Receiver recommendation for 5.2.4 Dolby Atmos Setup - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By bobknavs
  • 1 Post By skylarlove1999
post #1 of 24 Old 07-23-2019, 10:25 AM - Thread Starter
gps470's Avatar
Quoted: 16 Post(s)
Looking for advice and recommendations from the community.
Just got the wiring done for the overhead speakers for Dolby Atmos 5.2.4 setup. Fronts are Def Tech BP8060ST towers, Rears are SR8040BP, Center CS8040HD, Overhead 4 Di8R from Def Tech and Monolith 10" Sub.
I currently have a Yamaha RXV675 driving this setup.
I also have a Denon 2313CI driving my living room setup (2 UIW RLS II as Fronts, 3 UIW RCS II as Center and Rears and Earthquake 15" Supernova MKV Sub).
Need to reuse as much as possible without buying anything new. Will most likely sell one of these receivers to make room for new one.
gps470 is online now
post #2 of 24 Old 07-23-2019, 11:14 AM
spyboy's Avatar
Quoted: 216 Post(s)
Liked: 158
How much do you want to spend?
spyboy is offline
post #3 of 24 Old 07-23-2019, 11:19 AM
pbz06's Avatar
Quoted: 1088 Post(s)
Liked: 903
I have a similar setup and using Marantz SR7011. I like what XT32 does with the sub integration.
Sony XBR-77A9G / Panasonic DP-UB9000 / Marantz SR7011 / Def Tech 9060 Series
pbz06 is online now
post #4 of 24 Old 07-23-2019, 11:30 AM - Thread Starter
gps470's Avatar
Quoted: 16 Post(s)
Under a grand.
post #5 of 24 Old 07-23-2019, 12:28 PM
spyboy's Avatar
Quoted: 216 Post(s)
Liked: 158
If you don't mind a factory refurb Accessories4less has the Denon X4500 for $999
Also has XT32, AC4less is offering free shipping and a free 3 year warranty when you purchase the Denon X4500.
spyboy is offline
post #6 of 24 Old 07-23-2019, 12:39 PM
dfa973's Avatar
Quoted: 774 Post(s)
Liked: 717
Originally Posted by gps470 View Post
Under a grand.
For that, you can look for those:
DENON AVR-X4400H
DENON AVR-X4500H
DENON AVR-X3600H
MARANTZ SR6012
MARANTZ SR6013
ONKYO TX-NR787
PIONEER VSX-LX303
PIONEER VSX-LX304
PIONEER VSX-LX504
dfa973 is offline
post #7 of 24 Old 07-23-2019, 01:28 PM
scotthal's Avatar
Quoted: 124 Post(s)
Liked: 70
Yamaha fanboy .. RX-V2085 (Adorama, a couple hundred under yr limit).
scotthal is offline
post #8 of 24 Old 07-23-2019, 01:59 PM
spyboy's Avatar
Quoted: 216 Post(s)
Liked: 158
I just checked Adorama, and the price for the Yamaha RX-V2085 is $1399.95...
If you have a link to "a couple hundred under yr limit", please post it.
spyboy is offline
post #9 of 24 Old 07-23-2019, 02:20 PM
scotthal's Avatar
Quoted: 124 Post(s)
Liked: 70
PM sent - bought mine for $799 a few months back. Sale price re occurs at 2-3wk intervals.
scotthal is offline
post #10 of 24 Old 07-23-2019, 02:25 PM
tebling's Avatar
Quoted: 139 Post(s)
Liked: 154
Go Dirac or go home. Safe and Sound (a reputable NAD dealer) has factory refurbished NAD T758v3 units at $1050. I've been running a refurbished T777v3 from them. The sound is fantastic and the dealer has been stellar.
tebling is online now
post #11 of 24 Old 07-23-2019, 02:25 PM
bobknavs's Avatar
Quoted: 2338 Post(s)
Liked: 1667
I own neither, but the Onkyo TX-RZ630 and TX-RZ830 both support 9 channels.
The RZ830 is a particularly good buy at the moment. However, it has no Audyssey (proprietary room equalization software instead), and I believe that it has a single subwoofer output signal (regardless of how many subwoofer jacks it has).
Personally, I'd prefer the Denon AVR-X3600H (not the X3500H; it's a 7 channel AVR), X4400H, or X4500H. Audyssey XT32 plus SubEq (semi-independent equalization of 2 subs). The X4400H and X4500H can be had within your budget as refurbs, or new if you can find the right deal.
dfa973 and gps470 like this.
bobknavs is online now
post #12 of 24 Old 07-23-2019, 02:36 PM
scotthal's Avatar
Quoted: 124 Post(s)
Liked: 70
Per (PM) request - linky: https://www.adorama.com/yarxv2085bl....01%40gmail.com
scotthal is offline
post #13 of 24 Old 07-23-2019, 03:08 PM
skylarlove1999's Avatar
Quoted: 935 Post(s)
Liked: 648
Keep in mind AC4LESS is not an authorized Denon dealer. That warranty is from a third party hired by AC4LESS. Safe and Sound is an authorized Denon dealer and has open box 4500 with a lower price that has 3 full year manufacturer warranty including open box items. I don't work for either business just presenting options. The 4500 is an amazing receiver. I owned it before upgrading to the 6500 using Denon's upgrade program.
