strip-L...19641176&psc=1
bigguyca likes this.
jdsmoothie is online now
post #3 of 3 Old 06-20-2019, 10:13 AM - Thread Starter
Quoted: 226 Post(s)
Ah ok! I might be able to do this with my Harmony Hub. I think they have a lot of the same IR codes, but I think I can work it out with additional IR cables.
I guess I'll just have to mess around with it and see what works!
