AV Receiver Suggestions?? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Mocs123
  • 1 Post By Dennis Boone
post #1 of 7 Old 07-09-2019, 04:56 AM - Thread Starter
Liked: 6
I am looking for a new receiver to couple with my Emotiva XPA-5 Gen2 Amp. I will be a running 5.2.2 speaker set-up. The only speakers that will be powered by the receiver will be the 2 height speakers. My budget is $2k max. If it is not necessary to spend the entire $2k then I an good with that. I would like to have a quality unit that provides adequate voltage from the pre-outs to the amp as well as with the latest processing capabilities, Bluetooth, etc. I will not be running dual zones or anything like that. I have not researched receivers that much yet so I was hoping you folks could get me pointed in the right direction. Thank you!
Dennis Boone is offline
post #2 of 7 Old 07-09-2019, 05:50 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
Yamaha from 6 series of you prefer budget, or Denon from 3500 series..
Sent fra min AGS-W09 via Tapatalk
IIDexII is offline
post #3 of 7 Old 07-09-2019, 07:40 AM
Mocs123's Avatar
Quoted: 178 Post(s)
Liked: 83
Go to Accessories 4 Less and check out their deals on the Onkyo RZ830, Dennon 4400H or Marantz 6012. Any of the three should meet your needs.
smithsabom likes this.
7.1.4 Theater Room (In Progress): JVC-RS46U, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic DBT-110, JBL Studio 270’s, 4 - 15" DIY Sealed Subs
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne
Mocs123 is offline
post #4 of 7 Old 07-09-2019, 03:34 PM
eriksells916's Avatar
Quoted: 421 Post(s)
Liked: 159
@DennisBoone
7 channels with full preouts
Denon x3400/x3500 - excellent room correction, full preouts and phono on x3500 (finally)
Yammy rx-a860/a1060, a870/a1070, a880/a1080 - excellent quality, similar to x3500
9 channels with full preouts
rz830 - budget leader, good power and can expand to 11 channels (maybe you will one day)
x4400 - excellent HT receiver with xt32 which has dual sub control
sr6012 - cousin to x4400 with less power, but still has xt32, 9 channels and can expand to 11
NAD 758 v3 - highest priced here but most power, best room correction with dirac live
Open box specials here for you https://www.safeandsoundhq.com/colle...ition_open-box
eriksells916 is offline
post #5 of 7 Old 07-09-2019, 04:15 PM
pase22's Avatar
Quoted: 3219 Post(s)
Liked: 2672
Marantz 6013 or Denon X4400/4500. These can be had well within budget at A4L. The X4400/4500 and Marantz can process up to 11 channels in case you want to expand to 5.1.4. The X3400/3500 is limited to 7 channels so keep that in mind when shopping.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #6 of 7 Old 07-09-2019, 05:53 PM - Thread Starter
Liked: 6
Thanks for the suggestions. I found a great deal and pulled the trigger on the Marantz SR6013. Hopefully it will be a good decision. Cheers!!
IIDexII likes this.
post #7 of 7 Old 08-13-2019, 08:00 PM
rupedogg24's Avatar
Quoted: 146 Post(s)
Liked: 152
How is the Marantz working out for you? I'm trying to make the same decision as you did.
Sent from my SM-G965U using Tapatalk
Projector: Epson 5040ub DIY 140" Acoustic Screen
AVR: Onkyo RZ1100 (Main)
Blu-ray: PS4 -- Panasonic UB900
Speakers: 5.2.4 Atmos Sound System
Subwoofers: Dual Marty Cubes w/SI 18" - DIY Build w/SI 15"
rupedogg24 is offline