Sent from my SM-G965U using Tapatalk
gps470 likes this.
skylarlove1999 is online now
post #14 of 24 Old 07-23-2019, 03:10 PM - Thread Starter
gps470's Avatar
Quoted: 16 Post(s)
How reliable are ebay brand new units in general ? Found good price on Marantz SR7013 there, but hesitant to take a chance.
post #15 of 24 Old 07-23-2019, 04:25 PM
Quoted: 935 Post(s)
Liked: 648
99% of the dealers on eBay are not authorized dealers so you might get a unit that works fine for 10 years you might get a unit that works fine for 10 minutes. Unless it's like 60 to 70% off the manufacturer's suggested price I wouldn't even consider buying from a non authorized dealer and even then I think it's just not worth the hassle.
post #16 of 24 Old 07-23-2019, 04:35 PM
Quoted: 935 Post(s)
Liked: 648
https://www.safeandsoundhq.com/produ...hoCkjwQAvD_BwE
post #17 of 24 Old 07-24-2019, 08:37 AM - Thread Starter
gps470's Avatar
Quoted: 16 Post(s)
I extended my budget a bit, and got Marantz SR7013 for a good price (at least that's what I think) from SafeAndSoundHQ. Dave there was a pleasure to work with. While there, I also got a better deal on Def Tech Di8Rs and I am going to return the ones I got from Crutchfield.
Thanks everyone. I will share how everything sounds when I have them installed!
post #18 of 24 Old 07-24-2019, 09:00 AM
m0j0's Avatar
Quoted: 603 Post(s)
Liked: 603
Very nice receiver. Congrats and enjoy!
m0j0 is online now
post #19 of 24 Old 07-24-2019, 09:15 AM
Quoted: 935 Post(s)
Liked: 648
Safe and sound is an amazing authorized Denon dealer glad you were able to work with Dave and they could hook you up with the Definitive Technology speakers as well
post #20 of 24 Old 07-24-2019, 11:50 AM
Stephen Hopkins's Avatar
Quoted: 438 Post(s)
Liked: 202
Safe & Sound has become my go-to recommendation of AC4L... I got my refurb SR6011 there and was quite happy with the service, packaging, and price. They don't have quite as much available, especially on the refurb side, but I get a much better feeling from them than AC4L after the notable number of horror stories that have popped up over the last couple of years.
BenQ TK800 | Silver Ticket 106" 16:9 1.0 Grey | Marantz SR6011 | B&W P6 | B&W CDMC SE | Sonance .5 THX SUR | MCM In-Ceiling Atmos | Ascendant Avalanche 12" in 6 ft^3 @ 18Hz w/ BASH 500w Plate Amp | Sony X800 | NVidia Shield TV Pro | XBox One 500gb | Nintendo Switch | Harmony Smart Control | SmartThings Hub | Google Home | AT&T Fiber 300 | YouTube TV | Netflix | HBO Now | Spotify
Stephen Hopkins is offline
post #21 of 24 Old 07-24-2019, 12:59 PM
Quoted: 935 Post(s)
Liked: 648
I know I mentioned it before but accessories4less is supposedly an authorized Denon dealer but there is a thread on AVS Forum about AC4L that has been closed where there are quite a few horror stories. Buyer beware.
post #22 of 24 Old 07-24-2019, 01:00 PM
Quoted: 935 Post(s)
Liked: 648
Safe and sound on the other hand is an authorized dealer for Denon and Marantz and many other great manufacturers and on their open box items they still get the full manufacturer's warranty.
post #23 of 24 Old 07-24-2019, 03:07 PM - Thread Starter
gps470's Avatar
Quoted: 16 Post(s)
Originally Posted by skylarlove1999 View Post
I know I mentioned it before but accessories4less is not an authorized dealer and that 3-year warranty that's for free is worth exactly what you pay for it from them. I would stay as far away from accessories4less as you possibly can.
Actually A4L is authorized as per Denon.
If you buy a refurb from them, you get one year manufacturer warranty and 2 years from CPS for whatever it's worth.
https://usa.denon.com/us/wheretobuy/...935.1563922924
Sent from my Pixel 3 using Tapatalk
post #24 of 24 Old 07-24-2019, 03:12 PM
Quoted: 935 Post(s)
Liked: 648
Thank you for correcting my misinformation I did also reach out to Denon to verify. They didn't have anything other than to say that they were currently an authorized dealer.
