New home setup av closet - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-21-2019, 09:41 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
I am going to put my rack in the AV closet upstairs. I only have 5.1 speakers running from the great room to the closet where I plan to put my receiver and other gear.
how do I connect my sub from the great room back to the receiver?
Tony Wong is offline
post #2 of 11 Old 07-22-2019, 03:30 AM
Dargent0628's Avatar
Quoted: 224 Post(s)
Liked: 123
How many feet from the sub's location to the av closet? How are you running your speaker wire to the receiver? Monoprice has 100 ft RCA cable for $25.00.
Sent from my moto z3 using Tapatalk
Dargent0628 is online now
post #3 of 11 Old 07-22-2019, 05:19 AM
nonstopdoc1's Avatar
Quoted: 535 Post(s)
Liked: 116
If you cannot wire it than you can use a wireless adapter like SVS. Also, make sure your closet is adequately ventilated.
Sent from my SM-G975U using Tapatalk
My Build Thread
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | Denon AVR | QSC DPA 4.2 | ATI AT528NC | Procella P8/P5V | Revel C763L | Rythmik FV15HP x2
Living Room - LG OLED 65" | Yamaha 2060 | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia CC | Polk Surrounds | Monolith 12" Subs x 2
nonstopdoc1 is online now
post #4 of 11 Old 07-22-2019, 07:00 AM
bear123's Avatar
Quoted: 2561 Post(s)
Liked: 4007
If you run a long cable, do not run the bottom of the barrel cheapest product money can buy no qc 100 ft for $25 Monoprice. Its that cheap for a reason, and it isn't quality.
Go with Blue Jeans Cable LC-1 for a little more, but its the best quality you can get.
bear123 is online now
post #5 of 11 Old 07-22-2019, 07:22 AM
Quoted: 224 Post(s)
Liked: 123
https://www.avsforum.com/forum/168-h...monoprice.html
Please preface your remarks with an IMO. Debates occur regularly about the relative merits of cables, wires and interconnects. I referenced the monoprice product merely to show the OP that connecting the subwoofer to a receiver at a distance is neither difficult nor necessarily expensive. There are probably a hundred choices... What someone wants to spend is their business. Personally, I have had positive results with Monoprice, Parts Express and Amazon Basics, and would never spend 5-10 times more for a run of RCA cable ( yes, that is your "little bit more...").
post #6 of 11 Old 07-22-2019, 08:54 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
I think its maybe less than 100ft. but the walls are now closed and I cant run it through the walls. or I dont know how to.
post #7 of 11 Old 07-22-2019, 01:24 PM
Quoted: 487 Post(s)
Liked: 259
you may have to put a "line amp" / "distribution amp" into play. either that or use a "balun" ( RCA over ethernet/cat5). First off, test it out. I would stay away from the wireless options - I have tried a couple. most use the 2.4 ghz band and there is potentially a lot of interference in that band.
i am using on eof these: https://www.amazon.com/RadioShack-4-...s%2C206&sr=8-3
I only have to push the signal ~ 40'-50' ( wire length). my recviever was having trouble sending a strong enough sibnal to trigger the auto on function on the sub. I am using RCA over cat5 (110 block on the cat5 side). The line/distibution amp solved all my problems. I have a set of baluns, that I have yet to try...maybe today's the day for that?
update: these baluns work: https://www.amazon.com/HDTVhookup-St.../dp/B00D2172MS
good luck.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #8 of 11 Old 07-22-2019, 03:02 PM
Quoted: 224 Post(s)
Liked: 123
post #9 of 11 Old 07-22-2019, 03:27 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
so I read and good rcas will run 200FT?
post #10 of 11 Old 07-22-2019, 03:41 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
So there is no difference in term of quality if I use RCA Balun vs straight RCA cables?
post #11 of 11 Old 07-22-2019, 04:07 PM
Quoted: 487 Post(s)
Liked: 259
I couldn't tell you.
I would say test it out, test both, before running the wire through the walls. even all coiled up, 100' is a 100'...
