Looking for a amp-have questions/need suggestions - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #31 of 40 Old 07-24-2019, 11:20 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
great room is 19x16
currently is has 5.1 surround (3 front 2 back)
loft is 20x12
currently prewired for 5.1 surround
Tony Wong is offline
post #32 of 40 Old 07-24-2019, 01:21 PM
Zorba922's Avatar
Quoted: 7093 Post(s)
Liked: 5401
Originally Posted by Tony Wong View Post
great room is 19x16
loft is 20x12
If that's all one continuous space, then I'd shoot for at least one Hsu VTF-3 or VTF-15.
bear123 and d-rail34 like this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #33 of 40 Old 07-25-2019, 10:11 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
how to connect amp to receiver on the preouts
How do I pick a good amp to connect to a Denon 4500h/6500h on the preouts?
I have multiple rooms
Lower floor
1. 5.1 surround sound in the great room
2. 2, speakers in kitchen (open to the great room)
3. 2, speakers in the lower deck
upper floor
1. 5.1 surround in the loft
2. 2, speakers in the master
3. 2, speakers in the maser bath
4. 2, speakers in the upper deck
so I am looking at 10 speakers or 5 zones
in addition to 2, 5.1 surround environments
I think I need 2 amps?
should i get a more powerful 6500h to power all the lower floor
and get a 4500h for the upper?
In either case, should i get amp on both to connect to the preouts?
If i connect to preouts, that means the channels are not being used on the receiver?
Have to mention, all the speakers re ceiling speakers
specs on the 5.1 in lower floor is installed with
origin acoustics 3(D65s front) 2(D63 DT/SUR) rear
impedance: 6ohm
pwer handling: 25-140watts?
what does these mean?
post #34 of 40 Old 07-25-2019, 10:19 AM
eriksells916's Avatar
Quoted: 442 Post(s)
Liked: 171
@TonyWong that is a very expensive solution using an x4500 and x6500, you could probably get a whole home audio solution from OSD for way less https://www.outdoorspeakerdepot.com/...io-bundle.html
Maybe change your question and ask here or @rboster can move it for you https://www.avsforum.com/forum/36-home-v-distribution/
Good luck!
eriksells916 is offline
post #35 of 40 Old 07-25-2019, 10:29 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
but thats a 2 channel amp. I got 11 channels on the 6500h.
I was told I could reuse the surround backs (L &R), Height1,2 for different rooms?
post #36 of 40 Old 07-25-2019, 03:25 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
what do you think of wireless subs like sonus?
post #37 of 40 Old 07-25-2019, 03:36 PM
Zorba922's Avatar
Liked: 5401
The wireless functionality can be had with any subwoofer using add-on components like these:
https://www.amazon.com/s?k=wireless+...b_sb_ss_i_3_18
If you're refering to this Sonos sub, it looks like a WAF-driven marketing gimmick:
https://www.sonos.com/en-us/shop/sub.html
$700 for claimed 25Hz extension (probably a 6 or 12db rolloff not the standard +/- 3db) is lousy. The fact that the website offers zero remotely detailed specs is a big red flag.
You can get similar (most likely better) performance from a $450 RSL Speedwoofer 10S with built in wireless:
https://rslspeakers.com/products/rsl...-10s-wireless/
$600 (plus $100 for the wireless kit) can get you something like a Hsu VTF-2 which would blow that Sonos out of the water.
d-rail34 likes this.
Zorba922 is offline
post #38 of 40 Old 07-25-2019, 10:21 PM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
post #39 of 40 Old 07-26-2019, 06:00 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
need a good multichannel amp
I need a good multichannel amp. any suggestion?
post #40 of 40 Old 07-26-2019, 06:09 AM - Thread Starter
Quoted: 44 Post(s)
Liked: 0
what does this mean for an amplifier?
Continuous Power Output
(All Channels)
50 watts RMS at 4 ohms,
35 watts RMS at 8 ohms
Bridged Power Output
(All Channels)
90 Watts per channel
RMS at 8 ohms
