Hdpc 2.2 - Do I need a new receiver for hdr? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-18-2019, 08:21 PM - Thread Starter
Challe77's Avatar
Quoted: 41 Post(s)
Hi, I read in a post that you cant use a splitter from an apple tv4k for example where one goes to projector and the other goes to an old receiver, the connection detect the the hdmi on the receiver as non hdpc 2.2 and sends a normal sdr signal to the projector, is this true?
I also have a sony wireless headset mdr hw700ds that is 4k passthrough but I dont know if its hdpc 2.2
finally I have a splitter after the receiver arc out where one is hdmi out to the projector and the other is optical out to another wireless headset, how does this affect hdcp 2.2?
/Challe
Challe77 is offline
post #2 of 12 Old 07-19-2019, 03:09 AM - Thread Starter
Challe77's Avatar
Quoted: 41 Post(s)
ok I’m answering my own question, a device called hd fury avr key seems to solve my needs, it separates the 4k hdr stream without handshake issues, then I can use my non hdpc2.2 devices at the audio end.
Challe77 is offline
post #3 of 12 Old 07-19-2019, 03:14 AM
Mashie Saldana's Avatar
Quoted: 1161 Post(s)
Liked: 995
That should work fine.
For future reference it is HDCP (High Definition Copy Protection).
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is online now
post #4 of 12 Old 07-19-2019, 06:23 PM - Thread Starter
Challe77's Avatar
Quoted: 41 Post(s)
looks like they stops selling them like right now, should I get one while I can or are there other just as cheap alternatives??
Challe77 is offline
post #5 of 12 Old 07-19-2019, 06:29 PM - Thread Starter
Challe77's Avatar
Quoted: 41 Post(s)
also, does the devices after the arc out on receiver have to be hdcp 2.2 as well?
Challe77 is offline
post #6 of 12 Old 07-20-2019, 01:38 AM
Liked: 995
Unless you have a device like the HD Fury to strip off HDCP then all points in the chain have to support it.
There are a few of those HD Fury's on eBay still: https://www.ebay.com/itm/HDfury-4-K-...I/173223805377
post #7 of 12 Old 07-20-2019, 01:41 AM - Thread Starter
Challe77's Avatar
Quoted: 41 Post(s)
yeah so that means a new receiver wont solve all my problems.
Challe77 is offline
post #8 of 12 Old 07-20-2019, 01:49 AM
Liked: 995
Why are you connecting the headset using HDMI btw?
post #9 of 12 Old 07-20-2019, 01:57 AM - Thread Starter
Challe77's Avatar
Quoted: 41 Post(s)
sony mdr hw700ds wireless headset and another headset trough arc out
Challe77 is offline
post #10 of 12 Old 07-20-2019, 09:12 AM
Liked: 995
So what is your full HDMI chain? ATV -> TV -> Receiver -> Headset
Have tried and failed to get it working or are you just looking at building such a setup?
post #11 of 12 Old 07-20-2019, 06:41 PM - Thread Starter
Challe77's Avatar
Quoted: 41 Post(s)
my current setup is rather complicated with splitters and hdmi-opt out conversion boxes but works great. But if I buy a new hdr projector I need a new configuration to avoid the hdcp 2.2 problem. The hdmi-opt cnersion box I can replace to hdcp 2.2. But the box for the other headphones cant be replaced to hdcp 2.2 since it come with headphones, it has hdmi in from the reveivers arc, It also has opt in so I might have to use that and settle for lesser sound. An avr key will work but a new receiver with atmos is just 2000$ more...
Challe77 is offline
post #12 of 12 Old 07-20-2019, 08:37 PM - Thread Starter
Challe77's Avatar
Quoted: 41 Post(s)
I meant. just 200$ more 😉
Challe77 is offline
