Is There a Way to put Antenna Cable Through Yamaha Reciever? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By bobby94928
  • 1 Post By DrDon
  • 1 Post By sasmith129
post #1 of 11 Old 06-26-2019, 03:32 PM - Thread Starter
Liked: 0
I apologize if this is a dumb question...
I am putting a new antenna on the roof & was wondering if there was a way to somehow have the rg6 cable go through my Yamaha RX-A1010 receiver & then to our TV?
There is no rg6 input on the receiver but there is a hdmi in & output.
Thanks very much
scampcamp is offline
post #2 of 11 Old 06-26-2019, 04:15 PM
bobby94928's Avatar
Liked: 801
Thanks very much
Your Yamaha receiver has no TV tuner so, no, you can't do that. Does your TV not have an antenna input?
Bobby
bobby94928 is online now
post #3 of 11 Old 06-26-2019, 06:45 PM - Thread Starter
Liked: 0
Yes the TV has a antenna input but I was hoping to have a hdmi go to the TV so I could use the Yamaha for sound etc.
post #4 of 11 Old 06-26-2019, 06:50 PM
bobby94928's Avatar
Liked: 801
Does your TV have ARC out and your Yamaha ARC in? If so that will give you what you are looking for.
Bobby
post #5 of 11 Old 06-26-2019, 06:55 PM
bobby94928's Avatar
Liked: 801
Looking further, your Yamaha has ARC. What make and model is your TV?
DonoMan likes this.
Bobby
post #6 of 11 Old 06-27-2019, 08:19 AM
Super Moderator
DrDon's Avatar
Quoted: 2193 Post(s)
Liked: 4101
Moved to Receivers.
Please read posts that say READ BEFORE POSTING... before posting.
That said, if your TV doesn't do ARC, you'll need an external tuner/set top box. If you're doing OTA, see our HDTV Recorders section for solutions.
DonoMan likes this.
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is online now
post #7 of 11 Old 06-27-2019, 10:38 AM
sasmith129's Avatar
I've always used an optical cable (TOSlink) to achieve this. It's an extra cable but they're not expensive. Most current/recent TV's offer this as an output and most receivers have several as inputs. Just another option to consider...
Sent from my SHIELD Tablet K1 using Tapatalk
bobby94928 likes this.
sasmith129 is offline
post #8 of 11 Old 06-29-2019, 02:01 AM - Thread Starter
Liked: 0
Yes, all our TVs have ARC. Thanks for all of the replies. I really appreciate it.
This is a great forum.
post #9 of 11 Old 06-29-2019, 08:10 AM
bobby94928's Avatar
Liked: 801
Then all you have to do to get the TV sound to your Yamaha is to plug HDMI from whichever port is the ARC port on both the TV and the AVR. Set your Yamaha input to TV Sound or whatever it might be called on the Yamaha it is TV Audio on my Denon. You should now have sound, including 5.1, directly from the TV.
Bobby
post #10 of 11 Old 07-05-2019, 06:34 AM
Charles Tintera's Avatar
Quoted: 105 Post(s)
Liked: 30
Excuse me for stepping in. When you do this hook-up, essential Antenna to TV to Receiver via HTMI/ARC (correct?) don't you need to turn off the audio (speakers) on the TV?
Charles Tintera is offline
post #11 of 11 Old 07-05-2019, 08:12 AM
bobby94928's Avatar
Liked: 801
Yes, that is true. Otherwise you will have an echo effect...
Bobby
