Are all 7 speakers blown or is it my receiver? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By tonygeno
post #1 of 14 Old 07-20-2019, 05:44 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
I have a yamaha TSR-7810 receiver which is connected to 7 speakers. Suddenly speakers started sounding "hoarse" at higher volumes. I think the problem has become worse in a couple of days. I thought may be my front speakers have gone bad. So, I tried running the center channel alone. That also sounds bad. Every speaker sounds bad in every channel combination at high volumes. Do you think all my speakers have gone bad? Or, is it my receiver that has gone bad?
I have access to an oscilloscope, but I don't have another amplifier (or receiver) or another speaker (other than the 7), to test whether the speakers are bad or the receiver.
What could cause either of the two problems?
codwapeace is offline
post #2 of 14 Old 07-20-2019, 05:57 AM
lizrussspike's Avatar
Quoted: 1227 Post(s)
Liked: 1833
Need more info. What happened? Is your receiver warm/hot? Is your receiver flashing red?
lizrussspike is offline
post #3 of 14 Old 07-20-2019, 06:51 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
Nothing. Everything is normal except the harsh sound at high volumes. This situation has become worse over the course of a week. The harshness has slowly increased.
post #4 of 14 Old 07-20-2019, 07:16 AM
tonygeno's Avatar
Quoted: 404 Post(s)
Liked: 144
Doubt it's all 7 speakers. Sounds like the receiver has a problem.
liverpool_for_life likes this.
Tony
In search of the Holy Grail.
tonygeno is online now
post #5 of 14 Old 07-20-2019, 09:37 AM
Noel Hart's Avatar
Liked: 2
If you have a multimeter, check the resistance across the speaker terminals with nothing else hooked up to them. You should read approximately the stated resistance of the speakers (8, 6, or 4 ohm likely). If it fluctuates or is more than a few tenths of an ohm off, you probably have blown speakers.
Noel Hart is offline
post #6 of 14 Old 07-20-2019, 09:46 AM
pase22's Avatar
Quoted: 3350 Post(s)
Liked: 2824
How old is the AVR?
Have you tried running in direct or straight mode?
You can just go to best buy and pick up an AVR. Test it out to see if the issue persists. If no, it's the AVR. If yes it's the speakers. Either way return the AVR and get one cheaper somewhere else if it's the AVR.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #7 of 14 Old 07-20-2019, 11:24 AM
DonoMan's Avatar
Quoted: 246 Post(s)
Liked: 194
Test the speakers with a multimeter. IF you decide to try the speakers on another receiver, keep the volume super low. Generally if you blow speakers you will hear a loud pop and/or smell burned epoxy (from the voice coil) and it should be fairly obvious. But maybe it happened when you were out of the room or some weird fluke happened. Blown speakers can become open and will present no load to the receiver, but they can also short out and if you try them on a different receiver, they could then blow that receiver. You could spend around $20 on a Uni-T multimeter. You can get even cheaper no-name multimeters which would be fine for this purpose (but I don't recommend the cheapest multimeters for use with mains voltage because the cheap multimeters have less safety features). For measuring resistance, without needing to be the most accurate, the cheap meters are fine.
DonoMan is offline
post #8 of 14 Old 07-20-2019, 11:54 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
The tweeters are working. I can hear them. I have a sample audio of the problem. It is an AAC file (less than 1 MB). The song is in a foreign language but you can hear the problem. I change the volume to show I see distortion at high volumes.
https://drive.google.com/file/d/1_b5..._cNbUHotm/view
post #9 of 14 Old 07-20-2019, 11:57 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
Originally Posted by pase22 View Post
How old is the AVR?
1.5 years.
Yes no difference. They sound pretty distorted at high volumes.
post #10 of 14 Old 07-20-2019, 03:09 PM
Liked: 1833
Agree with others @codwapeace , pick on e up to demo at best buy, that you could return in 15 days. I bet it is the receiver, are there any other sound modes you can try on the Yamaha?
post #11 of 14 Old 07-20-2019, 11:07 PM
pase22's Avatar
Liked: 2824
I also believe the receiver to be the issue. If I'm not mistaken, repairs should be covered under warranty. The OP may want to check his source volume levels too. I had a similar incident a while back and turned out the source (computer) volume level was below 50%.
pase22 is offline
post #12 of 14 Old 07-21-2019, 12:27 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
How old is the AVR?
I got hold of an oscilloscope. Here is a plot from it. (The blue curve is the pre-out. The yellow is the speaker output with an 8 ohm resistive load).
So, it is my receiver. The problem is affecting all the channels, so I am guessing that it is a common capacitor that drives all the channels has gone bad. What do you guys think?
post #13 of 14 Old 07-21-2019, 08:41 AM
bobknavs's Avatar
Quoted: 2338 Post(s)
Liked: 1666
Power supply, maybe?
bobknavs is offline
post #14 of 14 Old 07-22-2019, 12:24 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 5
No. It is fine. I tested with a multimeter. The positive and negative rails are also fine. I have no idea what could cause this clipping on all channels. I was guessing that it was the negative rail which was causing this issue, but it is at full 60 V DC and so is the positive rail.
